Question about Sony CDX-MP40 CD Player
Cdx-mp40 Installed the headunit, the unit ejects and takes CDs so there is power but nothing else happens. All power leads are connected and the earth is connected. I have switched the yellow and red leads as suggested in the installation guide. The CD sometimes auto-ejects when the face is released but not always. I have an illumination lead from my car which doesn't connect to anything on the CDx-MP40, i presume the face is powered from the red and yellow leads. Any thoughts...
  • RichARD wATTS Mar 15, 2007
    I checked the fuse box yesterday and the permanent fuse had blown (the dead interior light should have woken me to that). So it's all working fine now, but thank's for the advise anyway.
  • Mini_woody Nov 16, 2007
    i've got a similar problem, the cd goes in and out no problem, i click reset and when the face is placed back in the unit whirls, but i dont get no lighting and the unit doesnt turn on, but the it takes CD's, anyone help??
  • 156 Answers
You are correct, the unit powers entirely from the red and yellow leads. Your symptoms sound like a unit that isn't getting power on the red (switched) lead. The most likely cause is a blown fuse in your vehicle's fuse box.
Posted on Mar 15, 2007
SOURCE:
Sony CDX-L410X Power Going To Unit But Won't Turn On
make sure you are getting power the the red (ignition ) wire.
Mar 03, 2010 | Sony CDX-L410X CD Player
How to connect a pioneer amplifier to sony cd player in car
easy as matey!
connect RCA leads to the preout in the back of the sony headunit run it down one side of the car into the boot and connect the RCA leads to the amp
You will need to wire in the power earth and remote
Remote lead connects to the BLUE N WHITE wire on back on head unit
Run the power lead and remote down one side of car and the RCA leads down other side which will stop interferance
then just connect the ground and that should be you done
Upfront Audio
May 08, 2009 | Car Audio & Video
Sony CDX-MP40 only works after hitting reset button
If you dosn't find a solution, then I'am very interested in buying the faceplate for this unit. batman@galnet.dk
Mar 09, 2008 | Sony CDX-MP40 CD Player
Sony CDX-L480X
I had the same problem, CD not accepted by unit and pressing source button to select CD player causes unit to display reset.
Using reset button just causes unit to 'whir' for a while, problem is not solved. Firstly with unit switched off, and the ignition off I inserted a CD using some gentle force, I then inserted a second CD, forcing it in over the top of the first. Next I pressed and held the reset button for a short time before releasing it. Both CDs were ejected, when the unit had stopped I took the CDs out, replaced the front panel and turned on the ignition, The unit will now accept CDs and eject them O.K.
(This did take two attempts to get right). Seems to reset the eject status of the CD player.
Avulon
Feb 17, 2008 | Sony CDX-L480X CD Player
Sony CDX-MP40, not take or load c.ds up, but ejects them!?!
Sounds like a jammed micro-switch, open it up and check for dirt in the loading mech.
Apr 14, 2007 | Sony CDX-MP40 CD Player
Changer refuses to eject or play CDs, keeps saying reset
Hello, in order to repair CD changer you have to be equiped with special tools and knowledge. This repair is only possibble in Authorized Sony Service or at the shop with best references for this kind of job. Best regards, Arpi
Apr 13, 2007 | Sony CDX-656 10-Disc CD Changer
Sony CDX-MP40 won't power up the amp.
Most in-dash stereos have a blue wire in the harness which is used as a "wake up" signal for external amps. Did you connect this? Does it have any voltage on it when the stereo is on?
Mar 03, 2007 | Sony CDX-MP40 CD Player
MP3 files start skipping/popping after few minutes of playback
Sony say in the manual that if you record high bit-rate mp3's the sound may be intermittent. I feel this is due to the decoder having to move ALOT of bits around to play, try some makeing a disk with mixed rate mp3's on. e.g.) some 64Kbps, some 128, some 192, and some as high as you can get and see if there is any differ Luck
Mar 02, 2007 | Sony CDX-MP40 CD Player
CDX-MP40
Did you hook up the red ignition wire?
Sep 14, 2006 | Sony CDX-MP40 CD Player
Can't get CDX-MP40 to work...
You can get a manual here http://esupport.sony.com/perl/select-system.pl?DIRECTOR=DOCS Your unit sounds like its dead. Try unplugging it for a day or overnight. if that dosent work your going to need to take the unit into the repair center. Good Luck
Aug 13, 2006 | Sony CDX-MP40 CD Player
Sony CDX-MP40 CD Player Logo
189 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Dalynn Turner
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
