Question about Philips Magnavox 51MP392H Rear Projection Television
No picture for a while i would turn the tv on and the picture would shut off after a few seconds. i found an adjustment "box" in the rear of the tv. after turning the color knobs down i was able to keep the picture from going out. but now i can't get any pic out of it.
  • Philips Master
  • 5,138 Answers
CK for poor solder connection around the video ic.Resolder around ic.
Posted on Dec 18, 2008
Picture went out and red light on the front by power button is blinking. When I turn TV on I can hear sound but no picture,, then TV turns off automatically after a few seconds.
It seems problem with low screen voltage to three picture tubes in this rear projection tv.
If standby light blinks 5 times after three seconds long pause then adjust screen volts of each picture tube to solve this issue.
Screen volt adjustment requires expertise and job of professional so please call local tv repairman to help you.
Thanks.
Feb 27, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
Turn TV on.. power light comes on.. sometimes see picture for a few seconds, picture blinks, becomes vertically smaller, then TV shuts off.... sometimes do not see picture at all, before TV shuts off....
the tv is rrar projection i am sorry but these are mento be serviced every 3 years or so but can go faster it is the convergance settings they are adjusted by knobs inside the tv you will need any good tv reapair service it will cost 120 pounds max and it will come with a garuntee but it is worth it as the tv will be like new again this is the problem with rear projection sorry to be the bearer of bad news but i fix these tvs every day...please be sure to make payment and let me know how you get on but please pay no more than 120 pounds
Jan 16, 2011 | RCA HD52W59 HDTV Projection Television
Picture has a black image (box that black out part of the screen) that comes on seconds after TV is turned on, leaves when volume is adjusted, then returns after a few seconds. Does not appear when Wii is...
You need to go into your menu and go to close caption and turn off the text screen that some how got turn on, that big black box is call a text screen, and you are not the first person that this has happen too, Take care.
Jan 09, 2011 | Panasonic PT-51HX41 51" Rear Projection...
Green hue on KP-43Ht20 Sony rear projection tv
Behind the front cover you will see a little plastic box with six phillips headed dials. They only move 180 degrees. The three on the bottom control color richness and the three above them control focus. Turn all three of the bottom ones to the left while the TV is on, then gradually turn them to the right until you get the color you want. NOTE if any one of the three bottom dials are too far up the TV will shut down and will continue to turn off after about 10 seconds after start up until the offending dial is turned back a little.
May 17, 2009 | Sony KP-43HT20 43" Rear Projection...
Tv wont come on
You may have some type of short INSIDE of your TV .Your TV is trying to turn on and RESETS itself to try again. If you have an EXTERNAL [black box],(usually means power supply, power adapter,etc.) power supply, that!! could be at fault. not giving the proper voltage, current, causing the machine to fault. If you can exchange a known working power supply to see if that is the problem.
If you don't know what you are doing, don't go inside of the TV. There are circuits that can hold a charge of electricity that can & will hurt you.
Oct 25, 2008 | Mitsubishi WS-55511 55" Rear Projection...
No picture sound is fine
tv comes on then turns blue at that time it shuts down. The power is on and then it blinks 5 times!!!
Apr 27, 2008 | Sony KP-65WS500 65" Rear Projection...
Turn on power, but no picture, when you turn off power see picture for a few seconds before tv shuts off
did you ever get your problem fixed? i have the same problem and its frrustrating. i fyou can help me please email me at blake.shewmaker@fnbky.com.
Thanks.
Dec 26, 2007 | Philips 50P8341 50" Rear Projection...
No picture, hear sound, television will shut off after a few seconds.
Lamp life is only a few thousand hours. Hopefully its only the lamp that made to noise. Don't turn on again until lamp is replaced.
Nov 05, 2007 | Toshiba TheaterWide 52HM84 52" Rear...
Green screen with pin stripes and TV shuts off after maybe 10 seconds!
Tom E...I have having the same problem with my Sony rear projection TV....it just started tonight, so I'm only now seeking a solution. Just curious if you've found anything out.
Sep 10, 2007 | Sony KP-57WS500 57" Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
54 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
