Question about Proview PL913B 19" Flat Panel LCD Monitor
Ma-982kc (900P) hi 19"proview model ma-982kc computer switched on monitor switched but screen black some times get fuzzy lines down the screen if you keep switching on and off eventualy normal screen returns untill it gets switched off tried leaving power to it when computer off but still the same put old monitor on with no problems so video card and computer ok cables waggled but still no change any ideas spirax
  • 3 more comments
  • Anonymous Mar 18, 2008
    Hello, i have the same problem. no lines though. one day, the monitor just decided to shut off, and the led power light started flashing. no picture. cant turn it on or off with the power button. the only thing i can do is unplug it. if someone has a suggestion other then throwing it out the window, please. i would love to hear it. i wouldnt want to send it in to fix it because im sure it costs the same amount as buying a new one. also, i am absolutely ignorant about anything electronics, im an electrician not a computer girl. so whatever your suggestion, im sure i wouldnt be the only one to appreciate you holding my hand through it all. thank you in advance.
  • Lauraleigh Apr 20, 2008
    I think I have the same problem... its two years old.. a MA982KC-900P... used pretty much on a daily basis... the problem first started that the image on the screen was shaky... the entire screen... everything would move back and forth very slightly... just for a few minutes at a time .. almost as if you had too much too drink and you were trying to focus... it didnt happen all the time.. just once in a while... then it progressed to when the computer is first lit up, the screen would come on as just bright white... and it would have to warm up for about 5 minutes... turn it off and on again and then it would be fine until turned off again over night... now when it is first lit up there is a black screen and no amount of turning it on or off makes a difference until it has sat on for about 10 minutes... then it changes to bright white... and if you turn it off and on you vaguely get the screen image until it transforms to all white again... only after sitting as white for 10 minutes can you turn it off and on again and there is no more problems as long as it is left on... so its anywhere from 20-30 minutes to get it up and running... its taken about 3 - 4 weeks to get to this point from the first time it had the all-white problem..
    thanks!
  • ja812 May 03, 2008
    I had the same problem that was described below. I have the same monitor except it's black.
    My monitor was doing the same thing almost. Their was a fuzzy border down both sides of the screen with faint black line across it. The problem had existed for nearly a month. It almost seemed like it needed to be 'degossed' (spelling?), like old computers that we had in high school. (I'm just assuming that only old monitors had that button because this one does not.) Anyhow, I messed with the controls on it and that didn't work. Then, I unplugged the cable from the back of the computer and blew it out, still there was no improvement.
    After read the solution I unplugged the cable and their were no bent prongs. So, I blew it out again like you would a Nintendo game and plugged it back in. Then, I unplugged the cable from the back of the monitor (the cord is removable on this Proview model) and did the same thing.
    I turned it on, and boom: Fixya! So, in this case, the true source of the problem was the way the cable was plugged into the back of the monitor.
    Thanks for the help!
  • superaz7 Jul 27, 2008
  • davidbukera Sep 04, 2008
    It seems to look like kind of
    but i don't know if you can help me with this problem
    I don’t know what has happened to my monitor. Last time when I use the monitor was working fine but later on it not working properly. When I put it on it only last for about 3-5 seconds then the light goes off but I can still see the image in harder condition which means everything is just very dark. Every time I put it off then back on, it keeping doing the same things so please help me because I really like this monitor I don’t want to get another one how can I fix this problem or where can I take it for repair
"IF YOU HAVE THE ON FOR A FEW SECONDS AND THEN OFF PROBLEM, DONT REPLACE ANYTHING UNTILL YOU HAVE TRIED THIS" hey guys i have the 2second problem aswell but!, i was just about to throw mines away when i can stumbled across away how to get it working proper again and again and again!. ive seen lots of help pages like this where everyone is talkin about replacing parts, but if u screen flicks on and then off it should work with my quick fix. heres how and i hope it works for you. Boot up ur pc as u would usually and wait awhile untill you think everything has loaded up or has reached the logon stage. Then if you look carefully at ur screen and press the menu button you should be able to see it thery faintly (i shine a lamp at it to see better). Then i cycle through OSD (on screen disply) menu using the up or down buttons on my monitor untill i see the "AUTO" option. at this stage i press MENU button "2 times" Then i cycle through the OSD untill i see the "RESET" option and again i press the MENU button to confirm the reset. Then simply press the power button to switch it off and then back on....HEY PRESTO! it working again. I have told 11 people this fix and they all reported back that it works for them 2. this method should work every time aslong as you stiil can see the green LED on ur monitor.
