Question about Acer Aspire 5050-3242 Notebook
Computer boots up to password then freezes the pad and key board and won't start up.
    Scholar:
  • 113 Answers
When you turn on your computer press the setup button (del), go to the CMOS setup, reset it to the default or optimized default settings, then save it and restart. if you can't get in and prompt you again that it has a password bring to the service center near you they to short circuit the battery which is the jumper setting to erase the password.
Posted on Dec 14, 2008
Cannot uninstall deep freeze
uninstall it using administrator password
May 10, 2011 | Computers & Internet
How i uninstall deep freeze software
HI Good day!! do the following
Disable Deep Freeze before uninstalling it.
To disable Deep Freeze:
1. Hold down the shift key and double-click the Deep Freeze icon. Alternatively, you can press CTRL+ALT+SHIFT+F6.
2. Enter your password and click OK.
3. If you have not yet entered a password you should be able to click OK without entering a password.
4. The Boot Options dialog is displayed. Select "Boot Thawed" and click OK. This will disable Deep Freeze on the next reboot.
5. Reboot your computer. After the computer reboots, you are ready to uninstall Deep Freeze.
To uninstall:
1. Locate the installation file you used to install Deep Freeze on your computer. By default, the name of this file is called "DF5Std.exe" for versions 5.X and "DF6Std.exe" for versions 6.X.
2. Run the installation file (DF5Std.exe or DF6Std.exe).
3. Select the option to "Uninstall"
Deep Freeze is uninstalled and your computer is rebooted.
Oct 12, 2010 | Computers & Internet
How to disable deep freeze without a password
How to Uninstall Deep Freeze for Windows 2000/XP/Vista without the password.
Note: Without a complete uninstallation you may not be able to reinstall Deep Freeze on your system.
What we are going to do is edit the registry and delete the startup references to Deep Freeze. This will prevent the Deep Freeze driver from starting up the next time you boot. (c:\windows\system32\drivers\deepfrz.sys)
1. First we need a way to edit the registry. The way to do this depends on your situation. If your computer is thawed you can simply use Regedit. If your computer is frozen or if it doesn't boot you'll need to find another way. Here are some alternatives:
If you have a multiboot computer with another copy of Windows 2K/XP you can boot from there. Or, you can physically mount the disk on another computer that uses Windows 2K/XP.
You will probably use a tool that lets you boot and edit the registry. A good example of this is PE Builder that lets you build a Windows PE CD and boot Windows from there. Or use Bart's, http://www.nu2.nu/pebuilder/ or Winternals ERD Commander. There are several, including some USB memory sticks capable of booting like a CD. The goal here is to boot separately from your hard drive and access it while it is "asleep".
2. If your computer is thawed run Regedit. If it's not thawed follow one of the alternatives described above, and run Regedit (or Regedt32 on Windows 2K).
3. On the Find dialog box type UpperFilters and check only the Values checkbox. Then click Find Next.
4. The program will find a value with the name UpperFilters. Open this value and if there's a line with the name of the Deep Freeze driver (DeepFrz or DepFrzLo) delete it including the return, leaving the rest of the lines intact. Also, if you are using ThawSpace and you want to get rid of it delete that line too (ThwSpace), if you want to keep the ThawSpace leave it there. Press F3 to find the next match and repeat the operation until you have fixed all the UpperFilters values inside the HKLM\MySystem key.
5. Navigate to HKLM\MySystem\Select and check the value with the name Default. It has the number of the control set key that the system will use when booted. If it is 1 the control set is ControlSet001, if it is 2 the control set is ControlSet002, and so on. We'll assume the control set is ControlSet001 but you should use the one specified by the value Default.
6. Now go to HKLM\MySystem\ControlSet001\Services and delete the keys with the name of the Deep Freeze drivers (DeepFrz or DepFrzLo and DepFrzHi). Also, if you decided to get rid of the ThawSpace delete the key with the name of the ThawSpace driver (ThwSpace).
7. That's it. Now reboot and Deep Freeze will not load.
QUESTION: What if the BIOS settings prevent me from booting from CD or USB? Answer: Deep Freeze prevents you from decrypting the BIOS password, but it does not prevent removing it, if you have the right tool! Most of the BIOS hacking programs will not work to remove the BIOS password on a Deep Freeze protected computer, but CmosPwd by Christophe Grenier does.
You'll need to know how to use a command line and install the driver. Yes, it uses a driver to remove the BIOS password. But it works, even on Deep Freeze protected computers. Use CmosPwd to remove the BIOS password and reset the default BIOS settings. Then you'll be able to boot from CD or USB and edit your computer's registry and remove the DeepFrz, DepFrzLo, and DepFrzHi references which start Deep Freeze.
Now here is a little known secret: Faronics (the makers of Deep Freeze) uses a special driver to remove broken or malicious Deep Freeze installations. They do not have any backdoor passwords, so they use a special driver to remove a Deep Freeze installation where the password is not known or that someone is having trouble with. Will they send it to you, or even admit to you that they have it? I don't know. But, even if you do have it, you will still have to boot separately from the hard drive and replace the existing Deep Freeze driver with the special one and reboot. And after that, you need to use a Deep Freeze installation file to fully uninstall Deep Freeze (it will be thawed when you boot up with the special driver). If you want to re-install Deep Freeze, you'll have to first delete the special driver too.
