Question about HP C7200-69016 Network Adapter
HP C7200 All In One Printer
Brand new printer, screen says Incorrect Ink Cartridges, The followin ink cartridges cannot be used after device initialization and must be replaced. It shows all ink cartridges. I opened it up and have removed all of them and replaced, Unplugged the printer but still get the same error
    President:
  • 8,637 Answers
Try this:
First make sure you are placing the right
color cartridge into the right slot.
Most Printers are touchy about the
installation of ink cartridges. If the
instructions say to press the cartridge
into the slot until you hear a loud click,
that's what they mean. If at first you
don't succeed, remove the cartridge and
reinsert it into the slot again and press
on it hard till it clicks.
Then your printer should work properly.
Hope this is of some help. Bud
Posted on Jul 20, 2010
Ink threshold exceeded
Sad to say I know how to fix this.
1. Power up the printer
2. set printer's date to the current day.
3. On the keypad press the * and # keys together
Now press one at a time 1,2,3 for the code
"screen stould display a white backround with 2 lines of info"
4. remove all the print cartridges
5. Press the >> arrow button twice until "reset menu" is found
6. Press OK
7. Select Partially full reset Press ok
( the printer will take almost to minutes before it powers down)
8. Power up the printer and follow the steps.
reinstall ink ect......
I don't know why this happens but I sure a lot of printers are in the trash because of this. If you print out a SELF TEST REPORT the
dates on the age of the ink Cartridges are likely out of life range.
Planned obsolescence by HP can be found all over the web. This could be one of those.
HP Photosmart 3000 C6100 C7200 PSC 7280 Printers HP 02 Cartridge...
Press the helpfull Thanks!!!!
Feb 04, 2014 | PrintCountry HP Photosmart C6280 Inkjet...
Refill cartridges
Sandra- some ink jet printer manufacturers are proprietary and use ink cartridges manufactured with "timers" built into them- making it almost impossible for the end-user to re-use them.
You mentioned that you refilled the cartridges; and without knowing what you actually mean by that, I will have to ask you; did you refill the cartridges yourself, or did you send them out to a third-party vendor?
Or perhaps, you are using a generic brand?
All of which can be problematic, if your particular model printer (not all) uses ink expiration technology on their ink cartridges or proprietary technology.
What does this mean? Ink expiration is a built-in date in which certain ink cartridges will stop working; even when there is still ink in them. Manufacturers like HP, claim that it uses such technology to protect the printing systems print-head and ink supply (which are two separate and distinct physical properties on certain printers).
Which now begs the question, does your printer have print-heads that are separate from the ink cartridges?
BTW, ink cartridge nozzles can dry out and block the flow of ink from its reservoir. You can try to manually clean the printer cartridges by using a q-tip swab dipped in rubbing alcohol until it is completely clean.
On a final note, another possibility in the troubleshooting process, reset the ink cartridges chip to full.
1) You can buy a universal ink cartridge resetting tool online or at a local computer or electronic store.
2.) When you do, remove the ink cartridges out of their holding carriages.
3.) Line up the device pins on the resetting tool and the chip on the cartridge. Press the pins and the chip together until they connect.
4.) Keep the pins and the chip connected until the device's LED light turns green (usually takes 10 seconds)- the chip on the ink cartridge will have reset.
5.) Reinsert the ink cartridge into the printer's ink carraige and print a test page. The printer should recognize the ink cartridge.
If all else fails and as a last resort, you will have to buy a brand new proprietary ink cartridge
Please keep me posted.
Nov 17, 2013 | Lexmark X5070 ALL-IN-ONE InkJet Printer
The black printer cartridge leaked a fair amount of ink in to the printer. I am getting all lights flashing and the printer won't even turn off when I hit the power button. I did some cleaning and it...
Sorry to hear that.. here are some instructions that should help you out:
Instructions
things you'll need: Microfiber cloth
1. Ink Cartridge Errors
2. Turn the printer on and open the ink cartridge cover. Wait for the cartridge carriage to stop completely before reaching into the printer.
3. Press on the top of each print cartridge, then pull the cartridges free from the carriage. Make sure you are only using HP cartridges labeled as "HP 60" or "HP 60XL."
4. Reinstall the ink cartridges and close the cover. If the ink cartridge error message displays again, remove the ink cartridges as before.
5. Clean the copper metal contacts on the cartridges using a dry microfiber cloth. If you still see the error message after you reinstall the ink cartridges, replace hem with new cartridges.
Print using the device's ink backup mode if you do not have a replacement for one of the cartridges. Remove the cartridge you cannot replace and close the cover and continue printing. The printer will automatically use the backup mode until you install a new cartridge.
Mar 21, 2011 | HP DeskJet F4280 All In One Printer InkJet
What does 'Print Cartridge in right stall not supported' mean?
