Question about Sony SLV-N750 VHS/S-VHS playback VCR
Vcr jams on eject
All operations such as tape movement -play-rewind-fast forwrd work 0k. When eject hit,tape crunches and james. Looking at the operation with the cover off, I don't see how the tape can be lifted free of the rollers to eject Before I retired from IBM I repaired large system computers, but this simple operatiom operation stumps me. I'm sure I'm missing something--getting dumber,with age. Thanks for any suggestions.
  • john mac whirter Mar 18, 2007
    yes it does load properly and the tape no longer crunches . Now, although the tape moves properly when play is hit no information seems to be read or displayed in the view portion of the screen. Other tapes with information on them do the same thing--nothing seems to be reading
    Novelist:
    Champion:
  • 275 Answers
What do you mean 'Tape crunches" Do you mean that there is tape slack, which then crunches when Tape is lifted during Eject? If that is the case, then the Supply Reel Roller Brake is bad. it is a Felt Pad, which needs replacing. If the entire eject operation is wonky, or if it's timing is bad, then I suspect that One of the eject Gears (On either side of the Mechanism) is damaged and needs to be replaced. One question, i assume that you are able to eject the Tape eventually, and so - Does the Tape Load into the VCR properly, when you insert it into the machine? This will help me in giving you a better diagnosis.
Posted on Mar 14, 2007
  • Pravin Gupta Mar 21, 2007
    Dear Jmack,
    Waht do you mean "yes it does load properly and the tape no longer crunches " ? does it mean that your initial problem is solved now? If you say that now the tape moves properly, Shall i assume that the mechanical problems are now sorted out? And as for no information being read, have tried cleaning the Video heads? Use a Wet Type Video head cleaning cassette. Let me know if things have become ok now.
Our Toshiba VCR won't play tape. It ejects tape after a few seconds.
If you are trying to play older VHS tapes, you may have to run them through some fast forward-rewind cycles to condition them and relieve stress
Jul 20, 2013 | Toshiba D-VR4 DVD Recorder/VCR
VCR does not play.. It keeps ejecting the tape
Does it eject right when you put a tape in? Or when you press play? Does it fast forward or rewind? if not a belt may need to be replaced or an idler tire is worn.
Jun 16, 2010 | Panasonic NV-HD680 VCR
Unit accepted cassette, won't eject
check the tips in my profile
May 10, 2010 | Sony EVC100 Hi8 VCR
I was rewinding a tape and the VCR just stopped. When I hit either play or rewind the VCR makes a kind of whine or grinding sound and then the following message appears in the display: 3L 22 AA. What...
Have you tried ejecting the tape?
If the cassette will not eject, the tape is probably fouled on the capstans and will need to be "surgically" removed, VERY CAREFULLY from the machine.
Apr 16, 2010 | Sony SLV-975HF VCR
It is likely that either the drive belt has broken or is slipping. Because the unit is still in "play" mode, the mechanism won't let the door open up. If you have not opened up these units before, do not attempt it now. This unit should be taken to an experienced tech for repair. Where are you located?
Dan
Apr 08, 2010 | Sony EVC100 Hi8 VCR
Tape ejects after playing for about 30 minutes
it could be dirty pinch rollers causing the tapes to tighten and be ejected. try fast forarding the tape to the end and rewinding. if this does not cure the problem, run a wet cleaner tape through.
Mar 05, 2010 | Emerson EWV403 VHS VCR
Loads tape then stops - won't play rewind fast
Way to go. Usually if you use anisotropic Alcohol with a few Q-tips works well I've found.
Try cleaning the other tap path items like the capstan that the pinch roller get's pushed up to also with this Alcohol. The cleaner the better the tape goes through. Much better picture.
Blessings,
A/V Media Guy
Nov 19, 2009 | Sony EVC100 Hi8 VCR
Tape Problem
When a VCR eats a tape, it can be cause by a couple things.
1. There is a rubber wheel called a "pincher wheel" that compresses the tape against the "capstan". The capstan is a shiny metal spindle connected to a motor. The pincher wheel can become worn and/or dirty (slick) from the oxide coating off of the tape. You can try cleaning the pincher wheel and capstan with alcohol or try using a re-grip solution on the pincher wheel. Last thing to do is replace the pincher wheel. Look to see that the pincher wheel is doing its job by pulling the tape through. The pincher wheel & capstan are not used during a fast forward or fast rewind, so if your tape is getting caught during the FF or RW and not Play, it's probably not related to capstan & pincher wheel.
2. There is a small tire wheel called an idler tire. This tire pivots between the sending and pickup reels of the player. Its also used during fast forward & rewind as well as play. If the tire is worn, the tape won't be wound up as fast on the take-up reel as the sending reel during play. This means more tape is coming out of the cassette than can be wound up on the takeup reel. You can try using a re-grip solution on the idler tire or replace it.
3. There's also a brake pad that is designed to grab and stop the tape wheels from spinning when you hit stop. If those pads are worn, the wheels will not stop fast enough and the tape will continue to feed (spool) out of the cassette and not be taken up by the other wheel.
So when when you hit eject, the excess tape that should have been wound up tight in the cassette before the eject sequence, is getting caught inside the player.
Let me know if I can be of further assistance to you.
- Jim
Jun 27, 2008 | Mitsubishi HS-U776 VCR
Eats tapes
3. You didn't say if the unit played ok. There's also a brake pad that is designed to grab and stop the tape wheels from spinning when you hit stop. If those pads are worn, the wheels will not stop fast enough and the tape will continue to feed (spool) out of the cassette and not be taken up by the other wheel.
- Jim
Feb 20, 2007 | Symphonic WF803 DVD Player/VCR
VCR tape stuck
Yes, it is a mechanical problem. While the tape is in fast forward the gears are engaged and locked to provide drive to the spindel on the right, however when you press the rewind button without hitting stop, the gears try to engage the spindel on the left without stoping and reversing (changing rotational positioning), this causes the motor to stop (this emulates a tape jam)the tope is left in and the unload mechanism never spools the tape back in because the motor has stopped. To free the tape, what I do is open up the unit and find the main motor check to see if the belt has slipped, if it has not try to manually spin the motor to engage the unload mechanism and eject the tape.
Dec 18, 2006 | Zenith VCS442 VHS VCR
Sony SLV-N750 VHS/S-VHS playback VCR Logo
425 people viewed this question
Top Sony Televison & Video Experts
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
