Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Washer is not spinning
My washer was bought three years ago, new. Now that the warranty is expired my washer has quit spinning. I have had to put loads through an additional spin cycle to get the clothes less wet. Now... it won't spin at all! Could this be the drive belt? I'm wwanting to fix this myself. Any suggestions would be greatly appreciated.
  • nikki111084 Jan 25, 2009
    I have a Kennmore washer and it has just stopped spinning...It does everything else right. Just stopped spinning any Ideas how to fix it???
    Novelist:
  • 116 Answers
The motor coupler could be worn. This is accessed by removing the front of the cabinet. The upper console 1s held on by 2 screws at the base of the upper control at the back corners. The console slides forward then rotates up. Benearth the upper console is 2 gold spring clips which have to be pryed out with a screwdriver, The power cord will have to be disconnected at this time. The whole cabinet will tip forward 45 degrees leaving the base and tub assembly stationary. The cabinet then can be slid out of the way. In the front at the bottom is the pump and motor. Pry off the 2 spring clips that hold the plastic pump in place and pull it out of the way. You do not need to disconnect the water lines. The motor is held in place by 2 spring clips which are fastened to the motor by a 5/16 hex bolts. Remove these bolts and pry the clips out of the way they both will pop off of the motor, do not let the motor drop. Pull the motor out of the way revealing a black rubber disk with a white coupler on the motor shaft and one on the transmission shaft. this whole assembly will likely be damaged and will need to be replaced. The coupler should only cost about $10 at any appliance parts store.
Posted on Mar 14, 2007
My dryer quit working this morning. The light and beep go off but the drum dies nothing.
I have the Frigidaire Affinity Washer and Dryer. A few weeks ago my Washer door switch went out I changes that with no problem. Now the Dryer has just stop quit working. Here are the symptoms on the ; 1>it's plug up and the power is fine 2> there is no errors on the panel 3> control operate fine. 4> close the door, set the controls, press start, No spinning. 5> when you press start you hear a buzzing sound for about 5 seconds, then nothing... Is it over for the dryer I bought 3 years with out extended warranty, or is the a simple fix? Thanks, Rob...
Sep 07, 2010 | Frigidaire Affinity AEQ6000WH Dryer
Washer quit spinning
Sounds like the lid switch has failed. This switch will not allow the drum to spin if it senses that the door is not locked. Have it replaced and that should take care of the problem. Hope this helps. Good luck.
Jul 23, 2009 | Roper RTW4300SQ Top Load Washer
Kenmore Elite HE4 front loading washer. I bought this washer 2 years & 2 months ago. According to Sears the warranty expired 2 months ago. I was getting a F 02 it would not spin or empty water, so I called...
ya, first question? they said $1000.00 to fix?wow Did the tech give you that in writing?
ok, take off the bottom kick plate and you will see a pump right in the middle. there is a trap there unsrew the cap and get the stuff out of there., word of caution have towels ready cause when you take this off the water will come out. you should get as much water as you can at first.from the tub.you will not get all the water out.
let me know what you find.
Dec 06, 2008 | Kenmore Elite HE4 Electric Dryer
Frigidaire
probaly control bd problem ..call any way to get history started also may consider extended warranty from where you purchased it some other warranty company control may finally go after warranty expires and and extended one would help avoid problems getting coverage for a problem that may be present during original warranty..ever tried convincing company to repair something that was faulty to begin with??
Nov 20, 2008 | Frigidaire GLTR1670A Front Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
246 people viewed this question
Sal De
Marvin
Marvin
jimorris77