Posted on Jun 13, 2009
  • skylark42 Apr 20, 2018
    Thank you very much, CurtisF08. I can confirm that this hack is still working as of April 2018. A small miracle; I thought my beautiful (10-year-old) MA-982K was a gonner.
  • 28 Answers
Found a 470uf @25V Electrolytic capicator vented (top bulged) in power supply. Although in my case this was the only one bad, all of the electrolytics in the D.C. power supply should be checked for tolerance and e.s.r.
Posted on Sep 06, 2008
    Scholar:
  • 87 Answers
Replace all capacitors on these monitors, The MA-782ck is the same monitor only 17", same repair applys, The usual suspects are 6x470uf 25 volt 105 degrees and 1x220uf 25 volt 105 degrees caps but replacing all the caps tends to make it more reliable. Also lines and "funny graphics" on the screen can be caused by the thin cable that runs from the graphics card in the monitor to the lcd screen not being pushed in fully on both sides of the cable. hope this helps.
Posted on May 08, 2009
CURTISF08....Make that #12 Curtis F is right on...Just followed his steps and voila the monitor is like a cat and has gained another life!
Posted on Sep 06, 2009
Hi i just got one of these monitors a few weeks ago from a friend with said same problem . i found that the electrolitic capacitors in the inverter had dryed out theres 4 in total in the inverter ( but i also changed all the electrolitics in the power suppy unit as well because the tops had started to bulge out for the extra few Cs its going to cost its worth it to do it even if they look ok if you can get them use Panasonic 105Deg ones result one nice monitor
Posted on Jul 12, 2007
  • 624 Answers
From what you describe it sounds like you have eliminated the physical video card as a problem. I would try checking: -For a new video card driver. I?m skeptical this will fix your problem but it?s an easy way to eliminate one more variable. -Where the video cable plugs into the PC. Remove and check for bent pins, corrosion and replace and firmly reconnect using the thumbscrews on the connector. -Where the video cable plugs into the monitor. Some LCD monitors have removable cables some don?t; if yours does follow the same procedure outlined above. -Could be a problem with a connection inside the monitor. A quick test and perhaps even fix would be to grasp the right and left sides of your display while it is on (displaying the offensive lines) and gently twist like you were wringing out a towel. Again, and I emphasize, gently using only a couple of ounces of force. Watch to see if the lines disappear, get worse of make the screen flash or change. If you do then its likely cause is the connector from the LCD panel to the electronics has oxidation or a loose connection. If you?re lucky the flexing might even fix your problem, if not you will have to take it apart to find out exactly what is going on. Let us know if you have any more questions and please don?t forget to rate this post.
Posted on Mar 14, 2007
ProView 19" Flat Screen Monitor comes on with
The dark or black picture is caused by a failure in the back light power supply. The problem can be corrected by replacing a few parts called capacitors on the board. Replacing them will require a little soldering but anyone can do it. Here is a link to a page that shows what needs to be replaced.
http://www.ccl-la.com/blog/index.php/gateway-fpd1975w-monitor-repair/
I hope this helps, if so please rate my solution.
BuddyMc
Sep 17, 2011 | Proview PL926WBi 19" LCD Monitor
Product NO. PL916s Model NO. 900P I have a Proview monitor, which has always worked wonderfully. Recently my computer broke down and I'm using another computer with a small screen. I have misplaced...
Product NO. PL916s Model NO? This trouble maybe power supply or inverter boards is defective. first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
AI 0088 Proview 860 ALZ M713W Power Supply for PL916S
Jul 21, 2011 | Proview PL916S2 Monitor
I have a xerox Flat Panel LCD Monitor 19" i purchased at office depot in 11/05, manufactured by Proview Technology, Inc. Model# 900P. I love this monitor, about 1 year ago I moved and it went into...
