Question about iRiver H10 MP3 Player
System files missing
I turned on my computer and a message read "system files missing",. i went online to iriveramerica/support and i could not understand their directions. I tried to call their hotline on 3/12/2007, # 360-567-3599,I stayed on hold from 6:15pm until 8:00pm, nobody picked up.(FYI, after 8pm, the phone clicks off) I called today, 3/13/2007, at 11:30am(opens from 11am-8pm)I stayed on hold until 12:30pm, nobody picked up. This seems like a common problem but i do not understand the answers that were given. I am not computer literate AT ALL. (you can just imagine what I went through just downloading ONE song) Do you have a telephone number where i can call and speak to a representative that can walk me through the process step by step?
  • Anonymous May 08, 2008
    to restor the sistem files,connect H10 to iriver plus
  • Anonymous May 22, 2008
    the some problem goes with me
    i can't find a solution
    when i turn on my device "system files missing" shows with a red color
    when i conect it to my computer it does not work at all
    can u help knowing that i have no istallation CD nor nothing else that comes with it
    mail me on : nuriah-ino@hotmail.com
    thanx a lot
Hey I had the same problem and finally recieved an email from Iriver after 3 weeks. I was so frustrated about how long it took though. But anyway, i tried what they told me to do and it worked!! Here are the instructions. Good luck! The following steps will help you manually format your H10. Copy & paste the link into your browser.Choose SAVE, save it to your Desktop. Locate the file & unzip the file. (let it unzip to the location that has already been chosen ) http://www.iriveramerica.com/download/H10/H10v10FW.exe 1. With the player disconnected & powered off, pull out the battery, then replace the battery. 2. Connect the H10 to your computer. 3. Hold down the "O" button then press the power button. Keep holding it down until you see "UMS Connect V0.90" or "Emergency Connect" at the very top of the H10's screen & let Go. The player will then display USB connected. 4.Click Start / My Computer 5. Right Click on the player's Drive letter and select Format "Removable Disk" 6. Check "Quick Format", making sure the File system is set to "FAT32" and click "Start", then OK. 7. After formatting is complete, click OK, then click on Close. 8. Click Start / My Computer. In the section "Devices with Removable Storage", double click on "Removable Disk". You should now see no files or folders in here. This is your H10 window, minimize the Window. 9. Click on My Computer, Click on your C: Drive, Open the iRiver Folder, Open the H10 folder. Right Click on the System folder & choose Send to H10. 10. Once the file has finished copying, close the H10 Window & disconnect the player from computer.Let the H10 boot up (it may look like it locked up, give it a minute). On H10, go to Settings / Timer / Date/Time and set to current date and time. 11. Reconnect the player & re-download your files to the player. 12. Perform a Firmware upgrade to the Player. Directions for manually updating the firmware on your H10. Please make sure you have the player connected to the system. Download the MTP Updater Tool and .ZIP files (Zip files are near the bottom of the page) from http://www.iriveramerica.com/support/mtpupdate/ FOR THE 5GB or 6GB PLAYERS: A. With the player disconnected & powered off, pull out the battery, then replace the battery. B. Connect the H10 to your computer. C. Hold down the "O" button then press the power button. Keep holding it down until you see "UMS Connect V0.90" at the very top of the H10's screen & let Go. The player will then display USB connected. FOR THE 20GB PLAYERS: A. Use Paperclip (or something similar) to ?Reset? the H10 via the Reset button on top. B. Hold in the (0) key and then Press Power. Hold both buttons in until you see ?Emergency Connection? across the top. Player is now in UMS Mode. Run the MTP Update Utility 1. From the Main Screen, Click on Manual to proceed with the Manual Update. 2. From here you would click on the Open Button to find the .zip file you downloaded. 3. Find the .Zip file that you downloaded. Click once on the file to highlight it and then click on Open to proceed. 4. It will do a firmware check and tell you what firmware you have on the player, and what is going to be installed. Click Next to continue. 5. Once it has detected the Firmware Versions, you Click on Update (or Recovery if you want to format the player) to update to the latest version. 6. The upgrade will proceed. Please wait until the upgrade is done. 7. It shows complete message and upgraded firmware version.
