Question about iRiver iFP-180T MP3 Player
My Iriver is connected via USB cord but my computer...
But my computer does not recognize and I am unable to download recordings from my Iriver
frit
  • 67 Answers
SOURCE: iriver T10
on your player go to settings screen, then to advanced, then to format. select format, then yes. Player should reboot. Then try connecting again. iriver uses windows media player now. shouldn't need anything else.
Posted on Jul 29, 2007
SOURCE: system files missing
I fixed this problem for my mate, here's what I did:
1) plugged in H10 to pc that didn't have any iriver software on it
a) I've read if you press the "o" button on the iRiver H10 when connecting it will just connect as a usb mass storage device
2) the H10 now appears as a mass storage device
3) right click on the drive, and select format ( I choose quick format)
4) install the iRiverFirmware updater from http://iriveramerica.com/support/mtpupdate/
5) when you run the updater, it found the H10, then asked if the device was from USA or Europe, mine was from Europe
6) It stated that the iRiver firmware was v0.0, and would install v2.51 (I've seen v2.53 available on the european iriver website but could not download it).
7) proceed with installing the updated firmware
8) on the last screen it says, unplug to complete firmware update - NOTE press Finish first before unplugging
9) switching on the iRiver it 'rebooted' a few times and then when the menu appeared, I connected to the pc and just dropped some mp3 files into the music directory and all was okay.
hope this helps.
Mike.
Posted on Nov 14, 2007
SOURCE: My iriver T10 is not being detected
That happend to me and i found a solution. First go to my computer and on your left click on VIEW SYSTEM INFORMATION then go to HARDWARE now click in DEVICE MANAGER it should say T10 around there look for T10 or IRIVER T10 and click on it press in UPDATE THIS TIME ONLY or an option you like and click next then click on the RECOMENDED OPTION to install the iriver t10 after you do that a magnifying glass should appear and wait and it would install saying MTP.
If still need help send me a message at NOHEMYGIRALDO@SBCGLOBAL.NET
Posted on Jan 15, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: computer won't recognize
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Posted on Jun 26, 2008
SOURCE: iriver H10 "System files missing".
I agree with Heracles83's approach (thank you, it finally worked for me!). However I would like to add something.
I own the H10 20GB model.
I tried the above approach a dozen times, but could not get the format to complete, until I noticed a little blurb from the iriver USA site concerning updating the firmware. http://iriverinc.com/support/mtpupdate/
The player must be in UMS mode in order to update the firmware and, as I finally figured out, to format the drive as well.
The above link will explain how to connect the H10 to your PC via UMS mode.
I was able to format on the first try after that, and the updater worked immediately.
Posted on Nov 12, 2008
Printer not being recognized by computer
Sir/Madam
1. Is the printer turned on?
Make sure the printer is turned on.
Make sure the power cord is securely plugged into the electrical outlet.
Test the power by plugging in the power cord of another electrical appliance to an electrical outlet and turn it on. If the power to the other electrical appliance comes on, the printer may be considered to be faulty.
If this product is recognized:
Close this page to return to the installation window.
If this product is not recognized:
Proceed to the next step.
2. Are your computer and the printer correctly connected?
Make sure the USB cable is securely connected to the printer and to your computer and check that the USB cable is not damaged nor badly crimped.
The printer will not be recognized during the driver installation if connected to a printer switch or the printer buffer. If this is the case, try to directly connect the printer to your computer using the USB cable.
If you are connecting the printer to your computer via a USB hub, connect the printer to the first-tier hub from your computer. If the printer driver is still not recognized on your computer, try to directly connect the printer to your computer without the USB hub.
If you are connecting the printer to your computer via a USB hub, make sure the USB hub device is recognized by your computer.
3. Does your computer provide USB or IEEE 1394 support?
If Still Your Problem Is not solved Then Click On Below URL
http://files.support.epson.com/htmldocs/r1800_/r1800_rf/dset_1.htm
Or
Still You have problem Then please Follow Us On HP Printer Support
Jan 08, 2014 | HP P4515n LaserJet Printer
How to fix iriver E10 it says on the screen is emergency usb
  1. If your PC does recognize the iRiver as a USB device/drive, there is an issue with the Hard Drive.
  2. If your computer doesn't recognize the iRiver as a USB device/drive and can read the files, there is an issue with the Circuitry in your e10.
  3. Turn the lock off and connect it to the usb port and press the reset button (small hole in lower left of unit, use a small object like a paperclip. The screen should change eventually to the "USB connected" screen. Disconnect the USB at the PC to get the "Ok to disconnect" message. Pull out the usb cable and hold down the "off" button. Eventually the unit will turn off. Turn it on and then off to verify it is working.
If nothing works, your iRiver needs to be returned to the manufacturer.
Feb 22, 2011 | iRiver E10 Digital Media Player
Does not open the iriver E10
My coolpix digital camera cannot connect to my computer. The usb cord is in fine condition but the computer continues to say " unable to recognize usb device it may have malfuntioned. Please try again."...
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
Aug 15, 2010 | Nikon COOLPIX L20 Digital Camera
Put videos on it
if you downloaded videos to pc/laptop...connect iriver to pc/laptop via usb cable ..open my computer/iriver.....go to start again open my computer/c drive/find the video files..(both windows iriver & c drive)...now copy the video from c drive and paste to iriver (or click and drag)
Dec 30, 2009 | iRiver Lplayer MP3 Player
I have a iriver spinn mp3 and i dont know how to to put music on it can you help me
Sure, connect to your computer via proprietary USB cable that comes with the device. Your computer should automatically recognize the new Spinn device. Software is also included in order to manage music, video, & ebooks (text files). Install Iriver Plus 3. Perform media search on your computer. Select files you want to put on your Spinn. Then transfer to your device. Make sure eject your device for safe removal. Thats it.
Nov 19, 2009 | Audio Players & Recorders
Pc doesnt recognize iriver ipod
first of all iriver is not an ipod
try to download the driver named iriverplus that shuld work
Jan 29, 2009 | iRiver H10 MP3 Player
Disappearing icon
i have the same problem but its not with an icon
Nov 30, 2007 | iRiver H10 MP3 Player
CLUELESS IN NY, IRIVER H320
You have to hit the on button twice to show as connected,then you can manually move files to the root directory by going to the computer ICON on your desktop, finding your MP3 player,then clickto open the file - the find thefile you want to copy or move onto the MP3 and drag it into the MP3's main file NOT the file that says RECORD
Nov 07, 2007 | iRiver H320 MP3 Player
iRiver iFP-180T MP3 Player Logo
97 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
