MY OS IS WINDOWS NT, AND MY PRINTER IS MFC240C, CAN I MAKE THE PRINTER WORK ON WINDOWS NT ... PL ADVISE...
    President:
  • 2,692 Answers
Their is a driver available for Xp professional 64 for your printer (see link below) I se no reason thar it would not work as Xpro 64 contains a lot of the code from Win NT. Worth a try.
http://www.brother-usa.com/Downloads/Default.aspx
Posted on Dec 14, 2008
    Scholar:
  • 113 Answers
Read the package box of your printer. If it has windows NT printed on it then you can, because it needs compatibility driver to run your printer. But if it is a desk-jet or inkjet you can install whether you are in NT or other os.
THE MITSUBISHI CP8000DW DRIVER IS DISCONTINUED HOW CAN I FIND THE DRIVER?
What OS is your computer running? I found the drivers for supported OS versions here: http://displays.mitsubishielectric.eu/resources/product/CP8000DW . The direct links are listed below. (All are .zip files so you will need to unzip them.)
Mac http://displays.mitsubishielectric.eu/files/library/files/DISCONTINUED/PRINTERS/cp8000m_macos.zip .
Win95-98 http://displays.mitsubishielectric.eu/files/library/files/DISCONTINUED/PRINTERS/cp8000dw_win95-98.zip .
Win NT and Win2K
http://displays.mitsubishielectric.eu/files/library/files/DISCONTINUED/PRINTERS/cpd8000n_wnt4_0.zip .
If you have a newer Windows OS, you can try the compatibility mode. (The NT driver will likely work in XP. If you have Vista or Win7 32-bit OS, it's possible they will work but maybe not. If you have the 64-bit version, the above files will not work directly.) For executable files in Windows, right click on the .exe file and choose properties. Select the Compatibility tab and check Always run this program in the Compatibility Mode. Select the appropriate older version of Windows. Then click Apply. Close the Properties window. Then right click again on the file and choose Run as Administrator (required for Win7 and Vista).
To check if you have the 64-bit OS, click Start > Control Panel > System and Security > System (for Win7). In Vista, the steps may be slightly different. If the version name ends with x64, you have a 64-bit OS. Otherwise, you have the 32-bit version.
If you have a 64-bit OS, you need a 32-bit OS for a work-around. This can be a true second computer, a dual boot system (2 partitions with different OSes loaded), or a virtual computer with an older version of the OS. If you have Windows 7 Pro or Ultimate, you can install a virtual XP computer for free. Go to microsoft.com and download Virtual PC and the XP mode program. Install them in order. Then install your printer under XP as if it were the only computer running. (Note some computer hardware limits may stop you from using this option.) There are other virtual computer programs (VMWare, Parallels). However for the other virtual computer programs or the dual boot or second computer options, you need a licensed copy of the older OS.
I hope this helps.
Oct 03, 2011 | Mitsubishi Color Printer 8000DW Thermal
OUR COMPUTER IS WINDOW 2000 AND WE WOULD LIKE TO INSTALL OUR EPSON PRINTER LX800
Download the Dot Matrix Printer Drivers @ "Generic 9-Pin Printer Driver v1.0bEs"
OS: Windows 98, Windows 95, Windows NT 4.0, Windows NT 3.51
File: epson10753.exe - 559KB
This self-extracting file contains the Generic 9-Pin Printer Driver for Windows 95, 98, NT 3.51 and NT 4.0 (Printer Driver v1.0bEs, Core Driver Disk v1.0). This file is for use with all Epson 9-Pin Dot Matrix Printers.
Note: Please have your Microsoft Windows CD-ROM available as the printer driver may require some OS files from the CD-ROM to complete the installation.
Hope it helps.
Apr 11, 2011 | Computers & Internet
Gerror 913 en lso archivos201 segenera por tener archivos desatualizado
Obten los controladores de Windows o MAc y actualiza tu printer.Si continua el problema escribeme.
Windows Operating Systems spacer.gif [+] Generic 9-Pin Printer Driver v1.0bEs
epson10753.exe - 559KB - posted on 05/29/03
[-] Generic 9-Pin Printer Driver v1.0bEs
downloads_icon.gif Download Now
Windows 3.1
ep10759.exe - 527.2KB - posted on 05/29/03
Windows 3.1
This self-extracting file contains the Generic 9-Pin Printer Driver for Windows 3.1 (Printer Driver v1.0bEs, Core Driver Disk v1.0). This file is for use with all Epson 9-Pin Dot Matrix Printers.
Note: Please have your Windows 3.1 installation disks available as the printer driver requires the "unidrv.dll" file to complete the installation.
Macintosh Operating Systems spacer.gif [+] Network Printer Driver v2.0A
Mac System 7
EPRINT2N.SEA.hqx - 779.1KB - posted on 06/12/96
[-] Network Printer Driver v2.0A
Mac System 7
This self-extracting file contains the EPSON Print! 2 Network Printer Driver files for the 9-pin ESC P2, 24-pin ESC P2, and the DFX printers.
[+] Printer Driver (Serial) v2.0A
Mac System 7
EPRINT2S.SEA.hqx - 610.1KB - posted on 06/12/96
[-] Printer Driver (Serial) v2.0A
Mac System 7
This self-extracting file contains the Epson Print! 2 Printer Driver for serial connections with 9-pin ESC/P2, 24-pin ESC/P2, and the DFX printers.
Dec 17, 2010 | Epson FX 1170 Matrix Printer
Epson stylus 88+ drivers for windows NT
go to google search .while searching type the ur os name and and printer like(driver for printer name and windows nt os)ther u can find ur drivers
Feb 25, 2009 | Epson Stylus C88 InkJet Photo Printer
I need to know what windows program the Canon S750 will work with. Example will it work with 1998 Windows and older.
Operating systems that it works with is Windows 95/98/2000/Me/XP, Windows NT 4.0, Mac OS(8.5 to 9.x) and Mac OS X v10.1 to 10.2.x
may work with vista if drivers are available in canon website... for this model...
Aug 22, 2008 | Canon Office Equipment & Supplies
I cant install my canon BJC-4100 printer
What OS are you trying to install it on, and how are you getting the files? The printer came out when Windows 95 was brand new, so using the original installation discs (floppies?) on any newer OS is not going to work. Canon has drivers available online for Windows NT, 95, 98 and Me here.
If you have a newer Windows 2000 or Windows XP use the drivers that are built in to the OS. From the Add Printer option, select Canon as the manufacturer, then look for Canon Bubble Jet BJC-4100.
If you have Windows Vista, this printer is not supported in that OS. Nor is this printer supported in any Mac OS.
Jul 28, 2008 | Canon Office Equipment & Supplies
Compatibility
i have lost installation cd of CT7510 Camera please solve this
Apr 27, 2008 | Creative Labs Video Blaster Go Plus Webcam
Brother MFC240C in stallation
The solution for this one's an easy fix. All you have to do is go to brother, click on Product Support, select your country or the nearest one to you, then where it says please enter your model name type in mfc-240c and hit enter. Click where it says MFC-240C and then go to downloads, select drivers, then your operating system, and then your language, and finally, click search. It will bring you to the page with teh drivers for your printer. In the downloads area, you can also download the manuals, the software for your printer, etc.. It's all quite well laid out. Let me know if you run into any problems.
~adamvan2000
Mar 19, 2008 | Brother Multi-Function Center MFC-240C...
54 people viewed this question
k24674
jasbo
jasbo
