Question about Kitchen Ranges
No flame on my oven - Kitchen Ranges
  • 71 Answers
If your oven uses hot surface ingnitors check them
Posted on Dec 14, 2008
Gas valve wont open in my oven
call your local repairman .
Nov 15, 2016 | Ovens
Hot surface igniter will glow and put out a flame but is not a blue/orange flame
First you need to get a nice blue steady flame to prove to the ignition module there is flame. Check you orifice and bypass tube.
Feb 22, 2014 | Lincoln Impinger 1116 Gas Oven
Flame very low in bottom oven
If the flame stays low from the beginning then it will be the flame safety device (fsd) not opening on sensing the flame and will require replacement by a gas certified engineer.
Jul 29, 2012 | Ovens
Very small flame takes like ten minetes for flame to get high
The reason the flame in the oven is so small and takes for ever to heat up is because the oven igniter is weak and can not open the gas valve very much so hardly any gas flows resulting in a low flame size. By replacing the oven igniter the flame will be full size and heat quickly.
GENE
Oct 16, 2011 | Sears 61301 Gas Kitchen Range
My oven had flames burning up from the bottom during the self cleaning cycle. I managed to turn it off but it won't unlock. How do I unlock the door if I see flames? They stopped.
The oven wont unlock until the inside is at a certain temperature, to prevent you from burning yourself with the convective heat, or worse, the fire spreading to outside the oven. Once the flame runs out of oxygen inside, the flames will go out. But the oven may not unlock for a few hours at the most.
Mar 31, 2011 | GE Monogram® ZET958 Electric Double...
Oven burner flame is low
0000000.jpgOn top of that safety valve is a nut. Get a good fitting wrench. Turn on the oven and use that good fitting wrench on that nut. Turn it counterclockwise till the flame comes up about midways of the flame spreader. Don't get the flames too high. Midways of the spreader now. LOL
Jan 02, 2009 | Ovens
Oven flame ignites but will then not increase to the larger size
when oven is switched on the flame ignites,butthe flame refuses to go tothe next stage to preheat the ovento the required setting
Nov 10, 2008 | Rangemaster 110 (Gas) Kitchen Range
High flames in oven
Flame saftey device control valve stuck in open position that why main gas is coming other wise flame should be max 2cm long after flame saftey device heat up and bellow expand and main valve should open
Jul 21, 2008 | Frigidaire FGB24S5A Gas Single Oven
My gas oven flame
BLOCKED JET MAYBE CAUSED BY FOOD SPILLAGE OR BLOCK IN PIPE TO JET
May 28, 2007 | Parkinson Cowan SG320 Gas Kitchen Range
Kitchen Ranges Logo
48 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
