Question about IBM ThinkPad 600E 2645 Notebook
Help how do i restore windows xp on my tkinkpad
  • 3 more comments
  • vmalhotra200 Jan 10, 2009
    Just like many out there I have the
    Error code 00174
    DEU 001
    Error 91
    FRU 3610
    appears to be very common but workable problem I'm about to follow some of the advice out there and see how it works out.Meantime any input on the Bttery Pack cost and retailers?Looking for one in Canada..South-western Ontario?Pls help secure peace of mind..
  • vmalhotra200 Jan 19, 2009
    Thx rob i'm going give it a shot as u hav recommended..
    Meantime here is the run up of the issue::
    TP 600E the work horse has been kind to me but now::
    As I boot the system normal ibm page starts n all..then error 174
    expanded n searched the codes n find that relates to CONF issue
    further expanede on that then find..error identified as 190303..that relates to HDD issue..NOT CONNECTED...??
    Ran the test page n all is good BUt the error msg as in original post..
    Error code 00174
    DEU 001
    Error 91
    FRU 3610
    ADVANCED TEST show :::HDD not connected...
    Open the HDD compartment n RESIT the HDD (it's a Toshiba product)
    ERROR LOG show NO ERROR LOGGED
    All related test show PK in BLUE..
    BTW HDD is not highlighted in the test page either?
    In fact after this happened the first time and i resi the HDD after a few attempts the TP booted as normal and run thru three days.BTW i didn't shut it off during this time then I RESTARTED n the TP REBOOTED OK ..so I shut it off .then again .. next morning NO SHOW n back to error 174 n all else...as above..??
    Looking fwd 2ur prompt response to address this asap..Plz do indicate the CONF sequence on the HDD on the BIOS page(easy set up) indicate the other related CONF aspects to verify for me..thx ahead..regards..
    SORRY the HDD error code displayed is 190305
    and NOT 190303 as in prev post ...just in the same CONF issue related with primary error msg 0174..thx again
  • Rob Houg
    Rob Houg May 11, 2010
    Try f11 when booting or try ctrl f11 when rebooting pc. If that doesn't help let me know
  • JDTec
    JDTec May 11, 2010
    Thie laptop came with Win98. If you installed XP, you need to find the XP cd and the license key yo reinstall XP.
  • 1,602 Answers
If the cmos is the problem or not sure remove the screws and find the batteries connection or buy a new one and get batteries anywhere in the world.....
cmos error, the battery for the cmos needs to replaced or look to see on the motherboard some thing with 2 or 4 pins or jumpers,
next to the jumper will habe in writting batt. or symbol big dash and little dash and big dash and little dash with lines in the middle of the dashs indicating line meaning leads or connectors for a battery device, buy the battery pack or remove the silver round disk on the motherboard and take it to anystore that carries that type of battery or batteries plus located all over the usa, foreign countries computer or electronic store, computer junk yard would even have them.
buy the battery pack that hold 4 batteries and you replace them without having to drive around looking for batties becuase that one takes AAs or AAA's and the are 1.5volts too and you can figure out how much power you need.
rod
ps the best way and the cheapiet to find out if you have to buy a whole new motherboard first!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Posted on Feb 11, 2009
How do I do a factory reset from safe mode with command prompt? windows xp
Restoring Windows XP operating system can be performed in DOS mode if XP's system restore tool cannot be accessed because of booting issues or when the XP recovery CDs are unavailable. There are two steps to this procedure: first, the XP system restore tool must be accessed using the DOS menu and second, the actual XP system restore is performed.
Start the computer and press the F8 key when the manufacturer's logo appears but before the Windows XP logo appears. Scroll through the menu options using the down arrow key. Select "Safe mode with a Command prompt" and hit the Enter key. Type in the administrator ID and password. Hit "Enter." Type in this code in the command prompt box to access the XP system restore tool: %systemroot%\system32\restore\rstrui.exe. Hit "Enter." The XP system restore tool will open. b> How to Restore Windows XP b> Click "Restore my Computer to an Earlier Time" when the XP system restore tool starts. Click "Next." Choose a restore point before your operating system began to malfunction. Click "Next" and "OK." Click "Next" to begin the XP restoration process. Do not turn off the computer or attempt to stop the system restore tool, as this may damage the hard drive. The system restore tool will automatically restart the computer when it has finished restoring the operating system. Hope this helps.
Dec 12, 2012 | Computers & Internet
How to install windows xp in toshiba qosmio f30-112
If the Notebook cannot find the device driver it is looking for then use this restore disk for an easy solution.
WINDOWS IS NOT ON THIS RESTORE DISK
This restore disk will only work for use with Toshiba Qosmio F30-112. This restore disk contains every driver for the Toshiba Qosmio F30-112.
http://restore-disk.com/shop/CartAdd.asp?ID=149816
Toshiba Qosmio F30-112 XP ... windows XP restore disk is a one stop solution. The Qosmio F30-112 drivers in ... Toshiba Qosmio F30-112 XP Notebook plug and play will install ...
TOTAL: $15.92
hope this helps
Sep 12, 2012 | Toshiba Qosmio F30-112 Laptop DC Car...
