Question about Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1
I have a Hayward H series spa/pool heater. It will not light.
I have not used the heater for over 6 months. The mode lights work correctly. It is on Standby as it should be. I selected SPA and set the temp for higher. The mode light flashed green but the heater did not light. Then a fault code of 1 F appeared. The same sequence of events occurred in the Pool mode. Should I have the tank filled and the system bled before I call for maintenance? Or do you have any other suggestions? Thanks, Phil Ragan
  • Anonymous Dec 30, 2008
    same problem here to
  • ifixpools May 11, 2010
    1F or IF???
  • 11 Answers
IF stands for ignition failure, one possible cause is that the two sparker prongs are not spaced properly, i have seen this before several times. The correct distance for them to be spaced apart is the width of two quarters side by side... not like this....OO, the other way so the are flat. To access that you have to take out the heat exchanger, which requires unhooking high limit switches in the back, unhooking the pressure switch, thermostat wire, and plumbing...just remember where everything goes. Before you do that though check this simple thing...there are a number of brass orifices that shout gas to the burners, use a 7/16 wrench to take off the one that is to the extreme left, which is on the igniter side of the heater, inspect the orifice to see if there is blockage, like a spider web or something. If it is blocked, clean it out and also look down the burner itself to see if it is free of blockage. And because we all make simple mistakes.......make sure the gas is on.
Posted on Jan 08, 2009
New Hayward Heater H series 400 BTU won`t light error IF
check gas pressure again meter could be too small if furnace goes on while heater is on it will run out of gas and turn off giving you that error
May 13, 2012 | Hayward H Series Pool & Spa Heater 400k...
Bd code
check ignitor and flame sensor
Jan 25, 2012 | Hayward H Series Pool & Spa Heater 400k...
Pool heater won't light
it is possible to light a pool heater with an ignition device,however it is not advisable.since your unit is calling for heat and the gas valve is opening,i suspect you have a faulty ignitor
Jul 21, 2009 | Hayward H Series Pool & Spa Heater 400k...
Hayward 150 Pool Heater- cannot get lit
Your pilot head is probably clogged with spiders. Disassemble and clean it out and it should start working.
Jun 03, 2009 | Hayward 150k Lp H Series Spa & Pool Heater...
Trouble shooting Hayward pool furnace
Big enough propane tank? proper pressure reducing valve on the propane? Check both of those.
May 30, 2009 | Hayward H Series Pool & Spa Heater 400k...
My Hayward 400 has no lights on the panel, no codes or modes
When cycling through the modes you have pool, spa and standby and a service light. When in pool mode watch for an IF reading the main cause of problems is a corroded bad thermistor found in the inlet/outlet header closest to inlet pipehas two smaller wires on it and unthreads out to replace
May 26, 2009 | Hayward H - Series 400 Heater Top for In -...
Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1 Logo
367 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
Craig Butler
Craig Butler
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
