Question about Juki MO-644D Mechanical Sewing Machine
Hi. I'm looking for a replacement blade for my commercial serger. It's a MO 3700 series.
    Problem Solver:
  • 13 Answers
Call Willard at Texas Sewing Machine in Ft. Worth, 1-800-252-8763.
They supply my company and do a great job. Very knowledgeable.
Posted on Dec 15, 2008
How do I change the lower blade on my Juki MO-816 Serger
Usually, the lower blade should be changed by a technician. The upper blade can be replaced by the user, but the lower blade requires some minute specifications that use special tools.
Dec 19, 2016 | Juki Sewing Machines
I need replace thread holder for Juki MO-644D serger
Good luck. I found a replacement part for one of mine on Ebay. Just search for Used Juki Serger for parts. Maybe you'll find a 644D for cheap enough that you can scavenge parts for a few more years.
Oct 25, 2012 | Juki MO-644D Mechanical Sewing Machine
How do you take the upper blade off of a juki MO-734DE serger?
check with these sites for a manual
jukihome.com
sew4less.com
sewingpartsonline.com
May 03, 2012 | Juki Sewing Machines
JUKI MO-812 Class DD6 Serger Instruction Manual
check with a juki dealer about a manual
or check with sewvacdoctor.com
Mar 03, 2012 | Sewing Machines
I want to adjust my serger yuki mo 2516n but i don't still have it's manual instructions
if you go to this page http://www.juki.co.jp/household_en/serger/index.html there are the current household sergers from Juki and a four page threading diagram for them showing the different stitch set ups.
If your serger is a domestic one too (the MO in front makes me think so) then you may find that the threading up is very similar on your model. Stitch length is usually a kob on the right marked from 0.5 to 4 and differential feed knob is usually there too, usually marked from -0.5 up to 1.5. Tension settings are usually around 5 but you adjust the looper tensions to suit the fabric and how wide you are trimming it with the blades.
You could contact Juki or their local distributor in your country and arrange to purchase manual for your model. http://www.juki.co.jp/household_en/dl/index.html this page gives a listing for countries.
it is also available on line to purchase as a black and white pdf file, http://www.sewusa.com/Sewing_Machine_Manuals/Juki_Manuals/Juki_Industrial_Sewing_Machine_Manuals/MO-2500_Instruction_Manual.htm for $8USD
Jun 20, 2011 | Sewing Machines
JUKI MO 134 SERGER
How to Thread Juki MO-134 Serger from watching lady at Lyles. Turn upper blade up. Push in first then turn up.It makes threading easier. Blue Thread upper looper first. Pull thread through tension knob. Don'tjust lay it there. (She thought that is what I must have done) Orange Thread lower looper next. Pull thread through tension knob as inthreading upper looper. Adjust lower looper so it is right nextto upper looper so that their points are almost together and directly belowsewing needles. Lower looper will be in front of upper looper (I believe). With tread from upper looper pulledback, slightly lift lower looper above upper looper and thread. I think this isright. Pull thread back with other thread. Tension is the key. Remember that. Yellow: Thread left needle first.Remember tension. Pull thread through curled wire on left side of needle arm. Green: Thread right needle. Rememberabout tension. Pull thread through curled wire on right side of needle arm. b> Note: Before sewing turn the wheel tomake sure the stitches are going together correctly.
Apr 16, 2010 | Juki MO-644D Mechanical Sewing Machine
Need instructions for threading Juki MO 3314
Open the font of the serger and the instructions will be printed on the serger or on the door.
Raise the presser foot and set the tensions to zero when threading.
Turn the hand wheel so the upper looper (curved one) is at it's highest point and thread it first, and then the lower looper.
With some sergers you must thread in a certain sequence. This should be indicated in the instructions on the serger.
Set the tensions back to normal ( 4 - 6), lower the presser foot and run a length of stitching to see if the threads are knitted together as they should before you start serging your project.
Feb 19, 2010 | Juki MO-734DE Mechanical Sewing Machine
Looking for an online manual for my Juki serger MO-634DE
Herre is a link to the threading diagram: http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Juki_Sewing_machine_threading/Juki_MO_634_Threading_Diagram.htm
Oct 08, 2009 | Juki MO-644D Mechanical Sewing Machine
I have a juki mo-3614 serger and I can't seem to get the blades lined up right for cutting. It just seems to want to roll the fabric instead of cut it. How do I line up the blades the right way.
first, pull out the bvlades and make surte they are sharp. It could simply be that they are dull. Next, line tyhe bottom blade up level to the surface of the needle plate. The top blade should be adjusted to where it slices against the botom blade. You may have to experiment with the height adjustment on the top blade, assuming you have a suitable cutting edge.
Nov 29, 2008 | Juki MO-644D Mechanical Sewing Machine
Juki MO-644D Mechanical Sewing Machine Logo
99 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Pete Alaniz
Level 1 Expert
Derek Massey
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
