Question about Compaq Presario 700 470024-192 Notebook
No sound from speaker and audio-out jack
Did almost everything, test sound
  • 113 Answers
Did you try to re install the operating system and then reinstall the audio driver which is on the utility CD of your laptop.  or Try to install the (OS) Vista version if you are still in XP. I tried already vista and it worked out. If it didn't for you then bring it to the service center near you.
Posted on Dec 14, 2008
How d0 i get audio speakers to workj
Assuming the speakers are working, you can test them by plugging them into any other headphone jack, for example your cell phone. Check drivers & etc on computer make sure sound card installed correct. Also verify you are using the correct jack, there may be several for example microphone line in if you have a 5.1 stereo card they may also be ports for the rear speakers.
Dec 15, 2014 | Systemax Ascent Computers & Internet
I have a samsung plasma 50" tv, how do I hook it up to this sound bar? I tried to hook it up using the rca jacks and it didn't work.
Near the Audio / Video inputs on your tv, you should see a "headphone" jack or it may be labeled "Audio Out"
some sound bars plug into these jacks using standard heaphone jack.
Other sound bars may need to be connected to the device your using on your tv. (DVD player, cable box, etc.)
Tv speakers can then be disabled in the "Audio" menu of your tv.
Dec 02, 2014 | Samsung Televison & Video
No sound from internal speakers after using headphones
The headphone jack has a switch in it to disable the speakers when the headphones are plugged in. This switch has stopped functionong. Look in the jack eith a magnafying glass to see if there may be lint or some other object holding the switch open when the headphones are not plugged in. Otherwise it's time to replace the jack.
Apr 19, 2014 | HP (153147-001) Sound Card
No sound on my technika 42" 3dtv
If the headphone jack socket works the audio output for the set is good, I suspect a dvd etc will also work if connected to the rear input audio and video jacks.
This does not leave too much, headphone jack dirty or defective, speakers for whatever reason are switched to off in the main menu.
the sound for the headphone socket if it is built into the set is the same audio going to the speakers.
Dec 05, 2012 | Televison & Video
Speakers won't work on ASUS P8Z68-V PRO/GEN3 motherboard
Speakers don't require drivers so test them elsewhere, and test your system with headphones to establish you have sound.
Some audio allow for the changing of the ports. Maybe called Smart Jack or Jack Detection. Open Audio Configuration Utility and make sure the green input is still the speaker input.
This MB has this feature with software provided.
Nov 01, 2012 | ASUS P8Z68-V PRO/GEN3 Desktop Motherboard...
Rear audio does not work
Hi the solution for the rear audio do not work is cold solder connection to the mother board or the banana plug female connector. You have to remove the mother board because you don have no access to re solder the the frame cover that area. If the female banana pug connector is the problem the parts is available at radio shack. Before you do all of what I mentioned first you have to confirm by going to control panel click sounds and audio devices and watch the screen and speaker will gray out if the speaker is un plug or not detected. If your PC use Realtek audio device on the control panel click the sound effect manager and click the speaker test tab and perform speaker test. Then if the test fail perform mother board repair. Hope this info might help you solve your PC rear sound problem.
Apr 27, 2009 | Evga nForce 680i SLI (122CKNF68)...
No audio
Pls check if the audio settings on the monitor are correct. Along with the monitor menu button, there will be another button for audio for some models. For other models the audio option will be available in the menu button itself.
Pls check with another set of powered speakers and not headphones.
Also check for the drivers and any driver updates for your sound card.
Hope this helps fix your problem.
Jan 28, 2008 | Acer AL1717 17" LCD Monitor
Compaq Presario 700 470024-192 Notebook Logo
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
