Question about E-Machines eMachines Desktop PC
I keep getting this error message. This USB device can perform faster if you connect it to a hi-speed USB 2.0 port. For a list of available ports, click here.
    Scholar:
  • 113 Answers
It means you have the USB low speed connection. If you have plug in the device in front of the CPU it prompt it sometimes, try it at the back if it still wouldn't work out. Install the USB driver to 2.0 version or higher. thats it
Posted on Dec 14, 2008
Recently, when I insert a USB flash drive into my laptop's USB port, I get the message: This USB device can perform faster if you connect it to a HI-SPEED USB 2.0 port.
Your laptop has USB1 port and the USB 2 message will appear if you plug an USB 2 device into this USB port.
You maybe able to upgrade the USB port to USB 2 if there is a BIOS upgrade available from the laptop manufacturer's WEB site.
If not you maybe able to get an USB 2 PCMCIA card to install into the PCMCAI slot on your laptop.
Dec 04, 2012 | Computers & Internet
USB Port can preform faster error message
This is because you are plugging in a USB 2 device to a standard USB port, or a USB 3 device into a USB 2 port. The computer is just telling you that if you upgrade the hardware, the device will work faster. Its more of an information message than an error. Your device should still function fine.
Jun 28, 2012 | Dell XPS M1530 Laptop
I keep getting message saying my pc will run faster with 2.0 hi-speed host. how do i get it
Hi! Welcome to FixYa!
USB versions are USB ver 1.1 and USB 2.0 and USB 2.0 has faster transfer rate.
When you're receiving this kind of message, that means you're using a USB device that is compatible with USB 2.0. This happens when you plugged in a USB 2.0 device to a USB 1.1 port on your computer. It simply notifies you that the USB device can perform faster when you have an available USB 2.0 port. I'm not really sure what kind of computer you have and what version of windows you have but you can actually check if you have USB 2.0 by going to Device Manager, click on Universal Serial Bus Controllers and look for "USB2 Enhanced Host Controller" if you don't have this, that means your computer has no USB 2.0 port. Hope this helps.
Jul 02, 2011 | Computers & Internet
USB's slow and external drive
For the USB ports, you may want to verify that the drivers for the "enhanced USB" are up to date and for USB 2.0 or 1.1. USB 2.0 ports are generally backwards compatible for 1.1 devices. The "enhanced" does indicate USB 2.0 controller. 30mins to backup 3GB to your external drive is a VERY long time. USB 2.0 transfers data up to 480mbps, but if you get an error message indicating that the device can perform faster on a 2.0 port, you maybe transferring data at 12mbps which is USB 1.1 speed
To speed up the transferring of data, identify which USB contoller in Device Manager is the USB port you're having a problem with, and delete it from Device Manager. Then, plug in your external drive into a USB port its never used before.
As for the naming of hard drives, Hitachi partners with several drive manufacturers including Dell and IBM.
Feb 22, 2010 | Philips Computers & Internet
USB error message
you might need the intel chip set drivers available from HP ... sometimes you have to remove the USB ports in Device Manager .. then reboot .. that will reload the USB drivers ..
here is a discussion about that problem
http://forums13.itrc.hp.com/service/forums/bizsupport/questionanswer.do?prodSeriesId=1847703&prodTypeId=321957&threadId=1217468&admit=109447627+1258886634148+28353475
Nov 22, 2009 | HP Compaq nc6400 Notebook
G'Day! I have a Transcend 2 GB USB stick. Whenever I connect it to my computer or any other computer, I get this error message ''THIS USB DEVICE CAN PERFORM FASTER IF YOU CONNNECT IT TO HIGH SPEED USB 2.0...
Yes. The problem is you don't have usb 2.0 ports on your motherboard. Its the second generation usb port. So if you want to upgrade you can buy additional hardware to upgrade this. But your motherboard has to be compatible with that additional peripheral too. As an example buses of your motherboard. So you have to check that also when you purchase. This is not a problem. The only thing is it will reduce the efficiency of your pen drive (Access time etc.). Other usb sticks you have may be usb 1.1 devices.
If this is helpful to you, please rate this .
Thanks.
Jun 15, 2009 | Computers & Internet
Location of USB Root Hub
Hi dottyo,
Generally the front USB ports on a computer are USB version 1.1, good for USB keyboard and mouse or printer.
But, almost always the USB ports on the back of the pc are USB version 2.0 which is what you are looking for. Try any ports on the back of the pc case.
Hope that helps!
Jan 03, 2009 | Dell OptiPlex 170L PC Desktop
Usb 2.0
this is a common error with operating systems and devices.
If you go into my Computer/system/device manager. And remove the installed USB devices. shutdown the computer, and reboot it. then try putting your USB device in.
What general happens, is that if you have had an older device in the USB port at any time, the port configures itself to this setting. options are to try another port on the computer ( some older ports only support usb1.1 )
ensure you have up to date drivers on the connecting device and on the connecting computer.
Hope this helps Mike @ Compurepair.
Feb 22, 2008 | ASUS M2A-VM (0610839149438) Motherboard
USB2 high speed not recognize
Try opening up the device manager and unistall everything in the Universal Serial Bus Controllers. Then reboot and let windows reinstall the USB controllers. Windows should now be able to recognize properly USB2 devices.
Ibm thinkpad a31p 2654
yes. your laptop has a onboard version 1.1 usb ports.
you can upgrade it by buying a usb 2.0 and connect it to your laptop
Jan 28, 2008 | Computers & Internet
E-Machines eMachines Desktop PC Logo
99 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
