Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
How to fix myself
Won't turn on. green light comes on but only stays on a few seconds then goes out.
  • 2 more comments
  • tmason99 Dec 24, 2008
    Same thing with my tv. How can I repair this?
  • sg1fanbill Jan 03, 2009
    I appreciate the help, the only problem is I have been given 2 solutions by 2 different gurus and they are totally different. I have no idea which of the many boards might be the deflection board. The other solution was a bad or weak high output block, which I did identify its location but it is too expensive of a part to just replace without testing it first, and I have not a clue as to how to go about that. So thank you but I'm still stuck with a bum tv.
  • Anonymous Jan 04, 2009
    have the same tv same problem cant find any of those numbers that match up ???? Help
  • Anonymous Jan 05, 2009
    SAME CAN ANYBODY HELP DAMN I CANT EVEN SEE THE GAMEEEEEEEEEEEEEEEEEEEEE
  • RCA Master
  • 5,138 Answers
Check capacitors 3 of them if cp150- 2200uf 16 is puffed up on top it is bad so replace other 2 caps cp114 cp120 220uf 35v. These are on the Deflection board, also resolder pinns on FBT.capacitors are green with gold writing on them.
Posted on Dec 25, 2008
  • ladywinn
    ladywinn Jan 03, 2009
    There is 2/3 on bottom First board to the left is the Deflection board next to it the one that has tuners where you hook cable to is the SSB board the board with AC Power cord is AC board
    DEFLECTION BOARD has Flyback Transfomer on it has 2 wires coming from part red/black-/.one of the wires goes to high voltage trippler other one leads to focus/screen control block it has 3 controls on top 3 on bottom R/G/B
I can't get my tv to turn on. I turn it on and the green light comes on 3 times and the light only stays on for 3 seconds and then turns off. Can't get anything to happen with screen. Can you help me
Does it sound like it's coming on then powers down? Mine turned out to be the bulb. I bought a bulb on Ebay for less than $90.00 and installed it myself.
The bulb was inside a square metal housing, pull housing and bulb out of tv, replace the bulb reusing the existing housing, then replace..... Pretty easy fix, and I'm not all that mechanically inclined. Good luck!
Apr 05, 2013 | Televison & Video
Mitsubishi WS-65908 will not stay on
Its a color convergence problem from description:
If green light comes on for a few seconds and goes off:
On the front of the set (not the remote) press and hold both the menu and input (device) buttons at the same time for at least 5 seconds and release both.
Watch power light: it will blink a two digit error code, in your case I suspect it will be 2 blinks, 2 blinks and repeat several times.
Let me know error code and I will help.
Apr 16, 2012 | Televison & Video
I recently fixed the blinking green light problem following advice here. Now, about a week later, when I turn on the tv, I get image for a few seconds and then the screen goes blank/dark. Green light...
i have the same problem. i just replace the power board because of the "green blinking" light. now, light stays green, picture comes on for a few seconds, then blank....
did you fix your problem.
Aug 31, 2010 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
I have a 37" Philips (37PF9431D/37) flat panel tv. It won't power on. When you plug it in you can hear a click the green light stays on for a few seconds then goes out. I've checked the power board for bad...
i am having the same problem. My Phillips 37" 37PF9431D/37I LCD High Definition TV won;t turn on. When I press the power button i hear a click and the green light comes on for a couple of seconds and then the red light appears. I can;t figure it out. Did you find a solution?
May 20, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
My Loewe Aconda TV will not turn on - buzzing noise.
My Loewe Aconda 81 HDR TV will not turn on. When I press the power button the green light comes on but the red light stays on with it and after a few seconds the green light goes out and the red light stays on. Any help please.
May 15, 2010 | Loewe Aconda ACO9383 38" TV
Ps3 does not turn ON
looks like the YLOD, you can search some fixes of refloating the solder with a heat gun or take it to a repair shop. lastly and most expensive is sending it into sony assuming its out of warranty if it is its 150 to fix it. If still under warranty then call them asap.
Apr 28, 2010 | Sony Playstation 3 (PS3) Console
Screen stays black green light comes on for a few seconds.
This sounds like you have "bricked" your psp... there are a few things that can cause this: first would be that you have bricked it trying to install Custom Firmware, another would be that the battery died or it was shut off during an update. You can buy what is called a Pandora Battery and a "magic" memory stick which will reset your PSPs firmware to the original 1.5, or if you still have warranty you can send it in to Sony to get fixed. Pandora batteries and Magic Memory Sticks are sold in a package for about $10-15 on the internet. Good Luck, hope you fix it.
Please Rate, thanks!
Jan 16, 2010 | Sony PlayStation Portable (PSP) Console
Won't boot. Power light on, No Video Signal message
It's also possible that your operating system has become corrupted. See if there is enough time to boot into safe mode, or choose a boot option to go into the recovery partition.
Have you made any recent hardware or software modifications?
Dec 12, 2008 | Gateway Media Center 610XL PC Desktop
Tv won't stay on
Hello mrscarpenter,
This is a common problem with the ITC222 chassis, I would check CP120, CP140, CP150 to see if they are bad I suspect CP150 is the one that is bad. Its value is 2200uf 16VDC. It is located on the same board as the IHVT and is in between the Heat sink in the middle of the board.
I hope this helps,
Shuttle83
http://www.electron-age-technologies-llc.com
Dec 04, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
74 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
