Question about Logitech Quickcam Chat Webcam
Not working driver
I have a usb pc camera
    Genius:
  • 1,061 Answers
Http://lsearch.logitech.com/search/query.jsp?qt=SUPPORT&cl=US%2CEN&country=us&language=en&accept-charset=iso-8859-1&rq=0&charset=utf-8&la=en&col=corpweb&style=usen&region=AMR...YOU CAN DOWNLOAD ALL YOU NEED DRIVERS AND MANUAL HERE.RICHARDM69
Was this solution helpful? Show your Appreciation by rating it:
Posted on Dec 15, 2008
Why my Nikon Coolpix L26 isnt uploading to computer via usb to PC
When you connect the USB cable from the camera to the PC, the camera should shut down. If it doesn't perhaps your cable is defect. Or one of the connectors, from the camera or from the PC.
When the cable works on another PC (or Laptop) you can assume the cable is good. But then the USB connector in the PC could be not connected, or the USB controller in the PC is not working correct.
Sure you did install the Nikon software on the PC to?
Apr 30, 2014 | Nikon Coolpix L26 Compact
My sony cyber shot does not get connected via usb to system
[Click here to Download*]
Description
Thisdriver download for Sony digital cameras will work on most Windowssystems and Cybershot digital cameras. This is a USB driver and in caseyou are not familiar with the general approach to installing drivers,it is important that you follow these steps:
  1. Download the Sony driver
  2. Make sure that the USB cable and digital camera are NOT connected to your PC
  3. Install the digital camera driver
  4. Do not try to plug the camera into your PC until you have finished installing the driver and restarted your computer.
Thisprocess may take an extra few minutes, but it helps prevent problemsand ensure the Sony digital camera driver is properly installed. Afterrestarting, the driver will let you transfer files via USB. Simply plugin your Sony camera and you should be ready to go.
Oct 17, 2009 | Sony Cyber-shot DSC-W30 Digital Camera
Driver for camera
yes you can down usb drive for web or pc cam freeware it will work, there are also many added freeware only for pc or web cam
Jul 23, 2009 | Computers & Internet
Problem Installing ZSMC USB PC Camera (ZS211)
I am trying to install ZSMC USB PC Camera (ZS211). When I tried
installing it in my Laptop (COMPAQ Presario V4000), i get message
Cannot Install this HArdware. There was a Probelm Installing this
hardware.
Aug 19, 2008 | Cameras
Driver ViMicro USB PC Camera 305
Hello all ز
You can download from here Aldiriver .
Jun 10, 2008 | Computers & Internet
Using usb
Make sure the computer contains the drivers for the camera.
If you would be using FireWire (IEEE1394) it would be no problem.
Check the box the camera came with (or Online) and install the required software. If you have done all that and it still doesn't work try to change the port you connect to. If it still doesn't work you may have an incompatibility issue or a corrupt USB driver which is resolved by reinstalling your computer USB drivers and camera drivers.
Hope it helps.
Mar 03, 2008 | JVC Cybercam GR-DV500US Mini DV Digital...
What should I do if my PC still won't recognize the camera after I reinstalled the USB drivers?
If the camera is still not recognized after the USB driver has been re-installed, one of the following situations may apply. "PC Camera" may be selected as the USB setting on the digital camera. Change the USB setting to DSC or select DSC in USB MODE. (This only applies to models with a USB Setting or USB MODE option in the SETUP screen.) Does the LCD monitor on the digital camera show that the USB connection is active (USB, DSC or a USB symbol with an arrow, etc.)? If not, the digital camera and PC may not be connected correctly. Check the items listed below. a) Restart the PC and reconnect the USB cable. b) If the PC has multiple USB ports, connect the cable to a different USB port. If steps a) and b) have both been tried and there is still no USB connection indicator displayed on the LCD monitor, there may be a problem with the digital camera or USB cable. Contact an authorized Fujifilm service center and ask them to check the digital camera together with the USB cable. Refer to the Digital Equipment Repair page for information such as the procedure for requesting checks and the locations of authorized Fujifilm service outlets. The USB driver may not be installed correctly. Download the USB driver from the Digital Camera Downloads page and re-install the driver The camera may not be recognized correctly if it is connected to an added USB interface board or via a USB hub. Always connect the camera directly to the USB port on the PC
Aug 30, 2005 | Fuji FinePix 2300 Digital Camera
If the camera is still not recognized after the USB driver has been re-installed, one of the following situations may apply. "PC Camera" may be selected as the USB setting on the digital camera. Change the USB setting to DSC or select DSC in USB MODE. (This only applies to models with a USB Setting or USB MODE option in the SETUP screen.) Does the LCD monitor on the digital camera show that the USB connection is active (USB, DSC or a USB symbol with an arrow, etc.)? If not, the digital camera and PC may not be connected correctly. Check the items listed below. a) Restart the PC and reconnect the USB cable. b) If the PC has multiple USB ports, connect the cable to a different USB port. If steps a) and b) have both been tried and there is still no USB connection indicator displayed on the LCD monitor, there may be a problem with the digital camera or USB cable. Contact an authorized Fujifilm service center and ask them to check the digital camera together with the USB cable. Refer to the Digital Equipment Repair page for information such as the procedure for requesting checks and the locations of authorized Fujifilm service outlets. The USB driver may not be installed correctly. Download the USB driver from the Digital Camera Downloads page and re-install the driver The camera may not be recognized correctly if it is connected to an added USB interface board or via a USB hub. Always connect the camera directly to the USB port on the PC.
Aug 29, 2005 | Fuji FinePix 3800 Digital Camera
Aug 29, 2005 | Fuji FinePix 2600 Zoom Digital Camera
Logitech Quickcam Chat Webcam Logo
20 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
