Question about HP W2007 LCD Monitor
Instructions for hooking up a new monitor
I just purchased a 20'' HP Monitor. I'm not sure if I follow the VGA hook-up instructions or the DVI hook-up instructions.
If you have a newer computer, Im assuming that you are hooking this monitor up to a computer, if the computer has a dvi connector on the back then hook the monitor to the dvi connector and away you go. In some rare cases you may have to install the drivers that should be included in an (Install CD) that came with the monitor. If not u can obtain them from HP's website follow the links to support, downloads, drivers, input the model of your unit when prompted and then just follow the instructions for downloading your monitors latest display drivers but you probably wont need any of these steps it should be plug n play compatible as long as your computer and monitor are within a few years of each other.
Posted on Mar 23, 2009
    Scholar:
  • 113 Answers
If you attach correctly all the connections then nothing to worry about. if you just follow all the instructions carefully and correctly then set back and relax... okay...
Posted on Dec 14, 2008
NO DVI INPUT SIGNAL AND MONITOR GOES TO SLEEP
you can't run 2 different inputs at the same time. VGA takes prescedence.
Apr 06, 2014 | HP L1950 Monitor
How do I fix the error no vga input signal no dvi input signal monitor going to sleep
Check if you VGA is properly settled in the PCI slot. Try to take it out, clean the slot for dust.
If that doesn't help, it is well possible that you VGA is not working any more.
Jun 10, 2012 | HP Computers & Internet
My hp monitor flashes no dvi imput signal
First, make sure the dvi cable is hooked properly to the computer and that the computer's VGA card's dvi output is set to work in the monitor's advance options.
Has this computer/monitor combinatioin ever worked before? Or did the message appear after successful operation of dvi to the monitor?
Perhaps, try to use a vga cable to the lcd monitor to see if that input works.
Good luck on this repair.
Jan 28, 2011 | HP w1907 LCD Monitor
Computer won't recognize monitor driver
Its the usb, if u connect the monitor via the standard port, the vga port, it will work. If your monitor only have an dvi cable you can fix that by an adapter. That adapter should be an DVI to VGA.
Good luck to you
Dec 11, 2008 | Acer AL2016W 20" LCD Monitor
Got this monitor from a friend with no instructions
It's an ancient monitor. You may have a new computer with a different kind of connector. That monitor uses a VGA connector. Your computer probably has a DVI connector.
This page here:
http://www.newegg.com/Product/Product.aspx?Item=N82E16812267001
has pictures of the type of converter that you need.
Dec 05, 2008 | ViewSonic MB90 Monitor
Samsung T220 monitor hook up to new macbookpro-how-pc driver only-help
I think you're using the adapter in reverse. The adapter that changes from VGA to DVI but not the other way. You should plug the adapter into the DVI out on the macbook and then plug the VGA end of the cable into the monitor. If the monitor has a DVI input then you should be using a DVI to DVI cable to hook it up.
Once you have the cable plugged in you'll need to enable dual monitors or switch to external monitor on your macbook. Don't worry about the driver's cd, they are not necessary to make the monitor work on your mac (or on a PC for that matter).
There are two great instructions on how to do this, just google for "macbook switch to external monitor"
One here.
Second one here.
Jun 04, 2008 | Samsung Computers & Internet
Hooking up a HP L1755 17
What is the way to get the very best picture quality when hooking up my new HP L 1755 Flat Screen Monitor to my E-Machine W3052 which is about 3 years old.First would it be compatible or the best idea to hook up VGA to VGA.DVI to DVI which means buying a new Video card for my Computer so the DVI could be hooked up to my computer, or hook up the DVI to VGA Connector ? Would a DVI Video card be worth the extra costs if I went that route ?This HP L 1755 only has a response time of 25 ms, is that good enough to watch Music Videos or not ? I do not do any gaming.Can you tell me the best detailed step by step way to hook up this monitor to my E-Machine W3052 Computer and which Connector to use ? If I need a DVI Card what would be the Part number or Card I would need to get ? Sorry about all the questions.Any guidance and input would be greatly appreciated since I have a disability and need some help and to be honest I do not have 50.00 for a DVI Video card. Sincerely & God Bless ! Thanks,Diehard16
Feb 18, 2008 | Computers & Internet
Samsung Syncmaster 245BW, can't get it up and running !
Most of the time when this happens it is due to a bad monitor, if you have another pc try to hook this monitor up to that one to see if it actually works, these monitors sometimes get damaged during shipment!
Jul 25, 2007 | Samsung SyncMaster 245BW Monitor
HP W2007 LCD Monitor Logo
199 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
