Question about Compaq Presario Notebook
Presario won't hybernate
I just replaced the hard drive in my Compaq Presario, and now it will not hybernate. It continues to run, even with the lid closed. Then it overheats. HELP!!
  • pgarv Dec 16, 2008
    Thanks for answering. i found the power button, but there was no hybernate tab. The closest thing was under the advanced tab. There was a question "When the lid is closed:", but the ONLY option was "Do nothing". --?!!!!
  • 136 Answers
Right click on the desktop
select properties
select screen saver
click the power button
click the hibernate tab
make sure the Enable Hibernation box is checked
Posted on Dec 14, 2008
  • Kevin Nelson Dec 16, 2008
    Could it be that your new hard drive does not meet the requirements for hibernation? What version of Windows are you running and is it currently updated?
    On Windows computers, hibernation is available only if all the hardware is ACPI compliant, Plug-and-play and all the drivers are PnP-compatible.
No bootable device - insert boot disk.
press F8 continuously after you turn on the laptop, then you will see a bios screen. Look if hard disk is detected in bios
May 20, 2012 | Compaq Presario CQ60-220US PC Laptop
I have compaq presario 5000 and I'm having problem
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they might be faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electical extensions
even something as small as an electrical fan and its lead can cause this problem or just replace them they could be faulty a computer needs all electrical power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
restart your computer then reinstall it this should activate found new hardware wizard
hope this helps you
Oct 21, 2011 | Compaq Computers & Internet
How do i remove my compaq presario 2200's hard drive?
The Compaq Presario line is one of the longest-running series of computers, originating in 1993 and remaining in production even after the purchase of Compaq by HP. Because of this, many Compaq Presario desktops have required that some of their parts be upgraded or replaced because of the wear that they have received over years of standard use. One of the more commonly replaced Presario desktop components is the hard drives, especially given how much hard drivemag-glass_10x10.gif storage capacity has increased since the Compaq Presario line was introduced. Replacing a hard drive in a Compaq Presario desktop isn't difficult, and can usually be done in a matter of minutes even for users who aren't familiar with computer upgrades.
structions
  1. Step 1Remove the screws holding the left side panel of the computer on, then slide the panel back to remove it. Set both the panel and the screws aside so that you can put the panel back in place once the hard drive has been replaced.
  2. Step 2Unplug the ATA (wide, flat and usually gray) or SATA (thicker, thin and red) data cable and the power cable from the back of the hard drive that is currently in the Compaq Presario. Move the cables so that they will be out of the way, but make sure that they will still be easily accessible to you so that you can plug them into the new hard drive.
Aug 08, 2010 | HP Compaq Presario 2200 Notebook
MY cOMPAQ pRESARIO CQ60 fell and cant complete boot
Most likely in this case, the damage is to the hard drive or its connection to the motherboard. The CQ series though has a three point screw attachment for the hard drive so Im more inclined to think that the shock of the landing has damaged the read/write head on the hard drive. If you happen to have another hard drive for a laptop, try installing a new drive and run the installation disc and see if it will complete and boot completely....if it will then the problem was the old drive.
May 23, 2010 | HP Compaq Presario CQ60-249US Notebook
Remove hd compaq presario 1621
I think it is the same as HP. When you undo the cover just pull it right out by the small plastic. No screws holding the drive.
Apr 21, 2010 | Compaq Presario Notebook
Running home ed windows on presario v2000 (now five yrs old) windows loads but harddrive continues to run inefectually - cant access programmes etc - then screen turns blank after approx 20-30mins - hard...
Backup your programs immediately to a thumb drive or external HD. The hard drive may be on the brink of failing. You can replace a hard drive, it's your information thats on it that you may not be able to if it totally crashes!
Mar 20, 2010 | HP Compaq Presario V2000 Notebook
The compaq presario v3000 replace hard drive
Yes of course you can install the Seagate Mementus 160GB, the laptop will take a dive with a 320GB capacity.
Regards.
Dec 02, 2009 | Compaq Presario Notebook
Error loading operating system
If you take a hard drive for one computer to another the windows wil have to be reinstalled as windows looks at the hardware configuation and if it doesn not match, will not run. If the 20 gb hard is working , reinstall it then using backup software back it up to another hard drive.That will work. Personally I use" Acronis true home" software to change a hard drive but their  are other  wil also work. Some  backup and transfer softwware even come with the replacment hard drives.
Dec 10, 2008 | Compaq Presario 5000 PC Desktop
Compaq 6715B
If your computer will turn on, get to the page where you have the options on how to boot the computer. Slect the option to boot from your hard drive. If it still will not boot up, then you are probably going to just have to repair your OS or do a clean install of your OS.
Sep 04, 2008 | Compaq Presario Notebook
Compaq Presario Notebook Logo
99 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
