Question about HTC Touch P3450 Smartphone
Lost HTC BH M200 Bluetooth headset manual, How do I pair it?
Without the manual, I haven't been able to push the right series of buttons to pair the headset with my new phone....
Does anyone know what I can do?
  • pap5t Dec 30, 2008
    same here... but i have a tytn II - should pair with this device too, shouldn't it?
  • cdjexe Jan 06, 2009
    I have paired BH M200 with an samsung to make a test and now i want to pair with my phone Blackstone but doesnt work. Any suggestions?
Hi, to pair this device first make sure it is powered off.
Then press and keep holding the power on button (large round one on the front). After a few seconds the LED will illuminate blue and then after a couple more seconds will flash red and blue. Now you should be able to pair with it.
Regards,
Nik.
Posted on Nov 04, 2009
  • Sherif Elshenawy Dec 05, 2010
    Thanks very much it's great
Nokia bluetooth head set BH-105 can't conect with my nokia C6 mobile
1: SWITCH ON THE BLUETOOTH FUNCTION ON YOUR MOBILE 2: THEN CHANGE MY PHOES VISIBLITY FROM HIDDEN TO SHOWN TO ALL 3; MAKE SURE U HAVE PRESSED THE BLUETOOTH HEADSET SWITCH ON BUTTON FOR AT LEAST 10 SECONDS . 3: U WILL HEAR A BEEP SOUND WHEN THE HEADSET IS SEARCHING FOR PAIRING 4 NOW SEARCH FOR NEW DEVICES ON YOUR MOBILE 5 WHEN THE SEARCH COMPLETES IT WILL SHOW BH-105 6 : SELECT IT AND CLICK PAIR . FINISHED
Jan 26, 2012 | Nokia Bluetooth Headset BH105
Have always used 0000 on my mobile as passcode to pair with nokia bh 212. however, for some reason, it says unable to pair, since this afternoon. pls help if there is anything else that i can...
i find out the way already as after reading its manual. You have to reset this headset by turn it off first. Then you push and hold its function button around 8~10s, you'll see the green and red indicator light alternate. Now you pair again with your phone and it works.
Sep 08, 2011 | Nokia BH-212 Bluetooth Headset
Dear HTC Experts I recently bought BH m300 bluetooth headset and I have asked the shop assistant who confirmed that it works with all types of mobile. Despite of this my Nokia N97 does not find the...
For connecting to other devices, press & hold the power button of your bluetooth headset for initiating the discoverable mode. When the led light starts flashing in red color, search for the headset from the phone in which you wanna connect. Open the Bluetooth settings, turn it on and search for new devices and pick from the list and pair the headset. After this, the headset will be auto-connected.
Regards
Vineeth
Jun 22, 2011 | HTC BH M300 Bluetooth Mono Headset (UK...
How do i pair up mu htc hd2 with htc bh m300 as i bought new one its not been showing in my device
ok you hold the power key 40 second and you see the power light is stable now you find the device from your phone when you able to find the device you are able to pair the device using 0000 pair key.
Oct 08, 2010 | HTC BH M300 Bluetooth Mono Headset (UK...
Trying to pair nokia x6 with nokia BH-214 bluetooth headset i need the code to pair them
You have to hold the button down on the headset controller for approximately 6 seconds until the little LED on it flashes blue very quickly. The X6 will see it and match a pair automatically. If you just switch the headset on and the light flashes green the x6 will ask you for a passcode ... it doesn't matter what you put in (it seems) even '0000' ....it won't match the pair. HTH
Reply
Sep 15, 2010 | Nokia BH-214 Bluetooth Stereo Headset
Nokia BH-213 unable to Pired with Nokia E-63,it stopped suddenly
I also experienced the same problem. After trial and error I realized that the bluetooth device needs to be reset to fix this issue.You may reset the bluetooth device by deleting the pairings from the headset or reseting the headset. Switch off the headset, and press and hold the multifunction key for over 8 seconds. Start pairing the device again. It should work fine now with default passkey 0000
May 03, 2010 | Nokia Bluetooth-Headset BH-213 2600...
Need a passcode to pair nokia BH-101 blutooth to phone lost passcode
If you haven't actually manually changed it, the password is always the last four digits of your phone number (ex. 1-555-868-2212 your password is 2212). If you manually changed it, you need to call Verizon and have that worked out.
-CompDoctor
Mar 02, 2010 | Nokia BH-101 BLUETOOTH HEADSET
Without the manual for my BH M200 HTC blue tooth, I haven't been able to push the right passcode of buttons to pair the headset with my new phone
Try the default pair code as 0000, 00000, 00000000 or 12345. One of the above codes should work with your headset.
Sep 09, 2009 | HTC Touch P3450 Smartphone
Bh 101 bluetooth headset lost manual and forgot pairing code
Try this: 1. Ensure that your phone is switched on. 2. If the headset has not been previously paired with a device, switch on the headset. The headset enters the pairing mode, and the indicator light starts to flash blue quickly. If the headset has been previously paired with another device, switch off the headset, and press and hold the multifunction key until the indicator light starts to flash blue quickly. 3. Activate the Bluetooth feature on the phone, and set it to search for Bluetooth devices. See the user guide of your phone for instructions. 4. Select the headset from the list of found devices. 5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones, you may need to make the connection separately after pairing. You only need to pair the headset with your phone once. If pairing is successful, the headset appears in the menu of the mobile phone where you can view the currently paired Bluetooth devices. When the headset is connected with your mobile phone and ready for use, the indicator light of the headset slowly flashes blue.
Apr 14, 2009 | Cell Phones
Pairing NOkia BH-207 with Blackberry 8120
Power it off
Press the power on button for at least 10 seconds, until it keep the blue ligth on and then pair it with your BB
Dec 14, 2008 | Nokia Bluetooth Headset BH-207 Wireless...
HTC Touch P3450 Smartphone Logo
3,653 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
