Question about Webroot Spy Sweeper (spysweeper) for PC
My cd rom wont read the cd to reinstall my software
    Problem Solver:
  • 11 Answers
Will it read any cd's at all? If not then most likely the lens is dusty/dirty which is even more common if it has been smoked around or if the lens has been touched. If on a laptop then all you need to do is get a cotten swab lightly moistened with rubbing alcohol & clean the lens. If this is an internel cd drive on a pc you might want to try opening the drive & cleaning the lens & applying a little 3 in 1 oil to the rails the lens moves along. "Has worked for me many many times on lots of drives" If your not comfortable doing this than you may just want to replace the drive as they are fairly cheap on http://www.newegg.com but if the drives bad it wouldn't hurt to at least try fixing it.
Hope this helps,
-Bryan
Posted on Dec 14, 2008
Cd rom does not run cd
Does your OS detect the drive ? Does it read DVDs or nothing at all ? try removing it and reinstalling it or use an external USB CD-ROM drive in the meantime.
Nov 20, 2012 | Computers & Internet
DVD RAM change to CD Rom when i inset a disc
Check your computer drivers for that drive. It may be a driver error. It has happened to me before and I fixed it by reinstalling the drivers. It should be a software issue if you can still read CD disks.
May 16, 2012 | Computers & Internet
Computer is not reading the installation disk
By installation Disk do you mean the CD/DVD-ROM? If yes
Check to see if the drive's LED flashes when the system is trying to boot. If it doesn't, open the system and make sure all the cables to the CD/DVD- ROM is properly connected and to the right slots. If the cables are properly connect and the CD/DVD- ROM is still not working replace the CD/DVD-ROM.
However, if its that the system could not install a particular program, make sure the installation files are complete and try again. If its a downloaded program, verify the completeness of the file downloaded and try reinstalling the program.
Feb 13, 2012 | Peachtree Software Computers & Internet
My pc wont read any cd
Most likely your CD-Rom either needs to be cleaned or replaced. Try running a regular CD player cleaning disc in the ROM. If this doesn't get it working correctly, then you will have to replace the CD-ROM or buy an external ROM that hooks up with a USB cable.
May 16, 2010 | PC Chips M810DLU (M810DLUV75C) Motherboard
CD-Rom not reading cd's
it sounds like the cd rom driver in windows is not installed correctly try reinstalling the cd rom if that does not work the cd rom needs replaced
Sep 02, 2009 | Dell Dimension 4500S PC Desktop
DVD CD ROM
yellow triangle means conflict error try updating the driver or you may have to reinstall the device
Apr 03, 2009 | NEC CDR-84 (CDR-84-1) CD-ROM Drive
Hello my name is Jodi Butler and I bought an Acer M1100 sometime in June 2008. My CD / DVD ROM has quit working. When I run a test on it the computer tells me the device is working properly, but it wont...
ok, have you tried reinstalling the drivers for your CD/DVD ROM? After reinstalling reboot the system if this doesn't work chances are it could be a hardware problem.
Hope this helps:)
Oct 20, 2008 | Computers & Internet
CD rom can't read CD XP
yes i think the cd rom is the problem ,use external cd drive for the re installation or you can use a flash disc
Jul 12, 2008 | Acer Aspire 4315 Notebook
DVD rom drive
It sounds like the drive itself is faulty. Since you've reformatted, it obviously isn't a software problem. CDs and DVDs are read by two different lasers so its not uncommon for one disc not to be read yet the other is just fine which seems to be the case. A new one can be purchased for under $40. http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010100005+1036508690&name=Slim+Combo+Drive
Jun 23, 2007 | Toshiba Satellite A135 Notebook
Webroot Spy Sweeper (spysweeper) for PC Logo
61 people viewed this question
Top Webroot Computers & Internet Experts
Coss
Mike
Are you a Webroot Computer and Internet Expert? Answer questions, earn points and help others
