Question about Lenovo ThinkPad X60 Tablet PC
My lenovo lcd 15' moniter has a display problem .please sugests. the colour in the moniter is not bright and the menu in moniter is locked.
  • Pritam Ray Dec 14, 2008
    i changed the inveter still my problem is not fixed. still the color in the lcd is bad.
My Lenovo, Y510 LCD monitor will not stay in the 90 degree position when open. It will just go flat. Has tightened all external screws with very little change. Please suggest.
Posted on Jan 14, 2009
  • 136 Answers
Your inverter is going bad. It will have to be replaced, there is no menu option to fix it.
Posted on Dec 14, 2008
  • Kevin Nelson Dec 14, 2008
    Check the Lenovo site for updated drivers, check windows updates for hardware updates.
IPad turns off after 5 minutes
Go to "Settings" and look under "Display & Brightness" on left side of screen. There you will see "Auto Lock." It may be set to "Automatically" Lock after 5 minutes. You can change it there to auto lock (shut down) from 2 minutes to "Never" if desired.
Apr 03, 2017 | Apple iPad Tablets & eReaders
How do I adjust brightness on hannspree tablet
Go to Settings, Display, Brightness. If you have never accessed Settings, do a finger slide from the edge of the screen where you see the battery indicator symbol, and you should see an option for Settings (or a small symbol at top right that looks like a cog such as you see where the chain connects to the back wheel on a bike). Selecting/touching that will open the full Settings menu. Then scroll down until you see Display, touch that, and then find Brightness and touch that. Then you should see a slider. You should also see an option for Automatic brightness control. Some tablets come with this selected by default. Choosing it will cause the tablet to brighten when outdoors or in a brightly lit room, and to dim automatically when lighting is low. I have never liked it, but it works for a lot of people who are not as picky as me, and can potentially allow your battery to last longer. Good luck and enjoy your tablet!
Jul 17, 2014 | Hannspree SN10T1 101 Tablet
My system is not display bright screen
This sounds like your backlight on the LCD screen has blown and may need replacing. Hope this helps.
Just make sure the brightness has not been turned down and you can check by connecting it to an external monitor to see if it works. If it does, then that will be your problem.
Hope this helps
Jul 29, 2011 | Fujitsu Tablets & eReaders
Ever since I downloaded Apple's latest iPad update my orientation lock has become a mute lock and I can't stop my orientation from moving. Any ideas?
In order to use orientation lock with the new update:
  1. Double-click the iPad's home button, bringing up the multitasking menu with all programs you are currently running.
  2. Swipe your finger to the left while in the multitasking area.
  3. The orientation lock is now controlled through a software feature rather than the physical mute button.
  4. Tap the orientation lock icon (circular arrow furthest to the left) to engage it.
  5. In this menu you can also quickly change brightness settings and music controls.
A new feature rumored in iOS 4.3 (the next iOS iteration) will allow for the iPad's user to set whether the physical button controls orientation, or act as a mute switch.
Feb 20, 2011 | Apple iPad (16 GB) WiFi Tablet PC
Thinkpad will not show anything on display when turned on
Hi, This issue is clearly hardware and might be related to 3 part, Inverter card, LCD cable or LCD Panel ( Or systemboard, just to make sure try with an external display if the issue reproduce it's systemboard/graphic card related, if not LCD related ). If you are still entitled to warranty then this hardware failure is covered by the terms. You should have the 3 parts stated below replaced as it s a common issue with Thinkpads.
In case you are out of warranty cover you still can try to subscribe to a warranty extension, you can check on www.lenovo.com , otherwise you might want to order theses parts on a website such as ebay. To swap the pieces requires quiet advanced skills as you have to take down the whole computer, obviously LCD Panel included. Unfortunalty this is hardware related, not much you can do... I hope this help ! Thanks and have a nice day ! J -
Apr 13, 2010 | Lenovo ThinkPad X61 Tablet
Stripes on Display, is there a way to repair?
If you have tried to reload the drivers and the same thing you still have stipes on the display... uuum i sugest change your screen.. normaly when LCD gets stripes no option but to change it.
cheers
Aug 27, 2008 | Fujitsu LifeBook T4210 Tablet PC
Monitor
If your LCD monitor has damage it could be in three forrmats:
1) Damage LCD ribbon. The screen will power up bright white and you will see random strings of color in diaganol or horizontal streaking slowly across your screen.
2) Damaged Liquid Crystal Container. The thin glass/plastic may have ruptured due to an impact on the screen. You will see sharp jagged lines and maybe a partial post screen, but where the sharp "jaggies" are, are now permantly broken
3) Nothing on screen. This indicates that your internal CCFL (oh I love LED technology) tubes have now lived their life and will not ignite. To test this method, hold a very bright light to the screen and see if you can see any logos (Compaq/HP/Win Xp loading screen...etc)
If you can see something, your screen is fine, but there is no light behind it for you to see.
Hope this helps.
Jun 05, 2008 | Compaq tc1000 Tablet PC
Display problem in Toshiba Satellite pro L20
did you try the FN and F8 key and try that see if that turns the lcd on. If not write back here and we can figure it out.
Dec 18, 2007 | Toshiba Satellite R10-S802TD Tablet PC
Screen brightness
Another way to adjust the screen brightness is to hold down the Functin key (blue, Fn) and then repeatedly press the up or down arrows (which also show the symbol for screen brightness on the keys in blue.)
Dec 09, 2007 | Gateway CX200S Tablet PC
Lenovo ThinkPad X60 Tablet PC Logo
363 people viewed this question
Top Lenovo Tablets & eReaders Experts
vojvodabudva
Are you a Lenovo Tablet and eReader Expert? Answer questions, earn points and help others