Depends where it was in storage. It may have got damp.
I would try leave it inside in the warm and try again.
If no luck it would probably be cheaper to get a new one than getting it repaired. A 19 monitor start at about £70
Sep 04, 2010 | Computers & Internet
I have Monitor Proview PL916S 900P It turns on
spc12b, Have you tried the flashlight test yet? How old is this monitor? Your monitor has a 2 types of power supplys in it. A switch-mode-power-supply and an "INVERTER" supply. One or both of them could be having a problem. The inverter needs DC from the smps to change it into AC to light up the cold-cathode-fluorescent-tubes that are hung in back of the lcd panel. Let me know results of flashlight test. After screen goes black, hold light 1-2" from screen at different angles. Let me know if you still can see the win-desktop screen even though it is still dark.. Bye for now. louie12fix on fixya or lmistyrel @aol.com
Aug 12, 2009 | Proview PL916S2 Monitor
Proview monitor blacking out
i would suggest getting a new monitor you might have made it overheat or your display driver failed.
Feb 16, 2009 | Proview PL913S 19" Flat Panel LCD Monitor
Popping sound, black screen
Has it bitten the dust? Probably.
May 18, 2017 | Proview PL926WBi 19" LCD Monitor
Monitor turns off after 4-5 seconds
hi every one, i hope this helps and am proud to say/or not that i am now using my philips php-19x (aka proview 900w/Mag LT916s Model 900p/ Xerox) and yes turn on the monitor 2 seconds screen goes black and the blue power light stay lit, but if you shine a torch onto the screen you can see the lcd display is working, and if you turn the power off and on the cycle starts again, like most of us we checked the web to no avail, untill yesterday. I have been playing with this monitor for 3 months on and off after a kind fellow gave me this monitor for free on uk freecycle and of course i checked all the caps on the psu/inverter pcb and more components all seemed fine checked the ccfl lamps by taking them out of the lcd panel (15 minutes to dismantle) both lamps where fine not orange, a nice bright light, and knowing that if the monitor started woking ok and the back lights did not fail it would run like this for ever until you turned the monitor off / video blanking so i was convinced that there was no fault with the psu/inverter board, and as i stated i found the solution at last (yeh) and here it is many that's to all on the bad caps forum and of course the main man -----barry wilkins-----
Re: Mag LT916s Model 900p 19" LCD dropping like flies
I have got to the bottom of this ,after I got one of scopes out (PM 97) the output of the TL 494 IC was disappearing .The IC seems to crash easily ,I think the oscillator on pins 5&6 actually stops.
I cleaned the whole board with an aerosol of PCB cleaner and heated up the PCB up with a small craft heat gun to quite hot .
I fitted a 0.01 mfd capacitor across the IC pins 12 to 7 to decouple the VSS supply ,because I felt the cause of the IC stopping could be interference based
The monitor now runs for all day with no sign of the backlights cutting out.
I found out this LCD display was made by proview.
Barry Wilkins
john r uk.
Sep 05, 2008 | Computers & Internet
Proview 19inch LCD MA982k model 900p
You are on the right track. Sometimes the ribbon cables will look fine but the wire inside the insulation is broken and will result in intermittant problems. Definately check the cable first and repair or replace. It is best to meter the cable while not connected to avoid false readings through other components. Should be a relatively easy repair.
Jan 03, 2008 | Proview PL926WBi 19" LCD Monitor
Monitor works on one computer, but not the other
The problem is not your monitor, but the video card on your computer that it doesn't work on. If the video output on your computer is built in, residing near your keyboard / mouse ports, you can purchase another video card to put into your computer and connect your monitor up to that instead. If it attaches to a separate card inside your computer, just replace it. There are three kinds you can get, AGP, PCI, or PCIe. Make sure you get one that will fit inside your computer.
Jun 26, 2007 | Proview PL913S 19" Flat Panel LCD Monitor
Proview PL913B 19" Flat Panel LCD Monitor Logo
2,112 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ka4iup
ka4iup
Bastian Farkash
Bastian Farkash
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
