Question about Kenmore 24032\24036 Top Load Washer
Washer stoped with full load of water and clothes
Kenmore #110 direct drive washing machine just quit on me with a full load of clothes and water. If I advance the dial, it will agitate again but can't get it to drain.
Dynomite web site!
  • 85 Answers
It couuld be a bad lid switch
Posted on Dec 14, 2008
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
Water trickles out when filling instead of the steady stream
Check the water inlet valve. Remove the water supply hoses and check the small metal screens inside the valve (especially the hot water side) and check the solenoids using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a bad solenoid. Here is a photo for reference. Hope this helped and best wishes.
Sep 30, 2009 | Kenmore 23822 Top Load Washer
What is the capacity of my Kenmore 80 series Model 110 washer?
The cubic feet of the Kenmore washer model 110 heavy duty is 2.8 cubic feet. Measured to the top water line 14.5 inches and using the radius of the tub of 10.375 inches
Sep 08, 2009 | Kenmore 24032\24036 Top Load Washer
No water run into the machine, kenmore front load washer
Is water turned on to machine don't laugh it has happened.
Check water valve if you know electricity you can hook 110 volts directly to the water valve and see if water will come out or check with an ohm meter.
Also be sure you have 110 volts to machine check first.
Jun 10, 2009 | Kenmore HE2 Plus Front Load Washer
CLOTHES STILL WET AFTER SPINNING
Is it pumping the water out?
If no, check the lid switch and the pump.
If yes, check the lid switch and the direct drive coupling on the motor.
Mar 14, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Washing Machine - no cold water coming in
most likely cuase would be the inlet valve
you would need the complete model number to make sure you get the right part for that unit.
Feb 23, 2009 | Kenmore 46462 Front Load Washer
Stoped machine
if you still have power then it sounds as if your pump may be blocked
Jun 09, 2008 | Zanussi ZWF1430W Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
107 people viewed this question
Sal De
fordexpert
Robert Rankin
