You can reset windows administrator password with Windows built-in administrator account:
1. Log on with the guest account on Vista, then right click computer, and choose Management.
2. Expand Local Users and Groups and Users in the console.
3. Right-click Administrator account and select Properties.
4. On the General tab, clear the Account is Disabled check box.
5. Close the console.
Now the super administrator account is successfully enabled. Next, you can easily reset the forgotten admin password from "Start->Control Panel".
If the above method can not help you, you can use Smartkey Windows Password Recovery to help you to reset the password, and see the detail direction from http://www.recoverlostpassword.com/products/windowspasswordrecovery.html
SOURCE: I forgot my password to
Download trinity rescue disk from this site:
http://trinityhome.org/Home/index.php?wpid=1&front_id=12
Follow the instructions on how to load it, and then resset or remove your password allowing you access to your computer and files.
SOURCE: I have lost Bios password on my Samsung R530. How
Disconnect the battery, unplug it, then open it up. There should be a small round battery called the CMOS battery somewhere in there. Pull that out. Then plug your computer in and boot it up without the CMOS battery. It should say password disabled. Turn it off, disconnect it, put it back together, and you're good to go.
SOURCE: my brother's samsung r530 wont boot up as it is
That is most likely the BIOS password, the best solution would be to ask your brother for the password so that you can boot to Windows and use it.
hope this helps
