Question about D-Link DSM-320RD DVD Player
DVD-RAM will not eject. Help....
I inserted a DVD-RAM home movie and the unit will not give it up. I have tried hitting button, turning off and hitting button but nothing seems to work.
Any ideas on how to over ride the unit or otherwise get the door open?
  • Anonymous Mar 24, 2009
Philips 3360H - can't eject DVD
Try this..turn it off, unplug it for a min or two, then plug it back in. THEN...if the power stays off...hit the eject/open/close button on the panel.
Sometimes this activates the eject mode without turning on the unit. IF NOT, try the remote eject without turning on the unit.
Apr 06, 2010 | Philips DVDR3370H DVD Recorder/HDD...
I have a HT-X40 Samsung home theater that worked fine until yesterday. It's been used very little to this point but now it won't turn on. I was watching a DVD yesterday morning then hit the stop button on...
I would say the DVD was stuck in the unit. Try pulling on the drawer whilst hitting eject. Also try pushing on it doing the same thing. Keep on trying to play it also, sometimes the control system and the mechanics get out of synch and need a little bit of help. But first thing - have you tried disconnecting the power completely (at the chord) and leaving it for about 10 minutes? Always a good first thing to try.
Aug 03, 2009 | Samsung HT-X40 System
Samsung blu-ray player won't eject, tried turning off power strip and waiting 10minutes then trying again, still didn't work
I had a similar problem with my unit. every time i hit "eject" the screen would display "eject" for about a minute then display "loading" indefinitely. no mater how many times i powered on or off it just would not spit out my disc. However, I hit the "function" button on the player and cycled through radio, aux. etc. and that seemed to un-freeze it. I was able to eject my DVD while the player was set to radio. give it a try and hope for the best.
Jun 11, 2009 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
I have had some luck in unplugging the machine for five or ten and then trying again. I have spent five to ten minutes trying to get the darn thing to spit out the disk and it refuses. Unplugging either gives me time to cool off or it helps the machine :)
Apr 30, 2009 | Panasonic PV-D4745S DVD Player/VCR
Hts 3450 home theatre system- dvd in player- but won't come out
When a disk is stuck inside the player , try following the procedure below:
Unplug power cord.
Plug back power.
Turn on the unit and press repeatedly the eject button at the same time. If you successeed in ejecting the disk before the player starts reading TOC(disk initial track), then the disk will eject.
If that does not work, then there is an internal fault, in that case the unit must be taken apart to remove the disk.
Dec 10, 2008 | Philips HTS3450 System
DVD drawer stuck out
Try to unplug the unit from its power source, give it a minute then plug it back in.If open appears on the window, hit the eject button. See if that will work for you. If that dont work, hit source and on at the same time, then eject if open appears in the window. That should close the draw for you.
Apr 19, 2008 | Bose 3·2·1 II System
DVD Stuck in Player
While the above problem is not in the manual, I would try pushing and holding down the Open/Close buttton for an extended period to see if the unit will 'unlock' itself.
Mar 16, 2008 | Sanyo DWM-390 DVD Player
Playing recordable dvd
My Emerson won't play anything except DVD Movies, never has, wasn't suppose too. Make your movies in DVD Video format and it will read them fine (unless it's broke). I make movies all the time and play them back in mine. It reads DVD-R, DVD+R, and in duel layered. It will not read RW disks!
Man I've every problem you can imagine with DVD Players. I've found when the disk gets stuck, as long as it's not jammed. You can turn the unit off or unplug it. Plug it back in but DON'T TURN IT ON! Instead hit the eject button and the drive should open the drive without trying to read the disk.
Feb 24, 2008 | Emerson EWD7003 DVD Player
Dvd player won't open
I had the same problem for my panasonic dvd player (ht540). Neither of the above solutions worked so I found this one on the panasonic website:
1. turn off unit by holding down the POWER button for 10 seconds.
2. unplug the power cord and wait for one minute.
3. plug the cord back in and turn on the unit
4. when the dvd begins to play, press "EJECT".
It worked for me. The site for other troubleshooting is:
Oct 09, 2007 | Philips HTS3410D/37 700W DVD Home Theater...
D-Link DSM-320RD DVD Player Logo
70 people viewed this question
Top D-Link Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a D-Link Furniture Expert? Answer questions, earn points and help others
