My lcd tv cutts out while its on what should i do
    Genius:
  • 2,920 Answers
Take it to a shop and have it repaired before it gets worse
Posted on Dec 14, 2008
Zebra label printer cutt off prints
In printer control panel menu check the print width of the label according to the size mean to say if you have 4 inch label the print width set to maximum value if print width set minimum then cutts off the print.
Codabar Pvt Limited Pakistan
Apr 13, 2014 | Zebra TLP 2824 Printer
Tv picture cut off
If the fuse used do not match with its rating [low amp rated fuse] this type of fault can occur. If the used fuse is of correct rating, and still it blow up during working, the main board to your TV should be checked for short circuted component/s. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts.
Mar 31, 2014 | Sanyo Televison & Video
Lg32lc46 lcd tv cuts off after a while
It sounds like a back-light inverter board fault. Check it. Replace it if needy. Normally, these boards has no repair. Replacement only can be done. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts.
Dec 24, 2013 | Televison & Video
SONY KDL-40S4100 flashes 5 times
try to force on the tv un plug and use remote when tv iv completly off. and press display 5 vol+ then power and see if tv stays on and in service menu look for eror code .if tv stays on if it cutts off then one of lamp in screen is defective. its mean screen defective
Mar 01, 2012 | Sony Bravia KDL-40S4100 40 in. LCD TV
Jerks at 4000 rpm won't accelerate past 4000
it cutts off the fuel after 4000 rmp check the cutt off switch
Aug 01, 2010 | 2000 Mazda Protege
Keeps blowing thermal cutt-off fuse
You need to remove the front dryer panel clean dryer completely of lint . Even where the lint filter is . Also make sure the vent hose is not kinked or filled with water and lint . I changed a thermal cutt-off 3 times in a dryer within about 2 weeks time . On the last time , removed the front panel and filter housing , and a big ball of lint fell out . Cleaned vent housing and inside of dryer and no more problems since .
Sep 05, 2009 | Whirlpool Dryers
Overscan
do you mean the top of the picture is cutt off? if so then go into tv menu and set screen size to 16:9 not auto. if that doesnt work then try settings on ps3 hopefully that works
Jul 23, 2008 | Toshiba 55H70 55" Rear Projection...
Rca 32v434t 32"
When cleaning the front of your tv do you spray glass cleaner on the glass? Many time I have seen glass cleaner that has dripped down onto the pc board, contols like power, vol, and channel control are under the tube and there is nothing to protect it from liquid, if it has not eaten the componets from Corsosion there may be a chance that you may be able to clean with flux remover or tuner cleaner. Be very careful when using these cleaners because they can eat plastic.
Sep 02, 2007 | RCA 32V550T 32" TV
Cutte Sonnu
what is your problem Cutte ?
Apr 06, 2007 | Panasonic NV-MD9000EN Mini DV Digital...
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
