Fisher DD603B / DD603W / DD603H Dishwasher
Problem for Fisher DD603B / DD603W / DD603H Dishwasher
Error U3
By di on Dec 14, 2008
Starts and runs for about 5 mins, then it beeps and comes up red in the display with U3 written on it. do you know what this means?
Comments:
Dec 14, 2008
- My apologies it is a DS601V2 model and thank you so much, the pressure seemed to be the problem as it is working fine now.
Best Solution
posted on Dec 14, 2008
Very Helpful)
RescueTech
Rank: Guru
Rating: 96%, 162 votes
That's a "Low Pressure" fault and it's possible you may only need to reset the mode. This question is posted under DD603 but a U3 code is usually associated with the 602 models. I am including an instruction for you on how to check the setting. Start with that first, it is easy to do.
Let me know if you are not able to read the text.
Was this helpful?
Yes
No
Solution #2
Helpful)
sunny16
Rank: Guru
Rating: 92%, 695 votes
U3 will display because the water did not drain from the previous stage in the cycle... Check the HP/LP settings first as this will give the impression the water did not drain if incorrectly set. Otherwise the pump may be damaged, blocked or the waste hose blocked.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Fisher DD603B / DD603W /
Questions and Unsolved Problems for Fisher DD603B / DD603W /
Do you recommend Fisher DD603B / DD603W / DD603H Dishwasher?
Answer
Answer
at first from time to time it was stiff now i cant close the top draw at all some thing to do with... (More)
Answer
I have the two drawer dishwasher. Today they both turned on the rinse cycle. We can't get them to... (More)
Answer
two draw machine that has a habbit of flooding but now after the usual hairdryer on the sensor and a... (More)
Answer
Cannot use dishwasher - the top drawer will not close
Answer
this is a fisher and paykel double drawer dishwasher model dd603
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwashers Experts
Top Dishwasher Repairmen
in , CA
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
