Question about D-Link DSM-320RD DVD Player
DVD Door will not open
I put a DVD-RAM into my D-link 320RD and now I cannot eject it. Any ideas on how to get the DVD out?
Thanks,
John
5 Suggested Answers
SOURCE: Insignia DVD Player
Try hitting the "Lock" button on the remote. That solved the problem for us.
Posted on Jan 28, 2007
ward_knutson
  • 64 Answers
SOURCE: D-Link DSM-320RD switch from NTSC to PAL
I couldnt find any reference to NTSC or PAL, only MPEG video but here is the link to this device. http://www.ipcamera.ch/docs/DSM320RD_fr_.pdf You should find what you need here!
Posted on Nov 25, 2008
  • 3 Answers
SOURCE: put in a dvd and
Hi dear, do check dvd motor or no?
my be your dvd player motor has problem.
if no check the motor driver ic am5898n
Posted on Jan 03, 2009
islandmyth
  • 120 Answers
SOURCE: cant open dvd door:
You can force a dvd player to open. If you noticed there's a small hole in your dvd player as big as a paper clip. All you need to do is to find a paper clip and use it as a key to open ur dvd player.
Posted on Mar 19, 2011
CD STUCK IN DRIVE D
Unbend a paper clip.
  1. Look very closely at the area around the CD/DVD drive door until you find a really small hole - it almost looks like an accident (probably just below the door).
  2. 3
    Insert the paper clip in the hole (don't be afraid).
  3. 4
    Push the paper clip gently to press the spring-loaded latch.
  4. 5
    Your CD/DVD tray should open right up.
Jun 19, 2013 | Dell Inspiron Computers & Internet
How do I open the door to my CD/DVD player on my eMachine Tower. I use to know how but as an old lady I need help remebering now. please help
There should be a button just below the cd tray on the front of the tower. If I remember correctly, on E-Machines there is a black bar just below the tray, and the button is a small section of this bar. If you press along the bar you should find a place that presses in. That will be the button to eject the tray.
Another way to do this is to click on "My Computer", there should either be a link on your desktop, or in the start menu. In this window you should see your disk drive, usually "D:\". Right click on this icon, and there should be a menu option called "Eject", which will open the drive for you.
Thanks,
John Vickers
Aug 12, 2011 | E-Machines eMachines Desktop PC
I put a dvd in my computer and roxio says it is reading disc. How do i get it to eject??
If the door on your CD/DVD drive will not open when you push the eject button (on the front of the drive), Click on Start, My Computer, and Right Click on your CD/DVD drive. Then Click on Eject. If the door still refuses to open, you can insert a paper clip into the small hole on the faceplate of the drive and push it in until the door opens. If the door continues to refuse to open in the normal manner, you will have to replace the drive,
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please rate my solution using FixYa's "Solution Helpful" rating scale.
Best regards,
Yavacotech
Apr 02, 2011 | Dell Dimension 5100 (D51L1) PC Desktop
I have a Samsung DVD R160 recorder. A few days ago the recorder was not on and it was making a noise like it was trying to read a disk. This went on for quite a while. I then turned it on and it would...
Try this, look for a small hole on the front of the unit.Use a pin and press in to see if it opens,ejects the disk .If no hole try seeing if you can press ,lift,pull at the door/slot while pressing the open door/eject either on the unit or with the remote control.It sounds like you may have a bad CD/DVD (copy) that the unit is trying to read/load but can't. keep trying to eject CD/DVD if this doesn't work unplug unit for 5 minutes,try open door again do press and hold open repeatedly I know it's frustrating but it just may eject.Don't use this recorder for playback of DVD buy a $30 DVD player the cheaper the better they play anything.GOOD LUCK
Jan 04, 2011 | Samsung DVD-R160 DVD Recorder
The dvd drawer on my BD-HP16U is stuck in closed position. The screen display "hold" when I push the eject button.
Try inserting a small pin through the hole beneath the insertion cabin, after pressing the eject button. If you don't have such a hole, Push the eject button and tap hardly on the top of the player. The drive will come out in two or three attempts.
Apr 13, 2010 | Sharp AQUOS Blu-ray Disc Player
When I press the bottin on the dvd burner to open the door, the green light comes on and i would hear the door try to open but no open.
yes frn this is happen due to the jam in the DVD rom. when you press the eject button put one pin in the hole that is just below the eject button. so that you can eject your DVD. or just hit the cd ROM slowly.
May 16, 2009 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
Nov 25, 2008 | D-Link DSM-320RD DVD Player
DSM-320RD reset problem???
Your problem is most likely an incorrect video out setting. Examine how you are physically connected to your
TV, set your TV to view that input. After your unit is powered up and the Welcome dissappears, hit the Video Out button on your remote until you see the display.
Apr 24, 2008 | D-Link DSM-320RD DVD Player
Dvd player won't open
I had the same problem for my panasonic dvd player (ht540). Neither of the above solutions worked so I found this one on the panasonic website:
1. turn off unit by holding down the POWER button for 10 seconds.
2. unplug the power cord and wait for one minute.
3. plug the cord back in and turn on the unit
4. when the dvd begins to play, press "EJECT".
It worked for me. The site for other troubleshooting is:
http://www2.panasonic.com/consumer-electronics/support/FAQs/details-FAQs+for+DVD+Recorders-UCM_PRD_CNT_001989#dvdrec6
Peter
Oct 09, 2007 | Philips HTS3410D/37 700W DVD Home Theater...
DVD drive troubleshooting
Can you explain a dvd cartridge please?
May 04, 2007 | Panasonic LF D521 (LF-D521U)...
D-Link DSM-320RD DVD Player Logo
Top D-Link Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a D-Link Furniture Expert? Answer questions, earn points and help others
