Question about Dell Latitude C400 Notebook
Administrative tools when i try to access admin.tools, the display says that the folder is empty. how do i fix without the password?
  • Kevin Nelson May 11, 2010
    What is your OS version?
    Guru:
  • Dell Master
  • 829 Answers
  • Start Regedit.exe and navigate to the following locations one by one:
HKEY_LOCAL_MACHINE \ SOFTWARE \ Microsoft \ Windows \ CurrentVersion \ Explorer \ User Shell Folders
-and-
HKEY_LOCAL_MACHINE \ SOFTWARE \ Microsoft \ Windows \ CurrentVersion \ Explorer \ Shell Folders
  • Delete the value named Common Administrative Tools (if present).
  • Close Regedit.exe and restart Windows.
See if the shortcuts in the Administrative Tools folder are restored. If not, see Solution 2 below.
Posted on Dec 22, 2008
How do a forgotten admin password on a xerox 7655
WorkCentre 7655 7665 7675 Online Support Solution Modify the Printer...
Solution : Modify the Printer's Administrator Password Using CentreWare Internet Services (CWIS) NOTE: This solution assumes the WorkCentre is configured and working properly on the network.
  1. From the computer, open an Internet browser window.
  2. Enter the IP address for the WorkCentre in theAddressfield, and then press [Enter] on the keyboard. The CentreWare Internet Services window will be displayed.
  3. Click on the [Properties] tab.
    NOTE:If the Login screen is displayed, enter the user name in theUser IDfield, and the password in thePasswordfield, and then click on the [Login] button.
    The default username is "admin" (case sensitive), and the default password is "1111". If it has been changed or forgotten, contact Support.
  4. Click on [Security] to expand the list of options.
  5. Select [Authentication Configuration].
  6. Click on the [Modify] button for Device System Administrator Password.
  7. Enter a new password in theNew Passwordfield.
  8. Retype the password in theRetype Passwordfield.
  9. Click on [Save]. This will be the new password to log into the Control Panel and CWIS.
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=143,E=0000000004704152929,K=9646,Sxi=4,Case=obj(3814)
Solution : Modify the Default Admin (Tools Mode) Password on the WorkCentre NOTE:The Admin (Tools Mode) password allows access to configure network and machine settings on the printer.Xerox recommends only changing the default Admin (Tools Mode) password if absolutely necessary. If the password has been changed from the default password (1111) and has been forgotten, a service call is required to reset the password.
To change the default Admin (Tools Mode) password:
  1. Press the [Log In / Out] button on the Control Panel. The Log In window will be displayed. See theRelated Itemsbelow for additional information regarding logging into the WorkCentre.
  2. Select [Security Settings] on the left side of the screen.
  3. Select [Authentication] from theGroupscolumn and then select [User / Administrator Accounts] from theFeaturescolumn. The User Administrator screen will be displayed.
  4. Select the [Account #] field, and then select account number 1 using the keypad on the Control Panel.
  5. Select the [Configure Account] button. The Configure User Accounts screen will be displayed.
  6. Press the [Clear C] button (several times, as required) on the Control Panel to clear the old password.
  7. Enter the new password using the keypad on the Control Panel.
  8. If necessary, place a check mark in the [System Administrator (Admin)] and [Account Administrator] check boxes, and then select [Save Account].
  9. Select [Close].
  10. Press the [Log In / Out] button on the Control Panel.
  11. Select [Logout] on the Touch Screen.
Apr 04, 2014 | Xerox WorkCentre M-24 Color Copier
Tip
How to Reset Windows Vista Administrator Password With Three Simple Methods?
Have you ever experienced Windows Vista administrator password forgot? Absolutely, there is nothing worse than forgot your Windows admin password when you have a great deal of work to do on your PC. Even though you can enter your computer with a standard user account, you still could not download anything and install programs on your PC. Therefore, how to reset or recover Windows Vista administrator password efficiently?
Here we will show the top three easy and efficient Windows Vista admin password recovery methods to anyone who have Windows Vista admin password forgotten issues.
Method 1: Reset Windows Vista administrator password on safe mode
Preparation Time: about 10 minutes
Pros: Simple and do not need third party tools
Cons: Need an available admin account on your Vista PC
You can reset Vista administrator password on command prompt with an available admin account to enter safe mode first. If you have another Windows Vista admin account, try these steps below:
Step 1: Press F8 when your Windows Vista PC is booting. You will come to the Advanced Boot Options. Then choose Safe Mode with Command Prompt and press Enter.
Step 2: Enter safe mode with an available admin account.
Step 3: Type "net user" and press Enter. The command prompt will show you all accounts on the Windows Vista PC.
Step 4: Type "net user Paul 123" (Paul is the locked admin account's name and 123 is the new password) and press Enter. Now you have successfully created a new password on the locked admin account.
Step 5: Type "shutdown -r -t 00" and press Enter.
Your Windows Vista PC should be rebooted automatically and then you can logon Windows Vista with the new password.
Method 2: Recover Windows Vista administrator password with freeware
Preparation Time: More than 30 minutes
Pros: Free and do not need to change the forgotten password
Cons: The freeware should not work if the password is too long
Ophcrack is freeware for Windows password recovery. This software can help you to recover your forgotten Windows Vista admin password. So that you can regain access your admin account without changing the password.
Ophcrack is used to create a Windows password recovery disk. You need to boot your computer from the disk to recover your password. You can follow these easy steps:
Step 1: Download Ophcrack
Step 2: Burn a Windows password recovery disk with the freeware
Step 3: Recover the forgotten Windows Vista admin password with the disk
You can logon Windows Vista with the old password now.
