Question about Pioneer DEH-P680MP CD Player
CD player just quit working.
The cd player was cutting in and out for a couple days and then it just completely stopped working, it doesn't turn on or anything. I checked the fuse and it was fine. Is there anything else i can do?
  • 363 Answers
SOURCE: Serious Problem With My CD Player
Take off the face and check the electrical contacts are not damaged.
Posted on Sep 22, 2007
SOURCE: My DEH-680MP Stopped Working....
bad ribbon cable on display they wear out!!!!Take to local repair depot should have the part in stock
Posted on Apr 11, 2008
  • 34 Answers
SOURCE: inside display is completely dark, doesn't work.
you need a new flexable ribbon cable. try ebay or
Posted on Jan 09, 2009
dj x
  • 61 Answers
SOURCE: tail and dashboard fuse keeps blowning
unhook black wire from harness and the ground from pioneer unit install the ground wire from pioneer unit to frame of car (you may need extra wire to do this) make sure the black wire from pioneer unit is bolted to frame of car not to the harness black wire........fuses will no longer blow and you will have your lights.
hope this helped
Posted on Mar 04, 2009
  • 676 Answers
SOURCE: how to install a cd player without a wireing
If the speakers are working already, you will have to connect the red wire from the stereo to the yellow wire for the iginition. Black to black for ground, and yellow from the stereo to orange in the vehicle wiring. If you are using a test light, the orange should be constant +12 volts, yellow will have switched +12 volts. This will turn off the stereo with the key.
Please be sure to give a rating. thank you.
Posted on Jun 12, 2009
J-Chris Ward
  • 731 Answers
SOURCE: i recently hooked up my pioneer cd player in my
Hi:) Sound like the pre-amplifier transistors are burnt out if you hear no sound at all. If you can hear a very fate sound then it would be the Output amplifier IC's. If you are using a separate output amp check the amp.
Posted on Mar 16, 2011
0 characters
1 Points
I get the TOC Error, when I put bought cds in.
don't think you will like this answer but, it probably time to get a new cd player... you could try using a cd cleaner designed to clean the laser or spray the insides with compressed air.
Apr 29, 2010 | Kenwood KDC-MP228 CD Player
Car cd player sound
check shorted speakers or they are getting old and need replacing
Apr 22, 2010 | Kenwood KDC-MP5032 - Car Audio CD MP3...
The cd player stop working sometime like it has a shortage in cut on and off
good day, it may have a loose wires, try checking the in dash rear connections. hope this helps, have a nice day
Feb 08, 2010 | Car Audio Receivers
Battery went dead alpine cd stop working
Sometimes when you jump off a truck the CD player fuse will blow because it was trying to turn on each time you turned over the engine. Check all the fuses.
Mar 22, 2009 | Alpine CDA-7892 CD Player
Quit working
make sure your power cord is connected properly
Sep 28, 2008 | JVC KD-G230 CD Player
Xtreme sound wms303 cd player..... need a new one?
It sounds like if it only works a day or two and then you disconnect it and re-connect it, and it works again for a day or two, I don't think the problem is how you are connecting it. I think the radio needs to be reset every couple of days. If it has a reset button, just press that and it will at least keep you from disconnecting it and reconnecting it.
This also sounds like it has an internal electronic problem. When you disconnect the radio, it resets the microprocessor. You should have it checked out by a service center, or if you do not want to spend any money on this radio, just get a new one.
Jul 06, 2008 | Xtreme Sound WMS303 CD Player
No sound...
you have wires grounding out at the back of the unit. i suggest trying to completely rewire it and see how that works. its easy if youve never done an install so dont sweat it. email me if you have any questions.
May 13, 2008 | Panasonic CQ-C7301U CD Player
CD 's work fine - NO Am or FM
sounds like the aerial has fallen out the back.
Dec 12, 2007 | Sony CDX-FW700 CD Player
MP3 CD's
Sometime when put too many file in a cd then the scond half of the cd get corrupt. Try play that cd in another player see if it work. Certain unit could only read certain compressed size file too small and it would be view as corrupted.
Nov 12, 2007 | Alpine CDA-9856 CD Player
Cd's player wont work quite right
u need to manually clean the lens using cotton buds(no fluid or solution) extra care! hope this help u...
May 15, 2007 | Jensen MP5610 CD Player
Pioneer DEH-P680MP CD Player Logo
Top Pioneer Car Audio Receivers Experts
xxxxxx xxx
Are you a Pioneer Car Audio Receiver Expert? Answer questions, earn points and help others