It means you have a faulty or incorrect cartridge installed on the right side position. It could also mean the contacts are dirty or misaligned. Remove the cartridge, clean with rubbing alcohol and reinstall.
This is not a unknown error particularly if you are using cartridges other than the HP brand. Other people will tell you it is fine to use off brand cartridges or refilled cartridges. For myself, I have never had luck doing that - on the other hand, I have never been disappointed using the more expensive cartridges recommended by the manufacturer across several brands including Epson, Canon, Compaq and HP.
Try cleaning the contacts and ink jets. You may have to replace the cartridge. If that is the case, I would return the faulty cartridge and get a store credit.
Just a few thoughts for you to consider. Thank you for using FixYa.com today.
Mar 03, 2011 | HP PSC 2355 All-In-One InkJet Printer
Printer will not accept new cartridges. Printer is new and wants original cartridges to initialize ink system. Original cartridges are not availible. Tryed reset but did not work.
HP printers will not accept refilled cartridges. Are you trying to replace your empty cartridges with refilled cartridges? There is a computer chip in the ink cartridge that tells the printer when it is out of ink. If you try and refill it yourself, the printer will not recognize that it has been refilled without replacing the computer chip in it.
I think your printer is telling you that it needs HP brand cartridges that are original and not refilled cartridges. There is no way to "reset" an hp printer to get it to use an off brand or refilled cartridge that has not had the chip changed.
You can pick up a good refilled cartridge at a professional company who knows about changing the chip for less then a third of the regular price of an HP cartridge in a department store. However, HP does not want you to use refilled cartridges and should something go wrong with your computer and they find out that you were using them they will void your warranty on your printer.
If you are not trying to replace HP brand cartridges with refilled or off brand versions, I suggest your return them to where you bought them and exchange them. They may be defective cartridges.
Hope this helps?
Nov 11, 2010 | HP C6250 InkJet Printer
Ink cartridge cannot be used after initialization
The following are common issues.
The following ink cartridges cannot be used after device initialization and must be replaced
Cause The wrong ink cartridge(s) are installed.
Solution The indicated ink cartridge(s) cannot be used after the device has undergone first time setup. Replace the ink cartridge(s) with the appropriate ink cartridges for the HP All-in-One. To find out the reorder number for all the ink cartridges that the HP All-in-One supports, see the printed documentation that came with the HP All-in-One.
If you are using compatible cartridges make sure they are reset for use.
Ink cartridge problem
Cause The indicated ink cartridge(s) are missing or are damaged.
Solution Replace the indicated ink cartridge(s) immediately so that you can resume printing. If there are no ink cartridges missing from the HP All-in-One, the ink cartridge contacts might need to be cleaned. If there are no ink cartridges missing from the HP All-in-One, and you still receive this message after cleaning the ink cartridge contacts, you might have a damaged ink cartridge.
Sep 21, 2009 | HP Photosmart C5180 All-In-One InkJet...
Says cartridge cannot be used after initialization but brand new HP 363 cartridge sent directly by HP to me. This happens ever time I put a new cartridge in when prompted by printer to do so. Do I put new...
Sep 21, 2009 | HP Photosmart 3310 Printer
HP Photosmart 3310 printer shows all ink cartridges need replaced
If you ran the ink cartridge refill routine, from your desktop using the utility supplied by HP, this should not occur, so try running the head cleaning and alignment routines and see if this clears up the problems.
I am assuming that all your cartridges are relatively full and trouble free and that the printer has been successfully and recently used, prior to your replacement of the one new cartridge.
Sometimes, if the printer has been idle for some time without use, the ink will dry on the heads of perfectly good cartridges, causing the problem you cite.
Use alchohol based cleaner with the kind pads supplied with a new cartridge to regularly clean the heads of your ink cartridges, according to instructions in your manual and CAREFULLY, so as to not damage the heads.
Apr 07, 2009 | HP Photosmart 3310 Printer
I just purchased an HP Photosmart C7200 All-in-one printer, loaded the ink cartridges and the screen says the magenta cartridge appears to be missing or damaged. I put in a new cartridge- same message...
Hi
If the printer is out of the Box, don not try any other ink cartridges, becoz you must use the HOST ink cartridges that is shipped with the printer for the first time.It seems that it is problem with Host ink cartridge.
You can check the cartridge whether its a Host ink cartridge or normal one by looking at the serial number.If Serial number starts with C9, it Host; if it starts with C8 its normal one.
Only HP can replace it , none of the store sells Host ink cartridges, they sell the replacement ones.
You can either call HP tech support or, return the printer to staples.
Thank You
Rizwan
rizwan84tx@gmail.com
Dec 07, 2008 | HP Office Equipment & Supplies
HP Deskjet 648C printer
Just a suggestion: Have you tried using a different ink cartridge? I have found brand new cartridges to be bad right out of the wrapper.
Aug 29, 2008 | HP DeskJet 648c InkJet Printer
Computers & Internet Logo
586 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