Method 3: Reset Windows Vista administrator password with shareware
Preparation Time: less than 10 minutes
Pros: Fast and 100% reset the forgotten password
Cons: Not free
Windows Password Recovery Tool 3.0 is easy-to-use shareware to reset forgotten Windows password, including administrator password and other standard users' passwords.
Unlike Ophcrack, Windows Password Recovery Tool is designed to reset the forgotten password. No matter how long and how complicated the password is, this software can 100% reset the forgotten password in few minutes. All you need to do is just three steps:
Step 1: Download Windows Password Recovery Tool
Step 2: Burn a Windows password reset disk with the shareware
Step 3: Reset the forgotten Windows Vista admin password with the disk.
These three Windows Vista administrator password recovery solutions are helpful for us to resolve the Vista admin password lost problem. Now, you are no more Vista admin password forgot matters.
This article is free for republishing
on Jul 12, 2010 | Computers & Internet
How to hack admin password from guest in xp?
Nope. Must be an admin.
Lost Windows password:
  • Login as Administrator. Try with no password (load safe mode if you don't see Administrator). Press F8 during boot to access Safe Mode.
  • Login as other user (if other user is available) and manage users. Must be an administrator.
  • Reformat computer.
  • Use 3rd party software to remove password. Like http://www.top-password.com/reset-windows-password.html
There is a free boot CD called Hirens.
Oct 09, 2012 | Microsoft Windows XP Home Edition English...
HOW TO FIND THE ADMINISTRATOR PASSWORD?
You can use a famous laptop password recovery tool--Windows Password Rescuer.
And I I highly recommend [Daos Password Recovery Bundle 2012]. [Daos Password Recovery Bundle 2012] is an all-in-one password recovery software, which recover password for Windows, Excel, Word, Access, PowerPoint, Outlook, RAR/WinRAR, ZIP/WinZIP, PDF etc. Over 70+ types of passwords can be recovered instantly.
Aug 13, 2010 | Acer Computers & Internet
What the lg default administrator password on a XP based notebook?
Xp based notebooks if the administrator account has never been accessed before the password for the account will be blank there will be no password set so type in administrator and leave password blank giving the administrator account is enabled if some one has accessed the account and set a password then you will basicly have to get a password hash hack for windows so you can reset the admin account just let me know if you can't acces the admin account and ill give you the info you need to get the program ...
Nov 08, 2009 | LG X-Note LM50 Notebook
Access to admin account
ok at the login screen when u enter u r password just type username as administrator and enter but still u should put the admin password or else try without a password
Jul 29, 2008 | Microsoft Windows XP Professional With...
I forgot my Administrator Password
When I forgot my XP administrator password, Windows Password Recovery Tool 3.0 will help us reset password efficiently by creating a password reset disk!
May 09, 2008 | Computers & Internet
Forgot administrator's password
Hi Reggie,
Please read the entire article before proceeding:
All administrator accounts are created equal, with equal
powers, except that the main adiminstrator account cannot
be deleted and it does not appear on the login (or users)
menu by default.
You do need an alternate administrator account to solve this
problem. You must login to a user account with administrative
privileges in order to access system resources, take ownership
of files and folders, and to change other people's passwords.
(including the built-in administrator account)
Otherwise, what would be the point of any security at all,
if you could bypass it at will.
If you can login to another account with administrator pri'vs,
then follow me. Otherwise you may have to pursue more difficult
options, as explained later.
1) Open up the control panel
2) Open up Administrative tools
3) Open up local security settings
4) Expand Local policies in the LHS folder tree
Check:
Accounts: Administrator Account Status = Enabled
Accounts: Rename Administrator Account = Administrator
this is to make sure that the admin account is enabled,
and has not been renamed. You can double click on these
settings to change them. Is you are for some reason unable
to enable the admin account, you must reboot to safe mode,
where the admin account is always enabled.
Now that you are sure that you have a functioning administrator
account, you must reset the password, since you cannot
retrieve it:
From the control panel, once again open up
Administrative Tools ---->
Computer Management --->
Local users and Groups ---->
Users ----->
Administrator ---->
Right click on administrator ---->
SET PASSWORD
This should do it.
N.B.
The administrator account will be re-created, you will loose
1) All settings and preferences
2) Access to any NTFS encrypted files the administrator
has encrypted.
3) Stored network and internet passwords (the administrator's)
4) Personal security certificates.
This procedure is different from simply changing the password,
because you don't know the original, so Windows treats it as a
hostile takeover, That's why you loose access to encrypted files.
If you have trouble starting the computer management Applet,
Run it manually:
START --> RUN --> compmgmt.msc
or
...\WINDOWS\system32\mmc.exe compmgmt.msc
Trick:
If you do not have access to an existing account
with administrative privileges, you may be able to hack in
with and old setup disk from Windows 2000, with
no service packs, or at most XP1
The reason is that Windows 2000 did not anticipate nor
respect Windows XP security.
1) Reboot from the 2000 disk, and follow the on screen
prompts to repair the system using the
SYSTEM RECOVERY CONSOLE.
2) Do not proceed to install Win 2000, make sure you
get out before it asks you to format a disk, if you get
there you missed the prompt and you have gone too far,
Reboot and try again.
3) Once you are in the recovery console = DOS like environment
type HELP, and it will give you a list of commands.
You should be able to create a new user account
(with admin or change the admin password privs)
4) The last alternative is to purchase an XP password recovery
utility, which you run from a boot CD.
Good luck
Martin.
Apr 23, 2008 | Microsoft Windows XP Professional With...
Dell Latitude C400 Notebook Logo
79 people viewed this question
Alun Cox
