Question about LG DLE3777 Electric Dryer
GE Dryer DPSR483GA2WW too noisy
The dryer is 8 years old. It started getting noisy about 1 month ago. It is a vibrating type noise. It is not a squeeking noise as someone else had reported. I checked all the things that cause a squeeking noise and they seem to be ok. I asked a tech repairman to look at it. He said he thought it was the motor. The motor bearings. He quoted me $300 to repair it. For that price I thought I could buy a new one! If it is the motor I would like to change the motor myself but I do not know how to get into the motor area. Any suggestions on the cause and how to get into the motor area?
  • 108 Answers
Remove the rear panel from the unit. This should expose the motor, drive belts, and the drum bearings. Now turn on the unit and your may be able to determine where the noise is coming from. Keep your hands away from moving parts and electrical connections!!
Ray
Posted on Dec 14, 2008
My GE Profile Dryer is only 14 months old. A couple months ago a soft squeal began whenever I use the dryer. I only average 2 loads a week at the most and sometimes less than that. Of course, the...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Aug 07, 2011 | GE Profile DPSB620GCWW Gas Dryer
Have ge model WCVH6800J1MV Will be 1 year old in Nov. it bangs and walks across the floor. it also vibrates and makes loud "clicking" noises have had five service repair visits all to no...
had the same problem but 7 or 8 months it started had it replaced and 7 or 8 months on new again same problem, a speed wash which is 36 mins takes 1.5 to 2 hrs
Oct 27, 2010 | GE WBVH6240F Front Load Washer
GE Harmony Dryer makes Loud Vibrating noise
If you can open the walls of the dryer up check all screws and bolts that hold things together. Some times they will vibrate loose causing parts to make a vibrating sound against the frame itself.. Eventually the loose screws will just keep getting looser. Even the screws on the walls of the unit should be tightened That could cause a lot of noise.
Apr 10, 2017 | GE Profile Harmony DPGT750EC Electric...
My GE Harmony Dryer is making a LOUD noise during entire cycle
heatman101
yue
Jan 26, 2010 | GE Profile Harmony DPGT750EC Electric...
GE Profile dryer - automatic dry never stops
ok go back to that page and
look in the
backsplash, blower section
you are looking for part
230
Oct 15, 2009 | Dryers
GE Clothes dryer squeaks
My ge electricryer sqeaks very loud and makes a thumping noise. it just started a cuouple of weeks ago.
Jun 19, 2009 | GE DWXR483EBCC Electric Dryer
Dryer vibrates with exhaust hose attached
Doubt this has anything to do with the drum replacement. Your model has an independent variable speed blower motor (not linked to the motor which turns the drum) and speeds up when it senses a vent restriction. You may have a problem with the vent motor or blower wheel, or just a vent restriction issue.
May 21, 2009 | GE Profile Harmony DPGT750EC Electric...
Maytag Quiet Series 200 Electric Dryer
I also had a similar problem with my maytag dryer which is 3 1/2 years old. It was the idler lever assembly with pulley. The part number is 11222607JG and the cost is about $20.00. Hope this helps.
Apr 04, 2009 | Maytag Dryers
Noisy dryer
i had same problem with washing machine. i found out it was the stone inside which holds it down while it spins. The screws or nuts or what ever is holding the stone could be loose.
Or it could be the nuts or screws of the actual drum that spins that got loose when you moved the machine
Nov 10, 2007 | Washing Machines
LG DLE3777 Electric Dryer Logo
229 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
