Question about Maytag Atlantis MAV6451 Top Load Washer
Water problem My machine is not holding the water. It is draining as fast as it is filling. It has worked fine for over 3 years so I am wondering if it is a valve and how do I get to it in order to fix it?
  • 67 Answers
I agree with him the drain hose needs to be as high at the top of the washer preferally with the hose making a u shape like a plumbers loop also make sure that the drain hose has plenty of room inthe drain pipe that its not shoved it there real tight believe it or not it will work for a long time but all ofa sudden it will stop
Posted on Mar 21, 2007
    President:
  • 1,462 Answers
You may have the drain hose too low so water syphons out. raise the drain hose as high as poss before going down to the drain
Hi my hotpoint ultima wmd960 of 2 half years,when i put a wash on it starts and fills up for about 3 mins later it comes up :no water, check supply, then starts ti drain water away ,then fills up again,so...
Please check your inlet water hose for any clogging that may be stopping the proper flow. some machines are programmed to get filled in particular given interval of time. they need proper pressure to properly work. Remove the hose and clean the wire mesh filter.
Oct 02, 2017 | Washing Machines
Washer will not hold water
You need to check drain hose, the drain hose needs to be above the tub. If it isn't the water will just drain out when you fill
Jan 12, 2010 | Washing Machines
Whirlpool washer - tub drains while it fills.
Your drain is to low. Make sure that the drain that your discharge hose is going into is at least as high as the washer. If not the water will drain out as fast as you can fill it.
Aug 15, 2009 | Whirlpool Washing Machines
Neptune frontloader washed accumulates water
replace water valve if its filling while not being used. if u hear the water in the tub but noty seeing it thats normal they water in them always. as far as mold u can buy some affresh its a cleaner for the frontloads
Mar 15, 2009 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool Washer - Imperial Series Quiet Wash 2
your washers drain hose is too far down the drain pipe which is causing a siphoning action pull the washers drain hose out pipe some you should be able to hear water dropping into the pipe the reason it only happens in the rinse cycle is because the water from wash is being drained and before the water vacuum is broken the rinse water comes in causing it to keep draining
Dec 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Water doesn't drain
water discharge drain $50 part, easy installation. google the lg model to locate part.
Nov 19, 2008 | LG WM-3677HW Front Load Washer / Dryer
Can't hold water
There is no drain valve.
Pull the drain hose up out of the drain pipe until there is only about 6" inside the pipe. Make sure there is a gap around the hose where it goes into the pipe so air can get in.
Make sure the drain pipe is higher than the water level in the tub.
Nov 17, 2007 | GE WJSR2070B Top Load Washer
Wash Machine Drainage problem
i am a recently retired appliance engineer of 20 years, slowing down the flow of water from any electrical washing appliances can be dangerous and will cause extensive damage to the appliance in question, at the very least it will stop half way through the cycle every time the only way to remedy this is to rectify the drain, or at least sort out another waste water outlet sorry
Sep 21, 2007 | Estate TAWB600JQ Top Load Washer
Maytag Atlantis MAV6451 Top Load Washer Logo
27 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
