Question about D-Link DPH-50U IP Phone
DPH-50U can't be uninstalled or reinstalled correctly
I installed latest driver for DPH-50U on my Vista OS, it worked fine, but after I run Windows Update, vista gives me blue screen (memory dumps ), no matter I uninstall or reinstall driver, it either shows me blue screen again or the “D-Link device not present"
  • 4 more comments
  • elwoody Dec 29, 2008
    Same here. After I reinstalled the correct vista driver I get a little red icon and device not present notice. Still working on it. I'll post if I find anything.
  • sbassiouny Jan 08, 2009
    i have the same problem on XP SP3 , after repeated calls with D-Link customer support , i get device Not present BUT i can call ONLY as VOIP (cant hook up a phone line for dual use )
    any suggestions ?
  • Anonymous Jan 30, 2009
    I have Windows Vista Home Premium and I cannot install the DPH-50U driver. A red icon appears and indicates "D-Link Device Not Present."
  • yani60 Feb 03, 2009
    Same here too. Its enough to make you batty. Until I can afford a WiFi Skype phone I'm going back to just a plug in Skype phone. Problem is last one I got lasted only 3mos. 1week. Couldn't get a refund. I'm thinking these are a piece of junk. Have headset though that work amazingly. Its plugged into my computer too. Tied to the computer. Blah.
  • p1138w Feb 05, 2009
    There is no fix and D-Link doesn't care.
    I have one as well and my solution is: run over it with your car. It will work even better then and won't cause you any more stress.
  • axsnow Feb 27, 2009
    i need a dph-50u driver for vista
    New Friend:
For your information the D-Link DPH-50U is in reality a: PLANET SKG-300 in a different box !!! You can download the last driver version (work's with windows 7) via this link: http://www.planet.com.tw/en/product/product.php?id=4084#dl
Steve president of www.BillProduction.com hardware solution !
Have fun !
Posted on Mar 09, 2013
To solve a problem "device not present", you must delete registry key "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{55280429-413e-460f-a31a-e19314823119}\0001" and restart service "VService".
Posted on Jun 13, 2009
  • Ben Southgate Nov 02, 2010
    I tried this method, also uninstalled everything, switched off the computer and tried again, It worked! I can tell you I am not going unplug this cable ever!
Yes, installing twice helps and also you have to plug the DPH-50U always in the same usb slot, as long as you have the same OS installed.
If you can't figure out your original USB hole, you will always have trouble...
Posted on Jun 03, 2010
My DPH-50u occassionally needs to be reinstalled (still haven't figured out why) but this latest time was much more painful. It sounds similar to this problem and I couldn't find a solution anywhere online so I thought I'd share what I finally got to work. The uninstall option in the Start menu did nothing, the uninstall option in Add/Remove Programs also did nothing. If I inserted the CD it acted like it was installing the drivers fresh and then would blue screen. In fact, just unplugging the USB blue screened my computer. I finally ran the updated 1.1 driver setup.exe which first uninstalled everything and then reinstalled. The steps weren't quite like in the Quick Install guide, but once it said it was done I plugged in the USB cable which then prompted another driver install popup window the only trick here is that windows wants to install drivers from the wrong location so twice I had to repoint it to the folder where I had downloaded the updated drivers. Once I went through that process twice, I was all set! Hope it helps someone else.
Posted on May 23, 2010
    Please let me vent about this Product. ITS F'n GARABGE! and D-link do not give a flying ****! I will never buy another Dlink product! I have the same issues as everyone above and also all over the internet. D Link clearly know there is an issue with the device, hence why it is no longer available. If anyone gets this device working DO NOT EVER unplug it, or it will NOT work again. Ive even had to change computers. When I had to move this computer also it now no longer works. I have tried endlessly to repair, reinstall etc with no luck, I've gone out of my Friggin mind as I relied on this device. Well no longer! Im going over to magic jack or something else, Goodbye Skype, Sorry Skype but unless I can connect my regular phone, I'm done! I think its time you created a router like Vonage have, save us all the time from buy crappy 3rd party devices.
Hp vista and monitor hp2509 was working fine. i uninstalled monitor driver but now computer starts fine but monitor goes blank
Monitor drivers are built into windows OS, you can't uninstall the driver unless you went to devise MGR, monitor, and opened proprieties and hit uninstall, and even then when you restart windows, it will auto reinstall the hardware. So what you're saying does not make sense.
If you reboot and noting, try a system restore, if you have a windows disk, then run repair. But like I said, you don't install monitor drivers, DVD rom drivers, these are generic drivers that are made into windows. If you think a monitor has a driver that needs installing, explain how people install windows if they couldn't see the monitor.
Only onboard video and graph cards need drivers to run the video at its intended resolution, but it does not need a driver for the monitor, it's built into windows.
Mar 29, 2013 | HP 2509M 25 Widescreen LCD Monitor -...
I have a use d-link 50u ip phone what do i nedd to make work i don't have a manual to install
http://www.dlink.com/products/default.aspx?pid=DPH-50U&tab=3
Click on Support Resources, Pick your country and download a manual or driver, everythings there
Aug 01, 2010 | D-Link DPH-50U IP Phone
Using D-Link DPH-50U with a softphone ie. Xlite,eyeBeam, etc
That phone looks exactly like the one I use from sjlabs.com. I have a SIP account with FWD on mine. The router should have nothing to do with it unless you are behind a corporate router with strict ACLs. The soft phone is software based. Just make sure your STUN server and SIP proxy is set up correctly. The Xlite should provide all the info needed,
Jan 29, 2009 | D-Link DPH-50U (0790069289750) Router
DPH-50U driver using high DPCs
I had a similar problem on a pc i built. the culprit was my wireless card. i opened up the pc and moved the card from one pci slot to another. powered it on and it redetected mt card. my cpu usage went from 40-50% at idle to 0-5% depending. hope that helps
Oct 25, 2008 | D-Link DPH-50U IP Phone
DPH-50U default audio
I had the same problem. I just reinstalled the hardware manually through the install new hardware module in XP. Once I did that, Skype "saw" the D-Link adapter.
'I went into "add new hardware" clicked "yer, hardware is already installed" then selected the D-Link device that will be listed. You have to have the driver already installed, then let the OS install the hardware as it always does and then you should see the D-Link driver as one of the choices.
This drove me crazy too. I hope this works for all of you. Good Luck.
Oct 24, 2008 | D-Link DPH-50U IP Phone
Communication error
Marky12, if the printer works fine on the vista system then you can eliminate a hardware fault. sounds like a driver or install issue. remove the printer completely from the mac (uninstall software, drivers and unplug) then go to epson.com, choose your countrey and head to the support and downloads section. Get the latest drivers for mac/tiger and reinstall the printer (make sure you have restarted the mac in between uninstall and reinstall) and most important !!! dont plug in the usb cord until the driver install tells you to
Good luck
Feb 28, 2008 | Office Equipment & Supplies
How to do voip calls with the regular phone
Did you read the manual?
first you press ##
then you will hear a weird buzz
then you dial 00 and then the phone number including the country code (example in canada.. you will do 00 1 450 419 0000
then you press *
so again,
## (weird buzz) 00 1 450 419 0000 *
and wait few seconds
Nov 15, 2007 | D-Link DPH-50U IP Phone
D-Link DPH-50U IP Phone Logo
1,729 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
