Question about Canon PowerShot A530 Digital Camera
Picture Dimension Hello. I am having trouble changing the dimension of the pictures my Canon PowerShot A530 is taking. It is set at a massive 2592 x 1944 and the files are massive. I currently have to use an outside program to shrink the dimensions, but when I'm downloading 50+ pictures off the camera at a time, that's quite tedious. I know there must be a way to change the ratio in the camera, but I can't find it. Any guidance would be greatly appreciated! Regards, Stacey
    Scholar:
  • 135 Answers
You can find this answer on page 31 of your owner's manual. You can download a copy of the manual from www.canon.com. I have attached a copy of the relevent page. The resolution choices are: L: 2592 x 1944 M1: 2048 x 1536 M2: 1600 x 1200 S: 640 x 480 Postcard: 1600 x 1200 Widescreen: 2592 x 1456
Posted on Mar 13, 2007
How do i get the camera to take a picture by itself
You just need to activate it's self timer feature. It will automatically take a picture after approximately 10 seconds. It can be set using custom setting.
Nov 27, 2009 | Canon PowerShot A530 Digital Camera
How do I take a picture with the date and time stamp in the picture
The date stamp only works in "Postcard" resolution. Press the "Func Set" button, then scroll down to the bottom to select postcard resolution.
Then press the menu button. Select the "Camera" menu, then scroll down to the the Date Time Stamp selection to turn it on.
Nov 05, 2009 | Canon PowerShot A530 Digital Camera
I put new batteries in and when I take a movie or picture it says change batteries.
Some of The Canon Powershot A530 and A540 cameras are subject to an advisory recall. Seems that a small spring on the battery compartment door can short out the batteries. Suspect this of yours, in that you mention that your batteries aren't lasting long. If your camera is on the list, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Aug 10, 2009 | Canon PowerShot A530 Digital Camera
A little hand with a no sogn through it and the word busy
The busy sign generally comes when:
Image is being recorded to the memory card, or playback mode is starting up.
It possible your memory card is full, please therefore down load your pictures and try again after erasing and reformating the memory card..
Alternatvely, please also reset all the camera ands menu settings to default.
Hope it works for you.
Mar 02, 2009 | Canon PowerShot A530 Digital Camera
Canon PowerShot SD1100 IS Digital Elph
there are some settings that can help with this (check out red eye and flash settings). The best solution I have found is to press the button down half way. The view finder will try to frame the picture, and then press the button all the way down. This 1) Eliminates Red Eye 2) Increases picture speed 3) allows for the "perfect" moment because you can leave it at half pressed for as long as you like, and 4) Allows you to take rapid fire pictures if you don't depress all the way.
Hope that helps
Oct 24, 2008 | Canon PowerShot SD1000 Digital Camera
Problems after repairing a Lens-error (E18) on a PowerShot A530
I think that the lens system is in different groups, which move independently based on a cam system. (This is based on watching the lens move while running the zoom lever.) I would suspect that your "cam timing" is not set quite right. You can either try to correct it by trial-and-error, making only small changes at a time, or send it in for factory calibration.
Aug 27, 2008 | Canon PowerShot A530 Digital Camera
Canon A530
The only way I know to help you is to suggest a software approach.  The reason I asked for your OS is to know whether or not a Mac solution (which I can personally vouch for) or a Windows solution (which I don't know for sure, but believe will work.
What you need to do is to change the images to that 1.5:1 ratio by adding blank white (or black, or whatever you want) to the long dimension.  This can be done easily using the batch capabilities of a program like GraphicConverter (Mac), Irfanview (PC) or Photoshop or Photoshop Elements (both).
If you are like me, then you want to save the expanded images to a new location with a new name.
If you tell me what software you have, I can give you step by step instructions for GraphicConverter or Photoshop.
A second alternative would of course be to find a place that can make prints in the same ratio as your images.  The problem is that this somewhat unpopular print ratio.  Oddly, it is a very popular image ratio for inexpensive cameras.
A third alternative approach would be to just take the potential cropping into account when you take the picture in the first place.  You could even place some tape over the parts of the LCD that will get cut off.
Please let me know if I can be of any more help.
Feb 07, 2008 | Canon PowerShot A530 Digital Camera
Canon a530 powershot won't snap a picture
sounds like the flash isn't charging, as the flash icon flashes while the flash is charging before letting you take the photo. Put it in "P" and disable the flash and see if it'll let you take a photo. G>
Sep 03, 2007 | Canon PowerShot A530 Digital Camera
Canon Powershot A530 is not detecting in my win XP SP2
check your usb cable maybe it have a open line...and also the usb socket pin of your camera may be there a pin not properly align..
Aug 20, 2007 | Canon PowerShot A530 Digital Camera
Canon PowerShot A530 Digital Camera Logo
98 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
