Question about Zanussi ZBS963X Electric Single Oven
Door Does anyone know how to take the door off the Zanussi ZBS 963X? (obviously without taking a sledge hammer to it)
    President:
  • 1,462 Answers
There are various ways of doing it but essentially you have to lock the hinges before removing door. sometimes a little arm which flips up or a circular slotted plate on the door
Posted on Mar 20, 2007
Will Details about Zanussi ZCG7901XN Cooker Top Oven Glass Door fit my ZCM7901XN oven?
I think yes, because spare part number 311407328/5 of outer glass door is the same for both oven.
Dado
Mar 03, 2015 | Zanussi Ovens
Oven door locked
put back in clean then cancle
May 25, 2010 | Zanussi ZBF360X Electric Single Oven
How do I replace the inner door of my zanussi ZBQ365X oven?
open the oven door and there are screws around the perimeter of the inner door cover remove these the seal then replace the glass and reverse the procedure make sure the heat seal gets put back right for the heat shield
Apr 30, 2010 | Zanussi ZBQ365 Electric Single Oven
The inner glass door on my zanussi oven has come
You should be able to repair your existing door. Have a look around the perimeter of the door to see if there are any screws, particularly near the handle. You are looking to take the front fascia off the door, so that you can access the inside. Most doors have the front fascia held on by small brackets glued to the back of the glass that clip on to a fixing on the internal door. The top of the fascia is normally held in place by the handle. Once you have the front of the door off you can retrieve the piece of glass that has fallen out. You will almost certainly find that the glass has come away from the adhesive that was used to hold it in place. You will need to clean up the glass and the metal door and re-stick the glass using a high temperature oven door glue
Jan 31, 2010 | Zanussi ZBF360X Electric Single Oven
How to fix iner seal on the oven door
I have a Zanussi ZDF290X which requires a new top oven seal. I have pulled the remainns of the old one out, but without dismantling the oven it seems impossible to fit the new seal. Any easy way of fixing this, please?
Jan 13, 2010 | Zanussi Ovens
Loose oven door handle on kitchenaid gas range
youl have to take apart the door.the screws are on the other side of the glass/framing
Dec 31, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Purchase of new part
Try 3wire.com or northernparts.com
Aug 26, 2008 | Zanussi Ovens
Oven door
You will need to replace the oven door.
Take the old door out by taking out the 2 to 3 screws on the side of the door. from there you will need to pull the door up and out torwards you. install the new door the same way.
Aug 14, 2008 | Zanussi ZBQ365 Electric Single Oven
Zbs 1063 - POBERR 80
Take note of the error code(POBERR 80) and contact an authorised
Service Centre.
Nov 24, 2007 | Zanussi ZBS963X Electric Single Oven
ZBS 1063 displayng
You have activated in some way the "child protection" function.
Please, check on the instruction book how to deactivate it .
Nov 17, 2007 | Zanussi ZBS963X Electric Single Oven
Zanussi ZBS963X Electric Single Oven Logo
177 people viewed this question
Top Zanussi Ovens Experts
John Tripp
John Tripp
gunfai
Level 1 Expert
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
