Question about Kitchen Ranges
Oven door lock engaged while NOT in cleaning mode with door open. Will not disengage. Cycled main power, cancel button does not work; Oven also inoperable. HELP! Appreciate any tips or tricks to get it unlocked. Thanks. Tom Model FGF378WCCC Frigeidaire Please let me know asap !! at tomew94@aol.com I spilled some water on the stove top and the lock on my oven door engaged, the display started beeping and the display was showing F3.  Somehow I was able to open the oven door but the lock is still engaged and I can't close the door and the oven doesn't work.  help!
  • 71 Answers
Your oven uses a motor lock latch #316028101 around 100 dollars the motor or the linkages to the motor are most likely bad . the control board could be supplying the voltage to the motor is which case the board would be bad if the are no sensors telling it to lock the door If you are not pretty handy with a schematic and a meter I would suggest you call someone. F3 can be a thermal fuse or maybe the wrong resistance on the over sensor
Posted on Dec 14, 2008
Oven door on lock
is the light oven on??? can you see the switch/button that the door would hit against to turn light off?? if so depress button so the lifht goes off, and start a clean cycle.This should make the lock mechanism engage fully. then cancel cycle and should fully disengage lock/latch (you need to depress light switch to trick unit into thinkin the door is closed)
Mar 08, 2008 | Kenmore 30169 Electric Single Oven
Can't disengage oven door lock
Lock disengaged on its own after a day. Oven is now clean, everything working properly.
Jul 06, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Door locks and F9 fault codes
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 24, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Oven door won't unlock
I had the same problem on my Kenmore Electric Range. Door would not unlock. Tried pressing "Off" for multiple seconds, but still would not unlock. No error codes. Clock was displaying normally. Finally decided to try running it thru the self cleaning operation to get it to cycle thru locking and unlocking the door. When I started self clean, the door automatically went thru the auto lock and "locked" appeared in the display. I then hit "Off" to clear it and stop the cleaning cycle. The door then unlocked as normal!
Feb 16, 2008 | Kitchen Ranges
Our GE Profile JTP18 keeps flashing "door lock" since we ran a self clean
most of the time a simple fix.... http://www.geappliances.com/search/fast/infobase/10004586.htm
you have to trick the door lock mech into cycling through the cleaning process (takes about 20 seconds)
Print Range - “LOCKED DOOR” flashes in the display
If “LOCKED DOOR” is flashing in the display of your range or oven, and the self-clean cycle has not been selected, follow the steps below to reset your control:
Motorized Switch
    1. With the door open, locate the door jamb switch on the face of the oven. It will look like a small black post or dowel.
    2. Push it in until the oven cavity light goes off, indicating that the oven believes the door is closed.
    3. While you hold the door jamb switch in this position, complete the following steps.
    4. Press the Clean pad, wait 10 seconds.
    5. When the cycle initiates, press the clear/off or cancel pad immediately to cancel it.
    6. Wait 10 seconds for the display to clear.
    7. The door should unlock and there should not be a need for service.
Manual Switch
    1. Press the Clean pad.
    2. Close the door.
    3. Slide the latch to lock the door.
    4. Hit the cancel button immediately.
    5. Unlock the door.
If the above does not correct the situation, a service technician will need to check your cooking product. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Sep 14, 2007 | GE Profile JTP18 Electric Single Oven
Kitchen Ranges Logo
310 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
