Hi we have an old kitchenaid dryer the modle nubmer is keye900twho.its plugged in the lights all turn on. we press the on button it beeps and turns on, we select the options then you cant press or do anything because of the pause/restart button led light is blinking and we dont know what to do please help this is only way to dry at the moment. thank you all in future!
SOURCE: Dryer stops drying and lint error message...
try cleaning the vent line. if you have a flex vent line make sure it isn't kinked in any spot. make sure the outlet outside does not have a birds nest or anything blocking it
SOURCE: kenmore 417 dryer
unplug for 5-10mins. Check vent and venting. sounds like it's not sensing and then maybe getting to hot
SOURCE: Dryer starts, then stops, no heat
if ther is no heat you need to ck igniter. if igniter not working the gas will not be on it cost 50.00 and part # is 13439400.
SOURCE: Kenmore Elite HE3
Try this.. across the top rear of the dryer there is 3 gold screws (1/4" I believe) remove them and pull the top panel back about 6" inches then get a hair-dryer.. when standing back in the front of the machine there is now a black strip of sheetmetal you can now see that is right behind the control panel your pressing all the time.. there is a small gap about 1/2" between the black metal strip and the control panel that allows you to see a few green PC boards from the back side.. put the hair-dryer on high and work it back and forth in that slot pointing it at these boards... this will dry out the moisture back there on the boards and in the buttons themselves.. Give it a few minutes.. the beeping sounds like your timer indicator buzzer button is stuck ON so be sure to dry off the right area where those buttons are also.. once the beeping stops it should work.. Mine has done this 3 times and the hair-dryer has fixed it every time.. What's going on is because the buttons have been pressed so many times they have almost collapsed together and only a little moisture allows them to stick ON.. once the timer button does this you cant start ANY mode until it is cleared.. kinda like holding the channel button down on your remote to the TV and not being able to do anything else until you get it to stop...
SOURCE: Dryer will work for about 15-20 minutes. Then
Always list your machine model, mfg, type, voltatge, etc. The more info we have the more we can help you. If you just got the machine, check your warranty. Blinking lights probably mean an electronic control problem, you're going to need a qualified tech to fix that.
