Question about Goodman GMS90703BXA Heater
I pruchase a new furnace the litght in blinking continueouly. can some one helps
Switch 110 volt wires ,reverse white and black wire and check ground
Posted on Dec 19, 2008
I have an Olsen furnace. It's not running and there is a red light blinking. What's wrong?
Count the blinks in between pauses. On the door of the furnace will be a legend that tells you what that number of blinks mean. For instance 3 blinks may mean open limit switch or pressure switch failed to close, something like that. Post here what it tells you then we can help.
Mar 23, 2015 | Heating & Cooling
HK42FZ034 status code light blinks in pattern
Located on the schematic on the inside of the furnace door should be a key for the blink sequence. 2 short blinks then 4 long ones would be a code 24 on that data plate
Apr 13, 2014 | Carrier Furnace Control Board Bryant...
My gibson furnace is about 8yrs old and it was working fine heat was on yesterday morning but last night it stopped. Changed batteries in thermostat which in new(thermostat) but no heat. Checked the vents...
Look on the back of the bottom cover... it should tell you what the blinking means...
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
Feb 03, 2011 | Gibson Heating & Cooling
My burner goes on but shuts off early and blows cold air. it is a goodman furnace. where should i start to solve this problem. i just had furnace cleaned and flame sensor cleaned. should i buy a new flame...
First when it goes out again, locate the furnace and look thru a small viewing port to see if there is a light blinking, count the number of blinks. Then look at the wiring diagram for a diagnostic code chart. This will give you a strart of where to look.
Oct 17, 2009 | Goodman Heating & Cooling
Glow light blinks once
One thing to try is to check the voltage coming to the furnace to see if it is correct. They do have separate furnaces for California because of the NOX compliable laws but the boards according to my vendor are all the same. Look on the new board to see if you see any of these numbers # PCBBF112S or 01030F00005S. If you do have one of these numbers it is the correct board. If not change the board or if voltage is wrong get that corrected and you should be fine
Jan 08, 2009 | Goodman GMS90703BXA Heater
Carrier Weathermaker won't stay running
Is this a gas furnace if so is it high efficient if so is there an led light on the furnace blinking a code usually seen through a window at the furnace. is the thermostat battery operated if so is it a new battery and are the aif filters new. These would be my first steps to check hope this helps
Dec 21, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Put new thermostat on but now furnace still doesnt run
Did you reset the furnace at breaker? If so what did it do? Did it give you a blinking led code? If so what does the code mean on your legend on furnace door?
Dec 05, 2008 | Heating & Cooling
Blinking symbol
Look for a reset selection on the thermostat. The Filter warning is probably programmed to come up on 90 day intervals.
Oct 20, 2008 | Honeywell Programmable Thermostat Heater
Goodman GMS90703BXA Heater Logo
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