How to restore original windows on a toshiba satellite a105-s4184
I have toshiba laptop satalite with 2 operation windows 2000 and HP windows running thus slowing the system down consiradably. Idealy would like to delete the windows 2000 professinal. Please help
Sep 26, 2011 | Computers & Internet
When opening it hangs-up after windows opening normally after 30 seconds...
Just before Windows boots, keep pressing the F8 key. When you get the boot menu, boot into Safe mode and click NO, when asked to logon. This would start System restore. Restore the system to a date when you know that Windows worked fine.
Here’s a youtube video on how to restore a system with System Restore
Here are step-by-step tutorials on System Restore:
For Windows XP:
http://www.howtogeek.com/howto/windows/using-system-restore-in-xp/ http://www.5starsupport.com/faq/xp-system-restore.htm
For Windows 7 or Vista:
http://www.howtogeek.com/howto/windows-vista/using-windows-vista-system-restore/ http://www.vistax64.com/tutorials/76905-system-restore-how.html
Hope that helps,
Regards,
Raspal
For Windows XP Driver Files and How-to Resources, visit XPDrivers.
May 02, 2010 | Dell Latitude E5400 Laptop
Wont allow me to choose system restore, it will only highlight reboot
disable system restore - fix what the problem is and delete the old system restore points and then re enable the system restore and make a restore point again.
If you need more help post back and explain what the problem is or why you are trying to restore it and I will help further.
Apr 15, 2009 | Dell Dimension 3100 PC Desktop
Windows XP Hiatus
When that happens you need to use a Windows install disk to reinstall the system.
do you have a Windows setup disk at hand?
Mar 05, 2009 | Computers & Internet
Windows xp professional repair
Try to do System restore
To use System Restore to restore Windows XP to a previous state, follow these steps:
  1. Log on to Windows as Administrator.
  2. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore. System Restore starts.
  3. On the Welcome to System Restore page, click Restore my computer to an earlier time (if it is not already selected), and then click Next.
  4. On the Select a Restore Point page, click the most recent system restore point in theOn this list, click a restore point list, and then click Next.
    Note A System Restore message may appear that lists configuration changes that System Restore will make. Click OK.
  5. On the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows XP configuration, and then restarts the computer.
  6. Log on to the computer as Administrator. The System Restore Restoration Completepage is displayed.
  7. Click OK.
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
Mar 04, 2009 | Microsoft Windows XP Professional
Lost system restore functionality after installing second xp pro
My computer properties system restore check if system restore is turned off.
If yes turn on all drives and restart.
If system restore is on then you need to create a new admin account and check system restore settings.
Also you need to have 6gb of free space in windows partition
Enjoy this will solve
Feb 08, 2009 | Microsoft Windows XP Professional
Vanishing restore points
Well known problem .... if you have a multi boot system with Xp and Vista/Win7 everytime you boot into XP the Vista/Win7 restore points will be deleted.
This only happens if you use the Windows Boot Manager though. I would suggest using a third party Boot Manager to get over the problem.'
I recommend OSL2000 loader which can handle just about any OS on any partition on any disk
http://www.osloader.com/
Jan 01, 2009 | Microsoft Windows Vista Ultimate Edition
Restore feature on windows xp home edition
Power001:
You have to create restore points first in order for this feature to work, to fully understand the system restore please go through this informative article:
http://www.microsoft.com/windowsxp/using/helpandsupport/getstarted/ballew_03may19.mspx
Hope that helped!
Dec 10, 2007 | Microsoft Windows XP Home Edition
Open Questions:
ibm thinkpad does not boot My IBM Thinkpad 600 (Type 2645-310) stops and hang during bootup. What happens is: 1. LED test, then green Power on and orange battery/charging 3. RAM OK (Responds when I take out /put in different amount of RAM and displays correctly. I have 128 + 32 removable, + 32 internal not possible to take out) 2. I can hear fan, CD drive and evt diskette drive. If I use diskette drive the LED wil give 1 blink, if I use CD drive it will give 14 blink. 3. No cursor seen, but this is displayed: Upper left show the amount of RAM present: 196032 KB OK Upper right IBMs logo in blue; IBM Lower left shows "ThinkPad(R)" in large letters and red dot over "i". 4. Then a "rrrrrr" sound from the loudspeakers after a while, this is in fact 28 clicks shortly after each other. Then nothing more happens. Diskette and CD drive is OK (But can not be used because bootup is never finished). I hear CD speed up and then down again but nothing more happens. No effect in booting with bootable diskette or CD, "Live Linux" CD or else. Backup battery OK (3V) and if I take it out I will be asked for correct date and time when Power on. I can then use keyboard or TrackPoint to set date and time, and after that hangup at the usual point. Starting without battery, HDD, CD drive and removable memory sticks makes no difference in symptoms. Pressing and holding F1 before and during poweron and startup (in order to enter BIOS and selftest) has no effect. I could not find help on IBMs home page, but maybe I did not look at the right place. Is somebody able to help me?
Feb 28, 2017 | IBM ThinkPad 600E 2645 Notebook
See all IBM ThinkPad 600E 2645 Notebook Questions
IBM ThinkPad 600E 2645 Notebook Logo
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
