Question about Kodak EasyShare M1033 Digital Camera Tripod
Wont Stay On
My Kodak m1033 will not stay on. Once I press the power, the screen is blurry and then it shuts off.
Help?
  • 2 more comments
  • agustin_ndon Dec 20, 2008
    I have the same problem, tried hiting it my couple of times but didn't work
  • Anonymous Jan 09, 2009
    My camera won't stay on and it also shows a blurry picture - HELP
  • kolacoley33 Apr 26, 2009
    I have the same problem, when i turn it on it is out of focus but then it just shuts off
  • piperacing May 01, 2009
    if i press the power and picture botton it stays on for a minute, and if i put in a unformated memory card it stays on and tries to format it but it stays there for ever
I fixed it, I hit it softly a couple of times lol.
Posted on Dec 14, 2008
2 Suggested Answers
shockwave727
  • 262 Answers
SOURCE: My Kodak m1033 will not stay on. Once I press the
If your using the battery which is included on the box the KLIC-7004 try to clean the 3 metal contacts of your battery using a clean dry cloth. hen charged the battery using AC adaptor or USB cable., Now if this not work, Try to turn On the camera using the AC adaptor if you experienced same problem it means the your camera is defective, But if you can turn On the camera using AC adaptor It means the battery is the cause of the problem
You may call tech support toll free 1 800 235 6325 ext 12
Posted on Nov 13, 2009
Camera turns on, and then turns off again right away
My M1033 had the same problem...I found a blog about someone using air to clean around the lens area...I cleaned my lens very thoroughly and noticed some gunk and once I cleaned this off, the camera seems to work like new!
Apr 05, 2010 | Kodak EasyShare M1033 Digital Camera
Nov 13, 2009 | Kodak EasyShare M1033 Digital Camera ...
My M1033 will power on and then it just powers
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 01, 2009 | Kodak EasyShare M1033 Digital Camera
It won't stay powered up
Hi!
Either the lens stucks in outter position or the focus is stuck. It's hard to tell without seeing it and taking apart the camera and lens. You should give it to a local repair shop or Kodak service center.
I work in Kodak service center.
Tom
Sep 26, 2009 | Kodak EasyShare M1033 - black Digital...
Kodak M1033 shuts off
The problem you describe is frequently the result of dirty/corroded battery contacts in the camera. Try removing the batteries and cleaning the inside contacts with a fine wire brush, steel wool, or fine sandpaper. Remove any residue left from the cleaning, then replace the batteries. Hopefully all will be well.
If the cleaning doesn't work you might want to check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Aug 03, 2009 | Kodak EasyShare M1033 Digital Camera
The Same problem
I'm not sure why this works for me, but I think it's worth a try:
1) First, take your SD card out of the camera.
2) Then turn on your camera and let it turn itself off.
3) Read the next step first and be ready to press the shutter release button (take a picture) right after the LCD screen turns on
4) With the camera lens pointed down towards the floor (aim down), turn on the camera. At this point the LCD screen should not be blurry anymore. Immediately press the shutter release after confirming that the LCD is not blurry. If the camera stays on and you can review the picture (most likely of your feet), then you are almost done.
5) Turn off the camera and re-insert your SD card.
5) This may not be a permanent fix, but point the camera lens downward whenever you turn on the camera. It should work normally if you do this. Mine worked normally (meaning I don't have to point it downward when I turn it on) after doing this several times. Your results may vary.
Jun 05, 2009 | Kodak EasyShare M1033 Digital Camera
I have a Kodak M1033 camera that I bought just over 6 months ago. I took it on holiday it worked fine and then suddenly it switched off. Since then it only powers up for about 5 seconds, shows a unfoc
Jun 02, 2009 | Kodak EasyShare M1033 - black Digital...
I have a kodak m1033 turns on then shuts right off
May 18, 2009 | Kodak EasyShare M1033 Digital Camera
My Kodak M1033 camera, the screen is totally blurry.
Your problem is either likely the lens or a sensor. However kodak does not sell just the lens and out of warranty repair is 70.00. Screw them guys! Ill send it some wheres else to fix. Its less than a year old, I lost the recipt and can't read a few numbers on the sticker for the serial number. So basically he tried to sell me a new camera for 15% off, when the camera cost more now then it did when i got at Walmart!
Jan 05, 2009 | Kodak EasyShare M1033 Digital Camera ...
Kodak EasyShare M1033 Digital Camera  Tripod Logo
563 people viewed this question
Top Kodak Photography Experts
Bill Eager
micky dee
Are you a Kodak Photography Expert? Answer questions, earn points and help others
