Question about Cycling
Exercise Bike lost resistence
I have a ProForm G35 exercise bike. It comes with four pre-programed exercise routines on the console. The console is still operating and exhibits an increase in the resistance on the programs, but the pedals go around as if the chain was off a road bike. Just spins. How do I regain the resistance?
  • zexp Dec 21, 2008
    I have a proform gt-30 with the opposite problem - tension stays too tight. Knob turns and appears to tighten and loosen, but tension stays the same.
4 Suggested Answers
  • 108 Answers
SOURCE: No resistance when I pedal the stationary exercise bike
I looked into this thinking is must be a simple belt, or tention wheel, but these devices are much more complex than the average exercise machine. See the Recumbent selection here.
It appears that the tentioning device is a magnetic brake.
This would require that it be plugged into a power source and programmed to provide a desired tention.
I've never used one of these so I can't say what kind of programming options there are or where they are found.
Hope this helps.
Richard.
Posted on Dec 07, 2009
SOURCE: the resistance belt on my Schwinn 205p recumbent
http://www.fitnessrepairparts.com/equipment/SelectEquipment/100 lists all the parts for this model
Posted on Jan 03, 2010
JayduttDave
  • 99 Answers
SOURCE: magnetic resistance not working on proform gl105
Just oil the area of magnetic resistance and if the problem continues then contact nearer repairer.
Posted on May 15, 2010
Resistance settings not working on fitnex r70 magnetic resistance exercise bike
If this is a new bike that may be the way it is. If it worked differently in the past, you may be looking at a busted tension motor or faulty brake.
Jan 03, 2014 | Champion Fitnex R70 Recumbent Exercise...
The console will not turn off with new batteries
Leave the machine for a few hours. You may not be giving it enough time. Also you may inadvertently changed the settings. Check that.
Sep 15, 2013 | ProForm XP 210 Upright Exercise Bike
What's the best exercise bike there is?
According to me, one of the best Exercise Bike is Fitness form S20 Indoor Cycle Bike. It has adjustable resistance level and adjustable horizontal or vertical seats also. It provides the pulse, distance and speed or has roller wheels to move around easily. In this bike, you can also get a warranty of 12 months.
Aug 09, 2012 | Exercise & Fitness
What are the different resistances on exercise bikes?
There are three main types of resistances, the fan resistance used to provide resistance with air they push as you pedal. The second type is the belt resistance which uses a belt that runs through a brake providing resistance for the exercise bikes. The third type is the magnetic exercise bike which provides resistance which can easily be adjusted while riding the bike.
How much weight will I lose using an exercise bike?
Exercisebikes are a really good way of losing weight without having to show up at thegym! It depends on your weight etc but on average, 15 minutes of cycling withburn about 170 calories. But an effective routine should last around 45-60minutes.
Jul 30, 2012 | Exercise & Fitness
What is a mini exercise bike?
A miniexercise bike is a bike with pedals and resistance parts only. It has no handlebarsor seat. You can use it while you sit on a regular chair and you can move thepedals with your hands for arm exercise.
Proform gr 80 recumbent exercise bike cant get the display to turn off when I get off bike. battery powered?
The GR80 uses for type D batteries. The battery compartment is on the bottom of the console, look for the D-shaped battery door, press the tab located towards the front side of the console and open the door. Careful, the batteries may fall down if you open the door - type Ds are heavy enough to be felt when they fall on your feet.
Jan 16, 2011 | Proform GT 85 x Upright Bike at GNC
Hope this helps.
Richard.
Dec 07, 2009 | Cycling
Cycling Logo
182 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
