Question about LG enV VX9900 Cellular Phone
Trouble staying powerd
I just got a used phone and all the time when i put it on the charger it takes normal time to say full battery. so i take it off the charger and 5 mins later its down two to bars of battery life. then 2 mins later it has three bars of battery left. then it goes to one bar for a about an hour then it goes dead and powers down. should i buy a new battery.
    Problem Solver:
  • 12 Answers
It could be the battery(a dead cell in it) or the charger. If you use a lot of applications like music. im, navigator, web, that eats up the battery. have verizon test the battery.
Posted on Dec 16, 2008
I have a serious problem...
Replace the cell-phone's battery, since it won't take or hold a charge.
Sep 20, 2015 | Cell Phones
What are other causes of a phone not turning on besides a dead battery, overheating, and freezing?
replace the battery for starters
check that the charger is putting out the correct voltage
Jun 05, 2017 | HTC HD Windows Phone 7
My battery for canon camera 550d flashes orange when charging, its been 4 hours now and it hasnt turned green yet.. I am charging it first time.. is this normal
Okay what happens sometimes is the charger gets into a feed back loop. What to do is remove the battery unplug the charger wait a few seconds (Maybe 20/30) plug the charger back into the outlet and then put the battery back in the charger. It should start to charge again and a few minutes later go to the blinking for full charge green.
It'll happen the other way as well meaning if the battery gets a memory (they say they don't but they do) you need to unplug the battery let is sit till it's cool and put it back on charge again. I've had this problem many times and have put it on charge and back off several times with in 15 minutes before it started to charge as it should.
Also these batteries do have a life span and if it's a three year old battery with many charges it could be failing meaning it just won't take a full charge.
Apr 19, 2011 | Canon Cameras
How many hours we should charge the battery fist time Nokia-2700
There are basically 3 types of chemicals currently being used for cell phone and laptop batteries. Ni-cad, Ni-mh and Li-ion. There is a fourth makineg its way in Li-ion polymer. A couple things are consistent for all types of batteries no matter what chemical is inside. You must initially give the battery a 12-14 hour charge on the home charger. (Don't use a cigarette adapter for the first charge. This conditions the battery and don't take it off the charger that first time even if the charging indicator says it's full after 3 hours. Also the manufacturer's also state to run it thru 3 charge cycles. What that mean's is that you fully charge and fully drain 3 times. 1 full charge + 1 full drain = 1 charge cycle. Here's where the way you charge the battery starts to differ.
Ni-cad: Mostly only on older devices, has a "memory" effect, should be drained before a full charge is put on it, should be removed after overnight charge or can be overcharged and burnt out.
Ni-mh: Still used for some devices, has slight memory effect but not enough to have to fully drain before the recharge, should not be consistently left on charger after full charge that can eventually burn out battery and shorten usage time.
Li-ion and Li-ion polymer: Used on a lot of newer devices, has no "memory" effect, should be recharged as often as possible, actually likes to be charged and draining it regularly can cause the usage time to be shortened, can NEVER be overcharged so whenever you're near a charger put it on there. Besides those benefits a li-ion battery is lighter and smaller but the chemical can hold more charge than Ni-cad and Ni-mh.
So the one reply to your question said to error on the side of draining the li-ion batteries. This is incorrect information. You want to charge the battery before it gets below a 20% charge. Also batteries will not go bad from accidentally doing the incorrect charging procedure here and there but normally follow the correct procedure. One last note try to use the home charger more often than the cigarette lighter charger for best long term results. Cigarette lighter chargers do not give a full charge (about 95%) which in the long run can damage any type of battery listed.
Oct 07, 2010 | Nokia N70 Cellular Phone
I changed over to other nam and powerd down phone
This will also bring the phone to default settings
1. First do a CUSTOM reset: *2767*2878#
turn off the phone
2. take out the battery and sim and put wrong network SIM and insert only a half of it,
Very important so it won't ask for network password and shows "Insert SIM" message.(possibly in a different language)
Now put the battery ,and switch the phone on .(phone shows "Insert SIM" message.)
3.push the sim fully in at this stage the phone is still asking to "Insert SIM"
4. Make a FULL reset: *2767*3855#
5. The phone should reboot working with "wrong" sim inside.
6. Make a Change the NCK password to 8 zeros by typing: *7465625*638*00000000*00000000#
7. Now Disable network lock By typing: #7465625*638*00000000#
Phone is unlocked
Mar 06, 2010 | Cell Phones
Lcd screen is ''full''
not sure what kind of phone this is. usually it shows these types of the screens when the phone is off and you are plugged into the charger.
unplug the phone from the charger, if it turns off, then switch it on. if it stays the same when the charger is removed then take out the battery and put it back in and turn it back on.
Dec 09, 2009 | Computers & Internet
How to save your dead battery: Please note using below method at your own risk, and you have been told. Take out you dead battery (PDA battery,PSP battery,Phone battery etc), wape it around by using a big piece of dry newspaper. Then put the newspaper waped battery into the freezer at below zero temperture for 4 days. After days, take the whole thing out and put in room termperture for one day. Recharge the battery and use it.
May 25, 2007 | Sony PlayStation Portable (PSP) Console
LG enV VX9900 Cellular Phone Logo
100 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
