Question about Cell Phones
Pairing Bluetooth How did you get your M300 to pair, because I have the same phone, and obviously, the same problem. Any suggestions?
I'm not sure but when M300 trying to pair, I think I have pressed the talk button on the bluetooth headset. Remember also that was about 20th tries before pairing succesfully.
Posted on Dec 14, 2008
Sm-g31or5 want to pair with my 07 toyota solara convertible. phone says paired, but not car
Just had to pair for a friend few days ago, Toyou press setupota will pair to audio, but not hands free talk. Not sure exactly what buttons to push on your particular, so I would suggest read your car manual for "Hands Free Bluetooth" Pairing, not just audio pairing. On Toyota that I paired, after you press setup Bluetooth you will have to press "Phone Off" button on your steering wheel to get into hands free pairing, but check your manual to be sure.
Apr 09, 2015 | Samsung Cell Phones
I cannot pair the SPH-M300 phone with my laptop using the PIN code 0000, how do I establish the PIN code of the handset?
When you turn the bluetooth on and try to pair the laptop and the phone, the phone should automatically ask you for a passcode. You could try pairing the other way around, instead.
Jul 06, 2011 | Samsung SPH-M300 Cellular Phone
I am trying to pair a bluetooth em227 to a samsung sph-m300 but it asks for a input pin? I have tried 0000,000000,1234,123456,9999,999999,1111,111111,and my phone number...not sure what else to do?
You must put you headset in pairing mode, prior to trying to pair it with your phone. In order to do it, starting with it turned off, press and hold the power button for some 10 seconds, until the indicator light is alternately flashing in red and blue. It is in pairing mode now. Then, bring your phone close to it, and make its bluetooth application search for new devices. After a little while, your headset should appear on-screen. Select it and make it connect. If a pairing code (or passkey, or PIN) is requested, enter '0000' (four zeros). If the pairing process is successful, your headset should enter the stand-by mode (blue light flashing every few seconds). By the way, If its user guide happens to be missing, or, rather, you need further informations on how to pair it with your phone, feel free to download it from this location.
Regards,
Carlos
Dec 23, 2010 | Samsung SPH-M300 Cellular Phone
How do i pair up mu htc hd2 with htc bh m300 as i bought new one its not been showing in my device
ok you hold the power key 40 second and you see the power light is stable now you find the device from your phone when you able to find the device you are able to pair the device using 0000 pair key.
Oct 08, 2010 | HTC BH M300 Bluetooth Mono Headset (UK...
I just bought a samsung soltice phone and I have a scala-600 bluetooth but I cant seem to get them to connect have any suggestions and I have used a bluetooth befor.
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Sep 12, 2010 | Cell Phones
I have a motorola bluetooth without the pairing code. Also I can not tell by looking at it what model it is ...it just says Motorola. it was my fathers and he can not find the book. Help I need it for work...
Bluetooth headsets have their pairing code hardcoded by their manufacturers. Most of them, choose '0000' (four zeros). Others choose '1234', whilst some of them use '8888'.
A bluetooth headset must be put in pairing mode, prior to its first connection to a bluetooth enabled device (e.g. phone, PC). All of them must be turned off before starting the pairing procedure. Some motorola headsets have a boom, which must be opened, in order for it to enter the pairing mode, whilst other headstets must have their Multi Function Button (MFB, or Call/End button) pressed and held for some 6 to 10 seconds. Their LED light use to indicate their pairing mode. Some of them flash rapidly (sometimes in more than one color), whilst others keep it solidly lit. Anyway, once your headset is in pairing mode, make your phone (or PC)'s bluetooth application search for new devices. After a while, your headset should appear on the device' screen. Select it and make the application connect. If a passkey (or PIN, or pairing code) is requested one of the codes I've suggested above.
The pairing procedure, between any two bluetooth enabled devices, should be done only once. All subsequent connections should be achieved by bring both devices, with their bluetooth radio turned on, close enough to each other. If their link is not automatically established, a simple press on the headset's MFB should be enough.
Hope you are able to pair your headset soon.
Regards, Carlos
Jun 02, 2010 | Motorola Mobility Bluetooth Hands Free...
My phone won't turn on
the problem is obviously not from the battery. There is something work with the phone.
Maybe you go ahead and get a new phone and if luckily the phone comes up later, you can dispose it off.
Take care.
Mar 08, 2010 | Samsung SPH-M300 Cellular Phone
I have my second motorola H700 headset paired to a samsung m300 phone. The problem is with my first headset after the pairing of the two, any time the headset was closed the bluetooth icon would go black...
Some phones allow you to set the options for the device in the bluetooth menu for each device. These options include auto authorize which is what you would be looking for to enable for your new headset to auto connect. I'm looking at the Samsung m300 user guide, but it doesn't mention this option, however it may be in the menu as an option when you select the device under the bluetooth menu.
Feb 24, 2010 | Motorola Mobility H700 Wireless Headset
Lg 8700 can not get to pair with any blue toogh device ,my phone has no other devices added
You Need To Type In A 4 Digit PassCode To Get Through To Another BlueTooth Device. Pairing Bluetooth Phones Is Kind Of Complicated. If You Are Pairing 2 Phones... Here Are The Steps:
1.) Find The Other Phone By Searching For It On BlueTooth
2.) Select The Device/Phone You Want To Pair With
3.) Enter The Last 4 Digits Of The Phone Your Trying To Pair With's Phone Number
4.) The Other Phone Should Be Asked If It Wants To Pair With Your Phone, Say Yes
5.) Type In The Last 4 Digits Again Of The Phone Your Trying To Pair With's Phone Number, Except This Time ON The Phone You Are Trying To Pair With
6.) You Should Get A Paired Successful
Pairing With Any Other BlueTooth Enabled Device:
1.) Search Through BlueTooth For The BlueTooth Enabled Device You Want To Pair To
2.) Select The Device You Want To Pair With
3.) Read The Instruction Manual That Came With The BlueTooth Device You Are Trying To Pair With, You Should Find A Pair Key In There Somewhere
4.) Enter The Passkey You Found (OR Already Know) And You Should Be Ready To Go
If All Else Fails, The BlueTooth Is Obviously Broken On Your Phone... Exchange It For A New One
Jan 30, 2010 | LG VX-8700 Cellular Phone
Trying to pair bluetooth SPH M300 to my Blackberry Curve 8900 and it is asking for a pass key??? Help!!!
ALL YOU HAVE TO DO IS USE THE INPUT CODE 1234 UNLESS YOU HAVE CHANGED YOUR CODE....BUT YOU CANT DO THAT ON MANY PHONES
Jan 22, 2010 | Samsung SPH-M300 Cellular Phone
Cell Phones Logo
228 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
