Question about Amana NAV5800A Top Load Washer
Washer starts, runs a few seconds and stops,does it over and over
Washer will start, runs a few seconds, then stops. After several minutes it will do this again and again until end of cycle. Doesn't matter which cycle you put it on. Doesn't matter what size of load. Doesn't matter what water temp. Takes 24 hrs to go thru a full reg. cycle.
    President:
  • 2,692 Answers
Sound like the internal overload on the motor may be going out .Thsi is usuaklly due to bad or worn bearings. If you know anything abotu electricity,take a voltage reading at the motor whe it is in the run cycle(when it stops) If you stil have have the 110Volts to the motor then the motor is bad and need to be replaced.If you do not then you wil have to look elsewhere for the problem.
Posted on Dec 14, 2008
Washer started and then stops mid cycle
Try unplugging it for a minute and plug back in, that should reset it.
Jan 09, 2018 | Maytag Neptune Washer
2003 Jetta starts for a second and dies after turning off car after drivena few miles
have your alternator checked,it may not be working and is not charging your battery,thats why it dies so fast and won't start again.
Dec 18, 2013 | 2003 Volkswagen Jetta - Sedan, 1.8T -...
Where is the idle located on a 1994 Jeep Grand Cherokee limited
It sounds like you do have a relay problem try switching relays around that have the same part number start with the starter relay when switching the make sure the key is off each time
Sep 04, 2012 | 1994 Jeep Grand Cherokee
I just replaced one of the suspension springs in our Kenmore 417 frontload washer. When I turned the washer back on and tried to run a load, it will run for about 5 seconds then stop for about a minute...
can you give me some explanation on what you did to replace the spring?. did you have to take the washer apart?. check the wire. maybe you forgot or did not plug all the way a connector. or came apart. my impression is that something came loose and the computer is not detecting a connection.
Feb 09, 2011 | Kenmore 44042 Front Load Washer
Maytag Neptune dryer beeps a lot and does not run.
what is the model number,sounds like you have a bad computer board but the problem is alot of parts for the neptune are no longer available
Sep 16, 2017 | Maytag Dryers
My Duet washer starts and runs for few seconds, then stops.
unplug machine take small panel off on bottom front of your washer, there should be a twist knob on pump, unscrew this (bearing in mind water will come out) you will find a strainer that catches debris before going through pump, clean out debris and re-intall. plug machine back in and try again.
Jun 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Dryer stops running
Sounds like a thermal breakdown in the motor.
Jan 11, 2008 | Maytag LSE7806A Top Load Stacked...
Amana NAV5800A Top Load Washer Logo
284 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
