Question about Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
No water/to carpet
No water out bottom but comes out handle bissell cleaner 7901
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
fgn
Posted on Sep 30, 2010
Can't remove the lid on tank of Bissel carpet cleaner # 7901-R
Hey Anne! Once you remove the water tank from the machine, grasp the gray handle, turn it from the curved end to the flat end of the tank, and lift upwards.
Feb 19, 2013 | Vacuums
How do I replace the elevator lever arm on my bissell 7901-6 steam cleaner
i have a bissell 7901 and i recently replaced the brush belt. now my problem is the brush while is working the brush is not making contact with the carpet. how can i adjust the brush?
Nov 01, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
My bissell7901 is spraying water out by the wheels
heatman101 sfdgd
Mar 28, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell pro heat steam carpet cleaner, not releasing water.
That means that you need to replace the pump belt. Here is the belt you need and a manual you can view:
Bissell 7901 Belt and Manual
Mar 01, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
The water will not come out, indicator not spinning
trash it! I am having the same problem. I am so mad at my carpet cleaner, I have only used it 2 times. JUNK!
Mar 30, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Singer by ryobi turtle plus carpet cleaner model ms4000
Will water squirt out the hose? If it does then the heater in the handle may be clogged and not allowing water to flow. The heater is in the handle. There are a number of things that can cause your problem. If no clogged heater and lines, and no water from the hose, then the pump or pump belt maybe bad, the cap for the flow indictor is leaking air and not sealing, the gasket at the bottom of the tank isn't on the tank, either missing or sitting in the hole in the base where the tank sits.
Here is a link you may find useful:
http://bissell.com/images/Schematics/7901.pdf
https://bissell.com/NewsLetters/ListArticles.asp?Page_id=27960&Article_id=132
Feb 21, 2008 | Bissell 7901-7 Proheat Upright Vacuum
Will not dispense soap from handle
The soap dispenser, on the side, make sure the seal is on the bottom of it and not in the hole. You may have to replace the valve asm for the dispenser part # 2101795
Sep 30, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum Logo
91 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
