Question about Whirlpool Kitchen Ranges
My rf367 range gets so hot during the self cleaning cycle that the top of the range is to hot to touch and the fan on my otr microwave comes on.
    President:
  • 2,692 Answers
Normal operation. If in doubt place a high temp theromoter on range top to see if it exceeds 600-900 degrees
The basic idea is "burn baby, burn!" Self-cleaning ovens use an approximately 900 degrees Fahrenheit (482 degrees Celsius) temperature cycle to burn off spills leftover from baking, without the use of any chemicals. A self-cleaning oven is designed with a mechanical interlock (patented in 1982) to keep the oven door locked and closed during and soon after the high-temperature cleaning cycle, which can be approximately three hours. The door stays locked to prevent burn injuries. You can open the oven door after the oven cools to approximately 600 F (315 C).
Posted on Dec 14, 2008
Brand new otr microwave won't heat and carousel won't turn. Control panel does work and its not in demo mode. No buzzing or noise coming from it other than the recirc fan out the top. Advice?
cabinet out of alignment , if this is over the range adjust the way you have hung it, the pawls on the door are not contacting the switch in the unit
Nov 20, 2015 | In Microwave Ovens
Stopped during self clean--already replaced thermal fuse---it appears cooling fan was never connected, and it does not work once connected. All other functions appear to work, except power to the fan
Is the control panel completely dead?? If the cooling fan under the cooktop was not working, in most cases the main control board or control transformer if it is separate will get heat damaged and need replaced. That cooling fan is there to keep everything from over heating mainly during clean but should come on during normal baking if it gets too hot under the cooktop.
Apr 30, 2015 | KitchenAid KESS908SPS Electric Kitchen...
OTR Samsung Microwave fan comes on with no reason. Any way to fix it?
Does this happen while you are cooking on the range burners under the control panel?? These type microwaves have a heat sensor built into them in the area of the control panel bottom. If the microwave control gets too hot from cooking on the stove below it the heat sensor will turn the fan on to keep the control panel from getting heat damage. The fan should go off after everything cools off.
Apr 13, 2015 | Samsung 1.8 Cu. Ft. Over-the-Range...
Spontaneously stops working and then comes on after 5 minutes. Why?
Sounds like the magnetron is overheating. There is an automatically-resetable thermal circuit breaker attached to the magnetron. Most likely your problem is caused by either a cooling fan that is not running, or is running too slow (caused by gummed-up bearings). In some over-the-range (OTR) microwave ovens, the exhaust fan is run at a slow speed to cool the magnetron, and if it's bearings get gummed up, it won't run on the slow speed. But if it's a new OTR microwave, then the exhaust fan may be pointing the wrong way. (It is rotatable, depending on the installation). For example, if it is pointing up, but you don't have an exhaust vent over the microwave, then the air has nowhere to go, and the magnetron will overheat.
Oct 16, 2014 | Microwave Ovens
What may cause the oven overheating during self clean
well last time I checked the self clean went to around 600 degrees . has to to burn off the stuff burnt on inside . and YES outside gets really hot .
Aug 28, 2014 | General Electric Ge Stove / Oven / Range...
I have a GE microwave and just ran the self cleaning option on my gas range. During the cleaning process the microwave fan turned on low and now that the range is finished cleaning the fan will not shut...
The fan has a safety thermostat which turns the fan on if the area under the microwave get too hot. It turns off after it has cooled, providing you have not manually switched the fan on.
Jan 01, 2011 | Kitchen Ranges
Can I use the stovetop when my oven is self cleaning?
Yes you should be able to but there are a couple things to consider. When the oven is in the self-cleaning cycle the heating element reaches a very high tempature and runs for extended periods. So if you have a couple top burners going the amperage draw could possibly trip the electrical breaker. Also there is a lot of heat generated around the range during the cleaning cycle and it may be to hot to actually work around the range. There are some ranges that dis-able the top burners during the self-clean cycle. If that is the case with your range then the answer would be no. The way you would know for sure is to try them during the self-cleaning cycle or consult your owners manual.
Apr 10, 2010 | Maytag MER5770 Electric Kitchen Range
Will an over the range microwave exhaust fan start automatically If the range cook top gets too hot.
NOT THAT I'M AWARE OF . YOUR UNIT SHOULD HAVE A SWITCH TO TURN ON AND MUST BE TURNED ON MANUALLY
Oct 12, 2009 | KitchenAid KHHS179L Convection/Microwave...
Samsung otr microwave vent problem
Please call Samsung's Service Division at 800-932-3837.
If they cannot help you, they should be able to give you another number to call.
Oct 23, 2008 | Samsung 1.8 Cu. Ft. Over-the-Range...
Ewave otr microwave
Some microwaves have a sensor built in so if the oven gets to hot the fan will come on to help cool it down. It should shut off when it senses it is cooled down to the proper temp. If it will not shut off the sensor may be defective. Its your choice to either call a service tech to repair it or just replace it. I would weigh the cost of the repair to a new unit.
Jul 11, 2007 | DCS Island Hood
Kitchen Ranges Logo
161 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