Posted on Apr 04, 2007
Http://iriverinc.com/support/mtpupdate/
Im a mexican boy with the same problem. Here are the instructions step by step. I follow the instructions and have my iriver in optims conditions. JE Sorry for my badly english. Seguro Funciona jejeje
Posted on May 21, 2008
I will answer my own problem. (i intially sent this problem hoping to get an answer)if anyone has had the above problem, i have the answer. First,i called the 360-567-3599, their is an automated service that ask you what type of h10 device you own, DO NOT pick the device type,(example: if you have h10 5/6 gbs press number 3, etc.)Later, you will hear about estore questions, keep listening, when you get to the end, you will hear, "all other questions, press(i'm not sure what number, but push that number) a live representative will help you. Let him know that you tried everything and it still does not work, they will have you send it to them. i was soooooo pleased with my device when i received it. all my music is gone but that's ok, but have it backed on my windows media player so i just downloaded it again. P.S. make sure when you mail it, that you get insurance, return receipt, the works, to ensure that you receive it back in one piece. I think i will return it to them in the future if it stops working again.
Posted on Apr 05, 2007
  • 62 Answers
Try this and let me know if it works http://www.iriveramerica.com/support/hd/H10_upgrade.aspx
Posted on Mar 29, 2007
I have the same problem. I also tried to call that same number a few times and stayed on for about 45 minutes each time and there was no answer. Please let me know if you fixed your problem and how. Thanks!
I have Samsung P5S800 desktop computer- It gives a message to start manually.However, the same message repeats to start manually after pressing OK. Please help!.
May be some system files are missing or .dll files are missing so better to re-install the operating system.
Hope you Understand
Oct 11, 2012 | Samsung Computers & Internet
Acer Aspire One Netbook D260A.Windows XP not booting. Message Reads Windows could not start because the following file is missing or corrupt. Windows Root System 32 Hal dll No recovery disc or USB...
Sometimes you can get the needed .dll file online, and manually place it on that drive, of course in the correct directory.To do this, you need a functioning computer and you hook up the hard drive with the problem VIA USB. You can get USB Hard drive adapters from most retailers.
You may want to extract all data before you do anything, just in case. Have you been doing backups????
Usually, you reinstall the OS to resolve this issue, but without disks, not so easy to do.
Feb 03, 2011 | Computers & Internet
Error message says: missing file, aquatica.dat
This is a system files. These are basic file's in a window directory.Regarding aquatica.dat, it is a multimedia file component.
You can repair this by downloading .dat file from .dat database. You can easily search the file online and add it. If you purchase a software, it would cost you certain bucks. Better reinstall windows or restore.
Computer can be affected by the missing of these files. It depends on How many files are missing, configuration of the PC, Virus, Malisware, Adware etc.
The simple option - Restore or Reinstall, if not a tech.
Let me know,if need any further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 25, 2009 | Dell Computers & Internet
Error messages :system32\hal.dll missing or corrupt"
Looks like you might have to format your drive and reload windows from scratch,unless you can restore deleted files from your recycle bin
Apr 30, 2009 | Dell Microsoft Windows XP Home Edition
IRIVER H10 system files misssing
you can just go into the shop you bought it from or dicksmiths or something and they would sell the disc
as for your computer one just plug in your device then when you think it has loaded and everything go in to my computer and it should have your device there!
Oct 12, 2008 | iRiver H10 MP3 Player
SYSTEM FILES MISSING
I had same problem. On this website I read that problem is due to hard drive malfunction. I have solved my problem by doing the following. Actually a friend of mine told me he solved similar problem with his iPod this way.
1- Per indication on this website (fixya) I put device next to my ear at the time I turn ON and screaky sound was present. In my case I could hear that sound.
2- on a solid table I put a piece of cloth
3- removed batery from H10 and installed back ON (I think this is called reset)
4-put iriver h10 on my hand with screen towards my palm
5-turn device ON and immediately slap it against table (with piece of cloth in between) at third attempt device boot normally.
I figure, device was dead why not try this. In my case it worked.
Now I am trying to synch my music. sometimes it sync sometimes it reports error but music is there.
Oct 11, 2008 | iRiver H10 MP3 Player
Iriver H10 sistem files missing problem
just go to iriver.com iriveramerica is more of a store search, got to the iriver website find your device click on its page and then at the bottem it will have relevant updates as well a firmware recovery tool, if not just do a search on their website it is not a player specific tool
Mar 22, 2008 | iRiver H10 MP3 Player
6 gb version of H10 displaying error message on start up
you need to upgrade firmware to version 2.51 using the mtp upgrader download found at www.iriver.com-support-ask.asp after doing this your player should work this upgrade is a recovery tool and works very well with all mtp version players
Dec 30, 2007 | iRiver H10 MP3 Player
iRiver H10 MP3 Player Logo
332 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Peter Dragonetti
Shawn DuRee
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
