Question about Maytag Neptune MDE5500AY Electric Dryer
Control panel is dead
We bought a used maytag neptune electric dryer model #MDE5500AYQ and I needed to install a 3 wire plug
so i did not realizing that the plug on the wall had been wired incorrectly ground and hot where switched so the dryer got 120 olts to ground when i plugged in cord, then it popped the breaker i relized right away what it was and corrected the problem but the dryer does not turn on is there a breaker or fuse inside the dryer to protect against this and if not what are the likley parts that would be damaged when this happened. Im not even sure if the dryer ever worked or not it wasent hooked up when i bought it from the seller
  • 108 Answers
Well irishs, when you buy something used with no written warranty, its like the old Irish saying. "Ya pays ya money and ya takes ya chances." So!! You either bought a defective unit, or you delivered 120 volts to a 230 volt motor and damaged it. Bottom line is, you have no recourse. Don't feel too bad. I have done this myself on several occasions. The good news is that this is a great time to buy appliances. The stores are practically giving this stuff away! Write this off as a lesson learned my friend...
Ray
Posted on Dec 14, 2008
Hello I have a MAYTAG NEPTUNE DRYER Model# MD5500 (MDE5500AYQ) . The console panel lights up.You can load up a cycle on the display but the unit won't start. It Just beeps or locks up.So I checked the...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 30, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Screaming sound when dryer is on
Hi, W/D here.
Screaming dryers can usually be traced to the drum support roller and the roller shaft. Once the screaming has commenced, both parts usually are damaged beyond reuse. Check this link; it will give you a good idea of what you need, and what to look for. You can scroll over the diagram to view the parts and assembly instructions. A lot of information, if you need it. It will be best to use tha diagrams as a disassembly guide, and confirm that the roller and roller shaft is the issue. Since you're already down to the rollers, it would be wisest to change them both at the same time, if this is the issue.
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Dryer-Parts/Model-MDE5500AYQ/3048/0151200/M0606011/00004?blt=06&prst=&shdMod=
Best regards, --W/D--
Feb 18, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Where can i get the wiring diagram for the neptune dryer model #mde4000ayw so i can put the 4 prong cord on the back?
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Oct 14, 2010 | Maytag Neptune MDE4000 Electric Dryer
Maytag neptune electric dryer MDE5500AYQ not getting hot
You should get a diagram of your dryer *(look on the exterior back panel and under the top lid to see if they put a sticker diagram there.
Your heating element can be shorted open so no heat can be made.
You can easily check the element with continuity meter to see if it's broken. Then, check the part number from the Maytag website and price up a replacement. I would also check Ebay if the unti is older and you want to save some money on the part.
Good luck and be careful...always do your continuity checks with unit unplugged.
Jan 19, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag neptune dryer mde5500ayq replaced old motor with new motor starts up first time alright I turn off and it will hesitate to restart. most times it will not restart. Humms then kicks out. I have no...
Compare the wiring connections on both motors. They may be marked. They may be different. Careful examination will determine the start and run wires. Other wires turn on the heat once the motor reaches running speed. The thermal fuse for the motor is internal and unservicable. The hi limit sensor will control the heat, but will not necessarily turn off the motor.
Apr 23, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Motor kicks out
sounds like you have a bad motor
Dryer doioesn,t dry in a 90 minute cyclr
you need to clean out the back vent hole on the dryer and the wall vent,you are keeping the moist hot air in the dryer that needs to be vented out so the dryers not drying like it should,let me know how you do-mike
Nov 12, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Electric Dryer - Control panel doesn't light unless door is open
the power connects for the 240 volts to the outside screws on the terminal block the center connector is the nutral connection
Jun 09, 2008 | Maytag Neptune MDE6800 Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
124 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
