Question about D-Link AirPlus DI-524 Wireless Router
Wireless network connected, no internet
I was able to connect to the wirelss network using the dlink (DI524), however, my notebook, ipod could not get connected to the internet. Please advise.
  • mull8033 Dec 18, 2008
    bought my daughter a new dell and am using DI-524 router. Desktop has internet but laptop doesn't I have tried everything I can think of, I am now into the rum. Suggestions anyone?
  • 20 Answers
Check whether your computer is able to recieve an ip address wirelessly
Posted on Dec 16, 2008
I purchased a wirelss printer (HP Officejet 6500) and need to install it. HP says that the firewall in the router (Dlink DI524) is blocking it. Any ideas how to fix the problem and get it working. THe...
If you are using a network switch or Access Point to create wireless network, you need to access its software and turn off its firewall and if you are connecting the printer with the Bluetooth of your computer you need to turn off the firewall of your computer.
Jul 28, 2011 | Office Equipment & Supplies
I want to setup ipod wifi with my dlink wireless router, please advise how to go about it?
Hi Masand,
Please follow the below steps to configure the Ipod to Dlink Wireless
Step 1: From your IPOD serach for Wireless network in the range
Step 2: You will be able to view your wireless network name
Step 3: Connect to the network, if it asks for password please put the security code of your wireless network
Step 4: Click on Connect
Step 5: The connection will be established
Please check and revert back to us, if you have any other issues
Thanks for contacting Fixya
Regards,
Aysaam
Feb 27, 2011 | Computers & Internet
Acer extensa 4620 Since purchased, wirelss
Try turning off your Acer wireless control and use "Wireless Zero Configuration"
Nov 27, 2009 | Acer Extensa 4620 Notebook
2 Notebooks without router acces at the same time
Under the DHCP settings, make sure that there is enough IP addresses for the router to assign. Although DHCP is somewhat "automatic" if there is not a sufficient range of IP addresses for the DHCP server to assign, then only a small number of clients can connect. See this page here: http://support.dlink.com/emulators/di524/h_dhcp.html
Also make sure that your notebooks are not set to the same static IP address, only one device can connect to a specific IP address. To check this under Windows XP, Right-click your wireless network connection and select "Status" then "Properties". Highlight the "Internet Protocol TCP/IP" and select "Properties". Make sure that the radio buttons "Obtain IP address automatically" and "Obtain DNS server address automatically" are selected. Click OK and OK to close the windows and save the settings.
I would also unplug the router, wait 60 seconds, then plug it back in and try to reconnect. Sometimes for whatever reason, the routers memory can get corrupted, (just like a computer) and need to be restarted.
Sep 06, 2009 | D-Link AirPlus DI-524 Wireless Router
Dlink DI524 wireless problem: cannot access the router
If the Router is new proceed to Step 1. If the Router is used power on and press and hold the Reset button for about 10 seconds. It is located next to where the power cord is plugged in. Use either a pen or paper clip to push reset button.
Step 1. Connect one end of an Ethernet cable to the Ethernet port located on the Cable / DSL modem and the other end to the WAN port on your D-Link DI524 wireless Router. The WAN LED light will illuminate to indicate proper connection.
Step 2. Connect one end of an Ethernet cable to LAN Port 1 on the back panel of the DI-524 and the other end to the network adapter in the computer you are using to
configure the DI-524. The LED light for LAN Port 1 illuminates to indicate proper
connection.
Step 3. Once all pieces ar connected. Open your Web browser and type http://192.168.0.1 into the URL address box then press ENTER. Once the log-on pop-up screen appears type admin for the user-name and leave the password blank then click ok.
Step 4. Once you have logged in, the Home screen will appear and you should see a box called RUN WIZARD in the middle of the screen. Click that box and follow the steps.
Setup Step 1 - Click Next
Setup Step 2 - Create Password and click Next
Setup Step 3 - Choose Time Zone and click Next
Setup Step 4 - Setup wizard will try to auto-detect your Internet connection type.
Setup Step 5 - Select your Internet Connection. You will be prompted to select the type of Internet connection for your router. More than likely it will be Dynamic IP Address. Click Next.
Setup Step 6 - Click the “Clone MAC Address” button to automatically copy the MAC address of the network adapter in your computer. You can also manually type in the MAC address. Click Next.
Setup Step 7 - The default wireless settings for your 802.11g wireless network are: SSID = default Channel = 6. You can change the SSID name to whatever you like. This will be the name of your wireless network. Click Next.
Step 8 - If you wish to use encryption for your 802.11g network, the DI-524 is capable of two levels of wireless encryption - 64-bit and 128-bit. By default the encryption is disabled. You can change the encryption settings for more secure wireless communication. If you choose to use encryption, you will need to write down the encryption key so that you can connect your laptop or pc via wireless connection. Click Next
Setup Step 9 - Your is complete. Click Restart to save and reboot your router.
Setup Step 10 - Click Close to complete your setup.
Setup Step 11 - You will be returned to the Home tab. Close this window and wait for the Router to finish rebooting. Then relaunch your Web browser (i.e., Internet Explorer or Netscape Navigator), to link to your favorite Web site to test your Internet connection.
Here is the link to download all the necessary info to configure your router - http://www.dlink.com/products/?pid=DI-524&tab=1
Jun 21, 2009 | D-Link AirPlus DI-524 Wireless Router
Slow Internet Connect
i have the same router. I recommend that you download a new driver of your lan card for your desktop pc, also if you have P2P and bittorrent applications, try to disable them first and see the difference, those programs slow down the your internet, because they hog your bandwidth and connects to multiple users.
Feb 01, 2009 | Compaq Armada M700 Notebook
Connecting with internet
Yes, that is possible since you have a wireless router. Router can share internet connection. Go to this link this will help you setup the wireless connection (secure it if you want)
http://www.portforward.com/english/routers/wireless/Dlink/DI-524/wireless.htm then on the very bottom there is an option how to Configure Windows XP to connect to your wireless network.
I suggest this because it would be better if there is encryption on the network so people wont be able to access your internet for free (unless you give them the security key)
Sep 15, 2008 | D-Link AirPlus DI-524 Wireless Router
Cannot Set Password on DI524 Wireless Router
Alright, it was a dumb thing to do....just make sure you use internet explorer...It works in there...don't ask why lol....I have no idea :D
Dec 31, 2007 | D-Link AirPlus DI-524 Wireless Router
D-Link AirPlus DI-524 Wireless Router Logo
117 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