Only a few people have this driver. It is the only solution Faronics has for those who need to remove Deep Freeze without the password. And, like I said, you will have to be able to boot from CD or USB and access the NTFS hard drive. If the boot-up order is locked (hard drive first and only) in BIOS settings, use CmosPwd to reset BIOS and boot order. Then you can boot from CD or USB.
Booting from CD or USB and removing the registry references works also, but then you should uninstall Deep Freeze with an installation file once you are able to boot thawed.
If you are dealing with a trial version of Deep Freeze, just forward the BIOS date past 60 days and then restart.
If anyone is wondering if Deep Freeze has ever been hacked, the answer is "yes" it has, several times over the years. Most of the time these were weaknesses that Faronics was able to quickly fix or prevent. However, there was one hacker that really, REALLY gave them headaches. His name was Emiiano Scavuzzo from Argentina. He was really good at low level programming and used OllyDbg to come up with about five versions of his "Deep Unfreezer" which gave Faronics their greatest challenge to date. Deep Unfreezer now only works on older versions of Deep Freeze.
Faronics is doing very, very well right now (as of 2008). They sold Apple Computer their Mac version of Deep Freeze, which, if you know how to look for it in the Applications folder on a Mac, is used in all the Apple Stores on both their desktops and their laptops. So, if you're ever in a Mac store playing around with PhotoBooth or whatever, and the computer settings are all messed up, just restart the Mac and thank Deep Freeze.
Apr 11, 2010 | Computers & Internet
Can't access laptop computer in safe mode, keyboard freeze up
Try booting your system from a LIVE cd like linux, a verson of Hiren's tools, or the UBCD (ultimate boot disc for windows). If your keyboard still freezes with the alternate OS, you may have a hardware malfunction.
Jan 18, 2010 | Compaq Computers & Internet
How to un instaill deep freeze
To uninstall:
for more, you can visit Faronics site (http://www.faronics.com)
regards,
dzilog
Jan 10, 2010 | Computers & Internet
Toshiba l300 1bv bios password forgotten
Download and flash your BIOS to the newest version for your make and model. You have four to choose from. There are known issues with Toshiba BIOS's, this is one of them.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
Hope this helps.
Edit: some notebooks use "Toshiba" or "toshiba" for their password.
Or try this: From Toshiba website http://tinyurl.com/dkoudz
ESC key BIOS Password setting procedure
1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the Esc key, until the message "Check system Then press (F1) key" appears on the screen.
2. Press the F1 key. The BIOS setup program will appear.
3. Using the arrow keys or the tab key, move to the Password field, and highlight NOT REGISTERED.
4. Press the spacebar, and then enter a new password at the "Password = " prompt. Press the Enter key.
5. Enter the password again when the Setup program prompts for it, and press Enter. The Password field will change to REGISTERED.
6. Press the End key and then the Y key to save changes and exit the BIOS Setup program.
F2 key BIOS Password setting procedure
1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the F2 key.
2. The BIOS setup program should appear. If Windows starts, shut down the computer and try step 1 again.
3. Use the arrow keys to move to the Security tab.
4. Use the arrow keys to select "Set User Password". (This 'User Password' is equivalent to what is otherwise called, in this document, a 'BIOS Password'.)
(It may be necessary to set a supervisor password before setting a user password. A Supervisor Password may be thought of as a backup mechanism -- if a User Password is forgotten, the Supervisor Password will allow access to the computer. The next section describes how to set a Supervisor Password.)
5. Press the F5 or the F6 key to navigate to the Password section. Type in a new password at the "Password = " prompt, and then press the Enter key.
6. Enter the password again when the Setup program prompts for it, and press Enter. The password field will now change to indicate that a password has been entered.
7. Optionally, set the Password on Boot feature to 'Enable'. Otherwise the computer may not prompt for the password at startup.
8. Press the F10 key to save changes and exit the BIOS Setup program.
this might be what you are after
http://www.pwcrack.com/bios.shtml
Also have you read through this site?
http://www.tech-faq.com/reset-bios-password.shtml
Dec 16, 2009 | Toshiba Computers & Internet
Deep freeze feronics V6 satandart
Double click to the taskbar Deep Freeze icon while pressing the Shift key, If it is password protected, give the password. Select Boot Thawed from Boot Control and restart your computer. Now open your Deep Freeze installation file (by which you have installed it). Now you will have the option to uninstall it.
Enjoy...
Apr 22, 2009 | Computers & Internet
Want to uninstall deep freeze
Give this a go....
To uninstall:
Hope this helps.
Andy
Dec 15, 2008 | Computers & Internet
TOUCHPAD, MANUAL KEY PAD QUESTION
Boot into safe mode and uninstall the yahoo software that started the problem.Press F8 at start up.
May 31, 2008 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5050-3242 Notebook Logo
27 people viewed this question
Brian Sullivan
Brian Sullivan
Mohammed Ebrahim M
Mohammed Ebrahim M
