My PortegeR100 won't booting
It was my portege won't goest into shutdown. Then i was tried to force shuting down by pressing power buttun. But unfortunally, when i try to switch on again it's can't booting. Only led indicator flashing with orange colour? Please give me advice about this case. Thank's and regard's
  • 1 more comment
  • gondez_edan Dec 21, 2008
    Thank for your advice. But after i try that your way i didn't see any change of this case. Please give me more advice?
    Thank for your advice. I was tried, but still didn't see anything change of this case. Please give me more advice?
  • gondez_edan Dec 22, 2008
    Ok thank. The worse possibility is my board or power supply spoiled. Can you give me any reffence's where i can get that spare part. This is (my portege) the thing which can't change to the other one. Very lot's memories with this. Thank for your strong support.
  • 679 Answers
Ok try this, shut the power off after you unplug it. Take out the battery, wait a minute and put it back in. Restart, that should fix it. If it's a larger problem let me know.
Posted on Dec 15, 2008
  • George Bill
    George Bill Dec 21, 2008
    Boot into the bios by pressing the delete key as it powers up. If you can't power up you have to un plug not just shut down. there is still current flowing in the board unless u unplug it. Then you must clesr the cmos by poping out the battery. when u are finished restart and kep taping the delete key until it goes into the bios, if you catn even start it, then you may have burnt out the board or power supply.
  • George Bill
    George Bill Dec 24, 2008
    Yes go to, pricewatch.com, and select from hundreds of vendors in real time. You should be able to pick up whatever part you need there, would appreciate a rating of at least 3 if I helped you at all, as that is how we get compensation, thanks and have a happy holiday
Toshiba satellite L750-iq6 won't shut down or sleep?!?
That is a software issue with the OS. Was it always like this? If not, try a system restore to some time in the past when you know the unit was working fine.
Sep 06, 2017 | Toshiba Satellite L750 Notebook
HOW CAN I REMOVE MY BIOS PASSWORD FOR TOSHIBA PORTEGE A100
Dear Friend,
Removed the memory cover along with the memory, press down the power button for about 30 seconds, place the memory back along with the cover and try to boot up your computer. If none of this work try the link below:
http://www.laptop-repair.info/toshiba_bios_password.html
Good Luck!
Nov 24, 2011 | Toshiba Computers & Internet
How do i get my toshiba portege m 100 to boot from cd
Press either delete or f2 during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
hope this helps good luck
Sep 13, 2010 | Toshiba Portege M100 Notebook
My toshiba Satellite A215-S7422 System unit, dose not shut down until the batries runs down.
1. It means the normal shutdown process is not working!
2. Try to press the "Power" button continuously untill the system shuts down!
3. Restart the system.
4. Press F8 key to get the advanced booting options.
5. Select the last option "Last Known Best Configuration"!
if it don't helps tell me...tc! :)
Jan 05, 2010 | Toshiba Satellite Pro A210-EZ2202X...
Shutdown popup slow in appearing
ok get Windows XP mananger or TuneUP utilities and adjust the speed of your shut down, if you have a bluetooth adapter try shuting it's radio off at shutdown time.
Jul 10, 2009 | Microsoft Windows XP Professional SP3 Full...
I need to manually reboot my toshiba portege laptop how do i do it?
a manual re-boot is just shuting down your laptop then re-starting it
Jun 07, 2009 | Computers & Internet
Lenovo booting problem
so u;re saying that the BIOS tests are taking 10 minutes ?! Usually that happenes when the computer shutes down brutally (after power surges, by removing the battery ... by forced shut down). Try doing a BIOS update, and also set it so it will skip some tests or not to do through testing ....
Aug 08, 2008 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Will not power-up after a shut down unless the CMOS is cleared.
try swapping the Ram Chips "Memory" try running it with less memory or if you have multi chips take a few out and run it
Good luck
Please rate US! thanks
Jul 14, 2008 | ASUS P4P800-MX Motherboard
Acer shut down
ok go to control panel, then power options and check that the option states that when you press the shutdown button, it powers down. You also may need to check inthe bios (F2 or Del on boot up) and go to standard cmos settings or the advanced cmos settings and see if ACPI is enabled, if not enable, then save settings and exit and a reboot will follow.
Apr 25, 2007 | Acer Veriton 5600GT PC Desktop
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
