Question about Toshiba Satellite M30X Notebook
SmaT FAILURE PREDICTED ON HARD DISC
I cannot start up my computer. it is a black screen that says smarT FAILURE PREDICTED ON HARD DISC
    Scholar:
  • 113 Answers
Okay you have seen that message simply because it did not detected any hard-disk. If you know how to open your computer all you have to do is press all the wires in there it maybe dew to loose connection. then try booting it up again be sure it has a system already. If still didn't work out no other solution but to replace the hard disk.
Posted on Dec 14, 2008
SMART FAILURE PREDICTED ON HARD DISK 2 TOSHIBA MK2035GSS (S1) PRESS F1 TO CONTINUE. ON START UP COMPUTER GOES TO THIS SCREEN EVERY OPTION ON START UP OF F1 DOES NOT START WINDOWS AND COMPUTER RETURNS TO...
Unfortunately it sounds like Your hard drive has gone bad. If this is the Hard Drive that contains your operating system you would have to replace Hard Drive and then replace Operating system using your Restore cd's.
Jul 11, 2011 | Computers & Internet
As I understand it, SMART is correct 50-60% of the time...means it's wrong 40-50% of the time.But..You can't take the risk, you have to assume something is wrong with your hard drive. So, i f you have important data there, go to a repair shop and they can save data from your hard drive and replace it, if necessary. If you want to solve it on our own, you need a boot cd with error checking. Any live boot cd with linux does that. Also, there are several live boot cds like Hiren's Boot, with rescue options.
May 11, 2011 | Computers & Internet
BLACK SCREEN WITH CURSOR NOW WITH A BLINKING LINE
Sounds liek your hard drive has failed, search ebay for this model of laptop with hardrive at end of yoru search, not 100 percent sure but im nearly 90 percent sure its hard drive failure.
Dec 03, 2009 | Gateway P-6313 Notebook
Smart Failure Predicted on Hard Disk 4
Are you sure you don't have a usb or other device plugged into your computer. Your main hard drive should be disc 0. Disc 4 is usually a disc further down the line, like an external or something like that. If it indeed the case then you may be having a problem with the boot in your primary drive. Try booting the disc with a windows installation disc. load the dosc and boot, when it says so, hit any key to boot off cd. When windows loads, hit repair this installation. It will reboot when it is ready. If that doesn't take care of it, reload the disc again and try to restore the drive to an earlier time, like a day or two ago. If this doesn't work, you may have to get another hard drive and reload the system. Don't get rod of the other hard drive though because you may still be able to access the personal files off of it as long as it hasn't had a mechanical or electrical problem keeping it from spinning.
Sep 13, 2009 | Dell Inspiron 1501 Notebook
Hard Disk Problem
That failure is predicted by the SMART reporting system. Its a status chip on the drive that reports to apps that can read the smart data from the hard drive. Its not always accurate but it usually is.
Time backup your data on that drive ASAP and then buy a new drive.
Sep 07, 2009 | Toshiba MK1637GSX 160 GB IDE Hard Drive
Smart failure predicted on hard disk toshiba mk4025gas ( pm )
This means your hard drive is bad or about to go bad and needs to be replaced. If you can still access the drive, immediately back up anything important to you. You will then need to replace the hard drive. Thanks and please take a moment to rate this solution with a fixya rating, even if the news isn't what you wanted to hear. Thanks! :c)
Feb 14, 2009 | HP Business Notebook NX9110 Notebook
Acer 1642 laptop is giving me much trouble. Was working fine until, fapoot... now i receive a message: SMART failure predicted on hard drive 0:ST6100825A-(PM), please help if you can
A SMART failure means that your hard drive is predicted to fail
soon. Fortunately these warnings are not right 40%-50% of the time. Go to the command prompt (start- run- type in "cmd")
In the prompt type in "chkdsk"
This will run tests on your hard drive and tell if there is anything wrong with it.
Dec 28, 2008 | Acer Aspire 3610 Notebook
When you turn the computer on it says SMART Failer predicted on hard disk 0: HTS54108G9SA00-(S1)
S.M.A.R.T. (Self-Monitoring Analysis and Reporting Technology) is a diagnostic method originally developed by IBM that at that time referred to as "Predictive Failure Analysis". This technology was developed for IBM mainframe drives to give advanced warning of drive failures. Based on this diagnostic, Compaq announced IntelliSafeTM, which was submitted to the ATA/IDE standards committees and the resulting standard was named S.M.A.R.T.
S.M.A.R.T. analyzes many of the mechanical attributes; over time, some failures can be predicted by detecting if the hard disk drive is moving out of tolerance. While the S.M.A.R.T. technology can detect upcoming issues, not all hard drive failures are predictable.
All this means on most modern drives is the hard drive is coming close to the maximum tolerances
I usually switch off in the bios smart monitoring.
This system is trying to predict a possible failure, which may or may not occur..
Mar 30, 2008 | Computers & Internet
Toshiba Satellite M30X Notebook Logo
224 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
